hello
I want to calculate expansion loop
who can I calculate these length ?
hello
Try to get LoopedLines.xls spreadsheet from Natural Gas Engineering Handbook.
Try with following books:
1) Design of Piping Systems - MW Kellogg
2) Piping Handbook - King & Crocker - 5th. edition
3) Piping Engineering - Tube Turns
4) Piping Design and Engineering - ITT Grinnell (Spielvogel method)
Be carefull with your design !!!
Martin Ruben
Looped line referred and quoted as given in Natural gas engineering handbook might be a different subject. Mr Galala cited pipe data prosoftware , yes you can get the output from the prgram easily.I have down loaded the following two articles from web, tehy may also be helpful.
best regards
Venugopal
thans to all these file
thanks alot friend, but i need to konw when i am drilling or running in hole ant pipe what are the factors beside tempreture can lead to pipe expansion?? for example if the gravity and tession can work together with heat exchange to expand the pipe??
