Page 1 of 2 1 2 LastLast
Results 1 to 12 of 17
Thread: Guidance on Practice for Cathodic Protection (BP)
  1. Guidance on Practice for Cathodic Protection (BP)
    Hi all
    Table of Contents - Page
    Foreword.......................................... .................................................. ........................................... 2
    Introduction...................................... .................................................. ............................................ 5
    1. Scope .................................................. .................................................. ............................... 6
    2. Normative references........................................ .................................................. ................... 6
    3. Terms and definitions....................................... .................................................. .................... 7
    4. Symbols and abbreviations..................................... .................................................. ........... 10
    5. The importance of cathodic protection .................................................. ............................... 11
    5.1. Corrosion threats .................................................. .................................................. .. 11
    5.2. Hazards identification and mitigation........................................ ................................. 11
    6. Competent person .................................................. .................................................. ........... 11
    7. Cathodic protection principles .................................................. ............................................ 11
    7.1. Corrosion control........................................... .................................................. .......... 11
    7.2. Coatings .................................................. .................................................. ............... 12
    7.3. Cathodic protection .................................................. ................................................. 12
    7.4. Polarization .................................................. .................................................. ........... 14
    7.5. Protection criteria onshore .................................................. ...................................... 14
    7.6. Protection criteria offshore .................................................. ...................................... 14
    7.7. Current density .................................................. .................................................. ..... 15
    7.8. Under-protection and over-protection........................................ ................................ 16
    7.9. IR drop.............................................. .................................................. ...................... 16
    7.10. Coupons .................................................. .................................................. ............... 16
    8. Galvanic anode systems........................................... .................................................. ......... 17
    8.1. Galvanic anodes .................................................. .................................................. ... 17
    8.2. Aluminium anodes .................................................. .................................................. 17
    8.3. Magnesium anodes............................................ .................................................. ..... 18
    8.4. Zinc anodes .................................................. .................................................. .......... 18
    8.5. Applications marine and offshore .................................................. ............................ 18
    8.6. Applications onshore........................................... .................................................. .... 19
    8.7. Connection........................................ .................................................. ...................... 19
    8.8. Installation...................................... .................................................. ......................... 20
    8.9. Risk of failure .................................................. .................................................. ........ 20
    9. Impressed current anode systems .................................................. ..................................... 21
    9.1. Introduction...................................... .................................................. ....................... 21
    9.2. Applications marine and offshore .................................................. ............................ 21
    9.3. Applications onshore........................................... .................................................. .... 23
    9.4. Power sources .................................................. .................................................. ...... 25
    9.5. Anode types............................................. .................................................. ............... 26
    9.6. Reference electrodes........................................ .................................................. ...... 28
    9.7. Cables and connections....................................... .................................................. ... 28
    9.8. Installation...................................... .................................................. ......................... 29
    9.9. Risk of failure .................................................. .................................................. ........ 29
    10. Hybrid systems .................................................. .................................................. ................ 29
    11. Retrofit systems........................................... .................................................. ...................... 30
    12. Advantages and disadvantages – galvanic and impressed current systems ........................ 31
    13. Design objectives and considerations .................................................. ................................ 32
    14. Safety and integrity .................................................. .................................................. .......... 34
    Annex A (Informative) Basics of corrosion......................................... ............................................ 36
    A.1 General........................................... .................................................. .................................. 36
    A.2 Anodic and cathodic reactions .................................................. ........................................... 36
    A.3 Electrolytes .................................................. .................................................. ...................... 37
    A.4 Resistivity .................................................. .................................................. ........................ 37
    A.5 Bimetallic corrosion......................................... .................................................. ................... 38
    A.6 Microbial corrosion......................................... .................................................. .................... 38
    A.7 Stray current corrosion......................................... .................................................. .............. 39
    A.8 Electrochemical series .................................................. .................................................. ..... 39
    I uploaded here
    Sasikumar
    Thank you
    Thank you
    thank you very much.
    Muhammad Khurram
  10. thank you
  11. Thanks a lot
    Dec 2007
    Pakistan
    Blog Entries
    1
    Thanks a lot.
    Oct 2008
    The Netherlands
    Blog Entries
    14
    thanks for this serious stuff ..really
  14. thanks a lot
  16. #12
  1. Cathodic Protection Course
    Last Post: 11-14-2017, 06:42 AM
  2. Cathodic Protection Stardards
    By jorgematoso@hotmail.com in forum Materials Science &Corrosion
    Last Post: 03-07-2014, 12:53 AM
  3. Cathodic Protection
    By f.ghezeljeh in forum Mechanical Engineering
    Last Post: 06-04-2013, 12:50 AM
  4. cathodic protection for pipeline
    By hadip in forum Pipeline And Fluid Flow
    Last Post: 02-26-2013, 06:31 PM
  5. Cathodic protection for API tanks.
    By ECH1 in forum Mechanical Engineering
    Last Post: 04-28-2011, 07:47 AM
