Is it necessary to vent a balance bellows type PSV/ PRV always to the atmosphere ?
Can't the discharge be sent to a tank or line instead ?
if is Steam you can vented to ATM but anything else but steam should be diverted to Flare and is always good idea to be a Balanced Bellows type valve.
As I have seen all critical plant safety valves are open to atmosphere as for steam and for Other pcocess fluid/toxic gases which needs to burn are connected to hot flare of plant.
For positive displacment pumps(like screw pumps) there is always pressure safety valve which diverts flow from discharge side to suction side if limit crosses.
