Hi Eveyone![]()
I Have both Petrel 2010 and Eclipse 2005 (both with --------) installed on my Laptop and they both work Great .
The problem is that, whenever I try to run eclipse from petrel ,it fails to run eclipse saying it can not find eclipse license. .
(by right clicking on imported case in "cases" panel and select simulation run )
However, if I use eclipse launcher to run eclipse ,it works fine and run my data file without any error.
I suspect that this might have something with --------s .
Do you ever encountered the same problem and is there any solution for this ?
Any help or suggestion is greatly appreciated![]()
Cheers !![]()
.and now I can launch eclipse from petrel (Eclipse 2009 and Petrel 2010.2 both 32 bit on windows 7 64 bit )
