We are facing problems with one of our reforming unit furnaces. There is a common duct in the three furnaces. The damper of the middle furnace causing problem. This damper falls several times after burning. The skin temperature of the tubes remain good but the stack temperature is higher than safe value by almost 150 degree Celsius (around 900 degree Celsius) . The furnace outlet temperature is operated below the design temperature by almost 25 degree Celsius. Our design temperature is 525 degree Celsius. The shaft, plate of damper used of stainless steel grade. We had changed burner tips several times but the problem was not solved. Please suggest me the cause and remedy of this problem.
