Thread: dynamic simulation in hysys!!!!!!!!
  1. dynamic simulation in hysys!!!!!!!!
    hello!
    I am doing a dynamic simulation in hysys !!!... I'm having a big problem with a heat exchanger. The following message appears frequently
    E-100 Very low efficiency flash failed. Increased efficiencies to 5% Which flash allowed to succeed.
    The mass balances are not correct. In input there is 140 kg / h, in output flow rates are negative.
    What does it mean ?????
    how can I resolve this??
    p.s. sorry for my english
    thanks in advance
    See More: dynamic simulation in hysys!!!!!!!!
    Because ur heat exchanger is not sized properly .. u are getting the error .. size the H.E. K value for required press drop & flow , also check the pressure spec u have specified downstream ..it should less than the outlet press specified at the H.E. . if the problem still persist try setting the mass flow factor to -0.001
    My threads; Fdias :
    •    Sponsored Links
    • what you say is correct .... but since the simulation is in the dynamic state, the flow entering in the heat exchanger is variable in the time !!!...if i consider a smaller volume, i find correct values of flow, but then I have to increase the size of H.E. because the flow is greater !!!!!!!
      how do I fix this problem???
      thanks in advance
    1. Dynamic Simulation In Hysys
      By wingsofdreams in forum Process Simulation Community
      Last Post: 02-06-2013, 06:38 PM
    2. Article: Dynamic Simulation In Hysys
      By wingsofdreams in forum Home Articles
      Last Post: 11-30-2012, 11:43 PM
    3. dynamic simulation in hysys...help me !!!!!!!
      By marchese85 in forum Process Simulation Community
      Last Post: 06-08-2010, 10:16 AM
    4. dynamic simulation in hysys!!!!!!!!
      Last Post: 04-21-2010, 09:21 PM
    5. dynamic simulation in hysys!!help!!!!!!!!!!!
      Last Post: 04-13-2010, 09:32 PM
