API MPMS 14.5-2002.pdf 0.946 MB
Dear Achmad Nur Eddin,
many thanks for you help, I am really appreciate
regards
Gabonabo
API MPMS 11.1 VOL VII 1st Ed 1987.pdf 48.691 MB
Manual of Petroleum Measurement Standards Chapter 11.1 - Volume Correction Factors Volume VII Table 53A - Generalized Crude Oils Correction of Observed Density to Density at 15 Degrees C Table 54A - Generalized Crude Oils Correction of Volume to 15 Degree
API MPMS 11.4.1 1st Ed 2003.pdf 0.300 MB
Measurement StandardsChapter 11Physical PropertiesData Section 4Properties of Reference Materials Part 1Density of Water and Water Volumetric Correction Factors for Water Calibration of Volumetric Provers First Edition
API MPMS 11.3.2.1 1st Ed 1993.pdf 4.530 MB
Manual of Petroleum Measurement Standards Chapter 11.3.2.1 - Ethylene Density Measurement Manual Disk Available
Thank you very much.
I need API MPMS Chapter 18 full, please upload !
Thanks again !
API MPMS 11.3.3.2 1st Ed 1997.pdf 9.233 MB
Manual of Petroleum Measurement Standards Chapter 11.3.3.2 - Propylene Compressibility Tables Disk Available
API MPMS 11.2.3 1st Ed 1984.pdf 5.689 MB
Manual of Petroleum Measurement Standards Chapter 11.2.3 - Water Calibration of Volumetric Provers
API MPMS 11.2.3M 1st Ed 1984.pdf 12.108 MB
Manual of Petroleum Measurement Standards Chapter 11.2.3M - Water Calibration of Volumetric Provers
API MPMS 11.2.2 2nd Ed 1986.pdf 10.733 MB
Manual of Petroleum Measurement Standards Chapter 11.2.2 - Compressibility Factors for Hydrocarbons: 0.350-0.637 Relative Density (60 Degrees F/ 60 Degrees F) and -50 Degrees F to 140 Degrees F Metering Temperature Second Edition; GPA 8286-86; Errata:June
API MPMS 11.2.1 1st Ed 1984.pdf 9.434 MB
Manual of Petroleum Measurement Standards Chapter 11.2.1 - Compressibility Factors for Hydrocarbons: 0-90 Degrees API Gravity Range
API MPMS 18.1 2nd Ed 2002.pdf 0.659 MB
Manual of Petroleum Measurement Standards Chapter 18 - Custody Transfer Section 1 - Measurement Procedures for Crude Oil Gathered From Small Tanks by Truck Second Edition
[QUOTE=Achmad Nur Eddin;47619]Salim Abdat
API MPMS 11.1 VOL I ACTV 1/1/1980 (R 1997) Manual of Petroleum Measurement Standards Chapter 11.1 - Volume Correction Factors Volume I Table 5A - Generalized Crude Oils and JP-4 Correction of Observed API Gravity to API Gravity at 60 Degrees F Table 6A - Generalized Crude Oils and JP-4 Correction
API MPMS 11.1 VOL II ACTV 1/1/1980 (R 1997) Manual of Petroleum Measurement Standards Chapter 11.1 - Volume Correction Factors Volume II Table 5B - Generalized Products Correction of Observed API Gravity to API Gravity at 60 Degrees F Table 6B - Generalized Products Correction of Volume to 60 Degre
i can't load this.Pls upload again
thank you
Dear Achmad
can help me by that
API MPMS 1 ACTV 7/1/1994 Manual of Petroleum Measurement Standards Chapter 1 - Vocabulary
PI MPMS 2.2A ACTV 2/1/1995 (R 2002) Manual of Petroleum Measurement Standard Chapter 2
API MPMS 3.6 ACTV 2/1/2001 Manual of Petroleum Measurement Standards Chapter 3
PI MPMS 8.1 ACTV 10/1/1995 (R 2000) Manual of Petroleum Measurement Standards Chapter 8 - Sampling Section
PI MPMS 16.2 ACTV 11/1/1994 (R 2002) Manual of Petroleum Measurement Standards Chapter 16 - Measurement of Hydrocarbon Fluids by Weight or Mass Section 2 - Mass Measurement of Liquid Hydrocarbons in Vertical Cylindrical Storage Tanks by Hydrostatic Tank Gauging First Edition
PI MPMS 17.1 ACTV 11/1/2001 Manual of Petroleum Measurement Standards Chapter 17 - Marine Measurement Section
PI MPMS 19.1 ACTV 3/1/2002 Manual of Petroleum Measurement Standards Chapter 19 - Evaporative Loss Measurement Section
API STD 2551 ACTV 1/1/1965 (R 2002) Standard Method for Measurement and Calibration of Horizontal Tanks ASTM D1410
API STD 2555 ACTV 1/1/1966 (R 1997) Method for Liquid Calibration of Tanks ASTM D1406-65
also i will be thankful if you help by any other document cover the following
API STD 2555 1987.pdf 0.638 MB
API STD 2555 Method for Liquid Calibration of Tanks equal to ANSI/ASTM D1406-65 R(1997)
API STD 2551 1st Ed 2002 (R).pdf 2.237 MB
API STD 2551 Standard Method for Measurement and Calibration of Horizontal Tanks ASTM D1410
API MPMS 17.1 4th Ed 2001.pdf 0.487 MB
Manual of Petroleum Measurement Standards Chapter 17 - Marine Measurement Section 1 - Guidelines for Marine Cargo Inspection Fourth Edition
you are the greatest,
thanks a lot
Dear Achmad Nur Eddin or anyone else who have it and wish to share
i need the following MPMS
MPMS 5.6
MPMS 21
