Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Flange Bolt Torque Value
    Dear friends,
    Can somebody please help me with a correlation between gasket material and needed bolt torque value for given process? I was asked today to prepare a report on a torque value change when gasket in use, say klingerit type unknown to me, is replaced with 1/8" thick cured rubber on flange face. I am aware that the relation is fairly if not very complicated one, but I need something to start from.
    Any help would be highly appreciated.
    Best Regards,
    TMN
    Dear friend, please refere Pressure Vessel Design Manual by Dennis R. Moss. There you will find procedure for the same.
    Thanks.
    @ mukesh_enjoy
    Thanks for your help.
    Best Regards,
    TMN
    - See Procedure 2-10 "Bolt Torque Required for Sealing Flanges", Page 59 of book " Pressure Vessel Design Manual by Dennis M. Ross":
    [link Point to another website Only the registered members can access] - Also, see "Chapter 6. Mechanical" of book "LANL Process Piping Guide for ASME B31.3":
    Thanks again for all your great help.
    Best Regards,
    TMN
    Nice contribution "Abdel Halim Galala"
    Oct 2008
    The Netherlands
    Blog Entries
    14
    There is a dedicated and clear chapter about bolt torque, bolt pretension load with or without bolt greasing , with wrench or controlled tightening in this standard
    API 6A
    I believe it is a standard about Christmas trees for oil industry
    Unfortunately I do not have a copy here , but I am wiling to talk in detail if I find it.
    if someons has this standard please upload it , than we can talk further
  11. I would recommend ASME PCC-1 Guidelines for Pressure Boundary Bolted Flange Joint Assembly:
    And secondly for a brief synopsis - Appendix S of ASME Sec VIII-1
    Quote Originally Posted by FATHI View Post
    API 6A
    API 6D Pipeline Valves - 2002:
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Dear Abdelhalim
    I am Looking for API 6A
    repeat A and not D
    So Iif you have it
    Chokran
  14. #11
    Friends here is the link for API 6A
    Hope you will get your answer.
  16. #12
    Dear Abdelhalim
    repeat A and not D
    So Iif you have it
    Chokran
    The available is "API 6FA" Fire Test for Valves - 1994, please let me know if you need it.
  1. A325 Bolt Torque Values
    By dnatarajan in forum Civil & Structural Engineering
    Last Post: 05-11-2013, 02:53 PM
  2. Bolt Torque, Loading & Tightening
    Last Post: 05-06-2013, 06:37 AM
  3. Flange bolt hole orientation
    By JimmyTjock in forum Oil And Gas Production
    Last Post: 04-09-2013, 05:38 AM
  4. FRP flange torque calculation
    By woonyen in forum Pipeline And Fluid Flow
    Last Post: 10-03-2011, 12:21 PM
  5. Bolt Torque and Tightening
    Last Post: 07-04-2011, 09:18 AM
