Results 1 to 5 of 5
Thread: Overfill protection for storage tanks in refineries
  1. Overfill protection for storage tanks in refineries
    API RP 2350 (3rd edition 2005) "Overfill Protection for Storage Tanks in Petroleum Facilities" specifies that high-high-level detector shall be independent of the automatic tank gauge system to provide greater reliability and to comply with the requirements of NFPA 30-2003, Section 4.6.1.1(2) and 4.6.1.1(3). Further there is a Note that State-of-the-art equipment with integrated (not independent) hardware can provide superior reliability for detecting high and high-high levels. NFPA 30-2003 Section 4.6.1.1(4) allows for the use of non-independent alternative systems, provided they are approved by the authority having jurisdiction.
    What are the types and specifications of the '"State-of-the-art" level instruments with integrated hardware for tank gauging and overfill protection? Do radar type level instruments qualify for this? I will be thankful for clarification on these points. Thanks.
  3. could you please sharing the book..
    I interested for this topic, thank you
    I think it should be addressed as a matter of reliability of the equipment more than a "state-of-the art" thing. I my case, I will never use integrated hardware for overspill applications, unless it had a SIL 2 or SIL 3 approved level. There's no guideline no follow in this subject, except your own criteria on how much you will loose if there's an overspill, or which dangers you can allow.
  6. Thanks PabloBS for the clarification.
    Sep 2008
    Planet Earth
    Yes he Pablo is right. Safety protection systems like overfill protection is not a matter of being 'state of art' or not . . . it should be decided by reliability and integrity requirements of the process like Safety Integrity Level (SIL) of Safety Instrumented Functions .
    I would also suggest you to read through the Bunchefield investigation reports to give u more insights on requirements of reliable overfill protection systems
  1. API RP 2001 Fire Protection in Refineries, please.
    By Kot in forum Oil And Gas Process
    Last Post: 12-24-2014, 12:22 PM
  2. API RP 2001 Fire Protection in Refineries, please.
    By Kot in forum Safety And Environment
    Last Post: 06-10-2014, 12:07 AM
  3. API Standard 2350 Overfill Protection for Storage Tank
    By kanankiri in forum Oil And Gas Production
    Last Post: 03-11-2014, 12:19 PM
  4. Cathodic protection of above ground storage tanks
    By f.ghezeljeh in forum Electrical & Power Engineering
    Last Post: 04-02-2011, 08:24 AM
