should a designated ground for a stack be bare or insulated? does anyone have a standard reference for this or any literature? also the grounding electrode for this ground should be tied to the area grounding electrode system right?(NEC says to tie all electrodes together). and if the ground should be bare, do you need to try to keep the ground isolated from the structure on the path up? thanks any direction is appreciated
