when stress analyst should analis the piping systemn ?
please refer me to stardard or some handbook?
when we can use CAESAR II ?
tanx
tanx
Formal cases are needed when
1/-When you have rotating equipment such as pumps, turbines, compressors ..for which you have to limit nozzle loads.
2/-When you have nozzle loads on thin vessels
3/-note also that are coolers are also very sensitive to external loads
4/-When you have high or cryogenic temperatures for which there is a lift off on the supports, and where spring supports are needed.
5/-When line deflections have to be checked , and where span tables are not sufficient.
6/-When you have concentrated loads from heavy flanges, valves ..simple pipe span tables are not enough
7/-When you need to know the loads which have to be transmitted to supporting structures
8/-When you need to know the moment at flanges , to check their rating, by reckoning with the generated additional equivalent pressure.
9,10..n/-When you have dynamic loads = seismic, slugs, vibration, modal analysis, discharge loads
Each company has it own rules to decide when or not to calculate software or by inspection with nomographs or Cantilever methods or by comparison with previous isometrics
but ultimately all is based on the above points.
Standard EN 134 ?? ( copy should be in this site) for piping , allows you after classification of the line *steam , gas , pressure,..) to go or not for formal calculations.
dear FATHI,
thank u very mush for good reply.
cheers
i didnt find EN 134,
do u have this standard?
Start with PED , let me explain,
All is derived from the Pressure European Directive , called PED
The PED gives guidances, but now formula or sketches,...
There is a PED for vessels and Piping
By classifying according to PED , you will see if you have to calculate with software such as Caesar , you will determine also the extend and amount of inspection and documentation, etc...
The PED is in the web !! for free
tobbe and others,
sorry for the confusion , By 134??? I mean the european piping code , e.g. EN 13480, this contains 5 volumes , the first is general and gives guidance for classification as stated in PED, the 3d is for design,the last ones are for fabrication and inspection testing..all is a bit similar to B31.3 but without ASTM materials...etc
At the end of each volume , you have appendix Z , which tells how to stay in conformity with the PED
by the way the EN's for piping are here in this site =
tank u very much dear FATHI,
cheers
