great work.. thanks and continue, its remarkable effort!
Dear Temr,
To create new well path why not you using the process called 'well path design' in Petrel. What is difference between your method and well path design method. I am also in learning stage.
Dipak, no difference in terms of results
But what if you do not have license for this well engineering module???
I showing you here what you can do in petrel "manually"
You can try to built it using standard method and my and make comparison.
If you do this comparison please share with us what is better and fast
Rgds
ok temr sir you continue in your own way, we are waiting for your lesson
WOo Hoo temr....Woo hoo to you![]()
Its true that not all Petrel have "well path deviations plugin"
it needs to be licenced from SLB.
I do not have the license from SLB for instance.
I had to get it made from a friend who had the license.
I have one more question temr.
My friend sent me the *.pet file and the *.sim file. It was made in Petrel 2009.2 and this will not open in Petrel 2009.1.
I cannot open the *.Pet in Petrel 2009.1 as it says it was made in a new version.
Do you have any work arounds for this?
You have been great help temr. I am very indebted to you .
Well in fact you cant open the new version of project in old petrel version - the reason is maintenance you pay to $chlubmerger , the only way to open this files is to **** binary files located in *.pet folder that process called reverse engineering and in order to do this you need some skills in programming.
The easiest way just ask you friend to send you the project in ascii format if it is input data
And if it is the model ask him to export grid in RESCUE format
If you can list the data you want to use i can advise you needed export formats
Well ya, my friend has gone for a holiday, I have to wait for him to get back.
If I have the horizontal wells in a format that I can use, I can import them into any project I make on Petrel 2009.1.
Although now I am contemplating of making the whole damn model in eclipse and get it done with.Sure it will take some time but it will be steady.
I just need the Pet file to open in 2009.1.... Damn!!
Lot of time went into designing it.!
thanx
Great work and great attitude temr. Thank you.
