Results 1 to 1 of 1
Thread: cause and effect matrix on hysys
  1. cause and effect matrix on hysys
    Im trying to learn how to use the cause and effect matrix but the hysys tutorials are very good (weird huh?) So if someone could tell me how to configure one on hysys for example it could be to something like this:
    case A) there are 2 tanks, when the first tank is filled at 90%, close the valve from tank A and open the valve from tank B to fill it
    or
    case B) there are 2 pumps (main pump and back-up pump), the main pump trips (loose his power or any other) so the back-up pump start-up.
    I supose that in case A the matrix would be something like:
    tank A lvl >=90% --> close valve A
    tank B lvl >=90% --> open valve B
    and for the case B:
    pump A power = 0 HP --> start-up pump B power (or set pump B power at "X" HP)
    If someone could help me on this I could figure my way out to bigger systems.
    Thank you very much.
  1. Acoustic matrix coring
    By daken in forum Geology & Exploration
    Last Post: 02-25-2014, 09:29 AM
  2. Help : Cause & Effect Trip Matrix
    By majorv in forum Instrumentation & Control
    Last Post: 01-23-2014, 11:52 PM
  3. Help: Matrix acidization
    By abcde123 in forum Oil And Gas Production
    Last Post: 12-03-2013, 11:21 PM
  4. Matrix Stimulation Books
    By thaly2010 in forum Oil And Gas Production
    Last Post: 01-30-2011, 12:46 AM
  5. Joule Thompson Effect ( JT Effect ), Trothling
    By rossi in forum Pipeline And Fluid Flow
    Last Post: 03-22-2009, 11:24 AM
