Thread: Are there ways for calculating petrophysical properties from well log in Petrel?
    Question Are there ways for calculating petrophysical properties from well log in Petrel?
    Hello everyone,
    I know that in Techlog I can determinate the rock properties (Sw, Porosity, N/G), but in petrel, there is a calculator tool where I could maybe put equations of correlations.
    My question is:
    Can I do it in Petrel? and Can petrel generate another track in correlation window with these results like techlog?
    I attached a picture in the following link if you do not understand me.
    Thanks in advance,
    Regards!
    Re: Are there ways for calculating petrophysical properties from well log in Petrel?
    Yes, it is possible to show and generate your Sw, Porosity, and NTG calculations in Petrel.
    Firstly, calculate your petrophysical properties using calculator in Petrel or import them from Techlog (much more easier)
    Secondly, in the input pane of Petrel under Global Well Logs or the related well, find your Sw, Porosity, and NTG calculations, and check them all.
    Lastly, play with the window setting of well correlation to make some cosmetics on your values.
    I hope this will help you.
    Best Regards,
  1. Need a petrophysical software
    By aniltyagi in forum Geology & Exploration
    Last Post: 08-02-2016, 10:04 AM
  2. Petrophysical calculators
    By usaf in forum Reservoir
    Last Post: 12-11-2009, 02:02 PM
  3. Petrophysical calculators
    By usaf in forum Oil And Gas Production
    Last Post: 12-11-2009, 12:24 PM
