Results 1 to 1 of 1
Thread: Hot Oil Furnace Efficiency
  1. Hot Oil Furnace Efficiency
    Greetings,
    I have a question: Does the efficiency of Hot Oil Furnace [a furnace that is used to increase the temperature of Thermia B oil using fuel gas] decrease by the decreasing the fuel gas flow?
    Let's say the overall efficiency is about 85% when oil temperature is increased from 168 to 240 oC (delta T is around 72 oC). What will happen to the efficiency if I keep the oil flow constant and I decrease the fuel gas flow in order to increase the oil temperature by just 15 oC?
    Also what is the typical thermal efficiency for a Fuel Gas fired Furnace?
    Thanks and regards!
    By Nabil17 in forum Mechanical Engineering
    Last Post: 07-26-2019, 11:41 AM
  2. Replies: 0
    Last Post: 12-02-2016, 08:39 PM
  3. Furnace and Boiler Design
    By adel khalifa in forum Electrical & Power Engineering
    Last Post: 04-17-2014, 03:57 PM
  4. sootblower for furnace
    Last Post: 05-27-2011, 03:36 PM
  5. Damper of Reforming furnace
    Last Post: 12-06-2010, 09:20 AM
