Well, i just found that if you do upscaling on your property modeling or your petrophysical modeling, the upscale will usually be lower or higher than the well logs data and this happen to my deviated well (+-30degree)
Ok that's great!
I want add me to this topic, We learn more about PETREL I'm new with PETREL but, I hope to help in everything it can..
Thank's "Term"
Thanks Anihita for share the PETREL course 2004!
There's no Petrel class offered in my school. But I know Petrel is a widely used software, which may be helpful in seeking jobs. I wanna learn it by myself. Thanks for your info.
Hi dudes!
I take the information that TEMR was share with the community Egepet.net and concentrate the advance in a word file in order to do more easy follow this help "PETL Step by step".
::from community to community::
Regards to all and success in 2011!!
Temr, I sent you an email. Pls reply.
Tejaswy, to be able to import the model ( only model no input data) from upper version to lower version of petrel ask you friend to export the model in Open Petrel Format(binary)
then import the model
input data can be easily exported - imported in ascii format
I checked 2010 were imported to 2009
Hi everyone.
I need help, can't find out how to set well bore diameter.
I looked at well completion design, global completions, casing. I tried to change different parameters and nevertheless I export simulation case for Eclipse its still the same value in COMPDAT clue word
Please tell me how to change it.
Hi guys,
I really need Petrel installer, I have being look for this but I haven't found nothing. Please share the installer.
thanks.
have a see, thanks
