Results 1 to 6 of 6
Thread: Welding electrode - super duplex 2205 and stainless steel
  1. Welding electrode - super duplex 2205 and stainless steel
    Dear Friend,
    I need your help in my work. Recently my company got a order for making the Heat Exchanger. I was asked to make some documents related to welding. i have to make welding procedure specification and procedure qualification requirement and choose the electrode for joining the super duplex 2205 tubes with the stainless steel 304L tubesheet. I am basically a mechanical engineer and i do not have any idea about welding, so please help me with your experience and knowledge. Also i have to make mockup piece of the same help in this issue.
    Thanks in advance,
    Rajesh
  3. I guess you can use 2209. what process are you going to use?
    Please go to this website and download info on how do welding and type of welding process and electrode and filler metal specification.
  7. see attached WPS
    I'm damn busy these days, so sorry for slow answer,but...let me give you few advices, cause I'm dealing all the time with wps's and pqr's for new materials for me:
    first of all, and basicly of all, you need to know something about chemistry; take a look at a certificates of materials; they're always must have included chemical composition of materials, and judging by that (chemical composition) you should find by yourself best filler metal for your materials..for example; everyone (don't get me wrong) use CM2-IG for welding 10CrMo9-10 with 10CrMo9-10 so, what I want to tell you..put it like this; you probably (definetaly) have wps's and wpqr's for some materials you already welded (I mean for welding plans)- take a look at chemical composition of materials and of filler metal, compare them, and you'll know what I mean..it is the same for every materials, mostly it's in chemical composition
    then; google catalogs of big filler metal productors (Lincoln, Bohler, Tysenn...) - it is easy to google it and download welding guidelines and catalogs of that kind of companies- if they guarantee for some filler metal that IS for certain materials - you can't miss it
    and final, make sure if you do pqr (wpar) that your wire or electrode have approval from approval house that will give you that certificate (TUV or something), because if it don't have, you'll make some cost for your company for nothing..
    and remember- 15614 standard tells you that if you can prove something, you can do it...so, brutally said, if you use nifil 625 or some other filler metal for your materials and if all results are satisfied in accordance with standard you doing by (NDT reports, bending testings, hardness test, blah blah....)- just do it ;-)
  1. Request:API TR 938-C-2011_Use of Duplex Stainless Steels
    By acier58 in forum Mechanical Engineering
    Last Post: 07-24-2018, 07:01 PM
  2. Post forming heat treatment for duplex stainless steel materials
    By yatin888 in forum Mechanical Engineering
    Last Post: 01-17-2014, 02:47 PM
  3. Welding stainless steel several times
    By Pieltro in forum Materials Science &Corrosion
    Last Post: 10-01-2013, 10:36 AM
  4. Welding of stainless steel
    Last Post: 12-28-2011, 04:15 PM
  5. Nace -corrosion resistance of weldable super 13cr stainless steel in h2s
    By mohammed21 in forum Materials Science &Corrosion
    Last Post: 09-30-2010, 06:28 AM
