Thread: dynamic simulation in hysys!!!!!!!!
  1. dynamic simulation in hysys!!!!!!!!
    hello!
    I am doing a dynamic simulation in hysys !!!... I'm having a big problem with a heat exchanger. The following message appears frequently
    E-100 Very low efficiency flash failed. Increased efficiencies to 5% Which flash allowed to succeed.
    The mass balances are not correct. In input there is 140 kg / h, in output flow rates are negative.
    What does it mean ?????
    how can I resolve this??
    p.s. sorry for my english
    thanks in advance
    Because ur heat exchanger is not sized properly .. u are getting the error .. size the H.E. K value for required press drop & flow , also check the pressure spec u have specified downstream ..it should less than the outlet press specified at the H.E. . if the problem still persist try setting the mass flow factor to -0.001
  5. what you say is correct .... but since the simulation is in the dynamic state, the flow entering in the heat exchanger is variable in the time !!!...if i consider a smaller volume, i find correct values of flow, but then I have to increase the size of H.E. because the flow is greater !!!!!!!
    how do I fix this problem???
    thanks in advance
  1. Article: Dynamic Simulation In Hysys
    By wingsofdreams in forum Home Articles
    Last Post: 11-30-2012, 11:43 PM
  2. dynamic simulation in hysys!!!!!!!!
    By marchese85 in forum Home Articles
    Last Post: 04-21-2010, 09:21 PM
