hi all,
i'm facing the following issue.
On a chemical storage facility there is a pre-action sprinkler type that is just using water.
I'm just concerned that water is not suitable as it will spread chemicals+fire.
How and based on which standard shall i select to adopt foam sprinkler?
and in case i will adopt AFF, is the sprinkler head for a foam system different from the one of water system?
Thank you in advance.
