Page 1 of 2 1 2 LastLast
Results 1 to 12 of 21
Thread: Heat Exchanger Design Handbook
    [link Point to another website Only the registered members can access] Heat Exchanger Design Handbook (Mechanical Engineering (Marcell Dekker))
    This comprehensive reference covers all the important aspects of heat exchangers (HEs)--their design and modes of operation--and practical, large-scale applications in process, power, petroleum, transport, air conditioning, refrigeration, cryogenics, heat recovery, energy, and other industries. Reflecting the author's extensive practical experience in industry, the Heat Exchanger Design Handbook discusses standard construction, thermo-hydraulic fundamentals and thermal design of Hes--tubular, extended surface, plate, and both rotary matrix and fixed regenerators explains algorithms and subalgorithms derived from heat transfer and geometry optimization modules showcases the tremendous recent advances in plate exchanger designs--brazed-plate, flow-flex tubular, wide gap, twin plate, double wall, graphite, and welded--and associated improvements addresses global and national standards and codes analyzes flow-induced vibration and mechanical design of shell-and-tube Hes explores a wide spectrum of materials for HEs, corrosion behavior, and optimum fabrication methods illustrates techniques for fabrication of shell-and-tube HEs, as well as brazing and soldering compact HEs examines quality assurance issues for HE manufacture and NDT techniques considers operational problems like corrosion and fouling and more! Abundantly illustrated with over 400 drawings, diagrams, tables, and equations, the Heat Exchanger Design Handbook is an excellent resource for mechanical, chemical, and petrochemical engineers; process equipment and pressure vessel designers; and upper-level undergraduate and graduate students in these disciplines
    [link Point to another website Only the registered members can access] .
    Thank You
    Thank You
    Thank You
    thank u a lot
  9. Thank you
  10. Thanks a lot
    thank you
    Does anybody have "Heat Exchanger Design Handbook 2002 (HEDH 2002)" ?
    see for details:
    see for details:
  14. Hi,
    Can anybody send the link for Chemical Engineering Thermodynamics by Smith, Abbott and Van Ness.
    Thanks in advance
  16. #12
    Thank you
  1. Heat Exchanger Design Handbook 2nd - Thulukkanam
    By Azad in forum Petrochemical
    Last Post: 06-17-2019, 06:33 AM
  2. Heat exchanger design handbook by t. kuppan
    By mbc.engg in forum Mechanical Engineering
    Last Post: 08-21-2014, 07:06 AM
  3. Heat Exchanger Design HandBook by T.Kuppan
    By tuatk in forum Mechanical Engineering
    Last Post: 06-29-2013, 03:31 PM
  4. Heat Exchanger Design Handbook
    By calefon in forum Oil And Gas Process
    Last Post: 06-25-2013, 12:16 AM
  5. Heat Exchanger Design Handbook
    By Jazz79 in forum Mechanical Engineering
    Last Post: 06-22-2010, 03:14 PM
