Page 5 of 5 FirstFirst ... 3 4 5
Results 49 to 54 of 54
Thread: Asme measurement of fluid flow
  1. Re: Asme measurement of fluid flow
  3. Re: Asme measurement of fluid flow
    Thank you monstrr!
  5. Re: Asme measurement of fluid flow
    dear friends, do you have asme ptc 10 Performance Test Code on Compressors and Exhausters ? can you please upload?
  6. Re: Asme measurement of fluid flow
    link expired , please re-upload bellow standard
    FC-2M Measurement Uncertainty for Fluid Flow in Closed Conduits
    MFC-4M Measurement of Gas Flow by Turbine Meters
    MFC-6M Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
    MFC-7M Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
    MFC-8M Fluid Flow in Closed Conduits : Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
    MFC-10M Method for Establishing Installation Effects on Flowmeters
    MFC-11M Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
    MFC-16M Measurement of Fluid Flow In Closed Conduits by Means of Electromagnetic Flowmeters
  7. Re: Asme measurement of fluid flow
    Thanks so much.
  9. Re: Asme measurement of fluid flow
    Dear everyone,
    Pls share the method to calculate restriction or multi-stage orifice. In case of the pipe size is less than 40 mm.
    Many thank!
  1. Fluid Flow Measurement
    By selmagis in forum Pipeline And Fluid Flow
    Last Post: 09-11-2014, 11:16 PM
  2. Fluid Flow Measurement
    By Mohamed in forum Pipeline And Fluid Flow
    Last Post: 05-01-2013, 12:10 AM
  3. ASME Standards-Fluid Flow Measurement
    By instsuresh in forum Instrumentation & Control
    Last Post: 08-17-2010, 06:46 PM
  4. Fluid Flow Measurement Handbook
    By Shabbir2009 in forum Instrumentation & Control
    Last Post: 09-01-2009, 03:42 PM
