help
my friends , I want the WRC bulletin 446 - for buried pipeline, or if someone have the all formulas to calculate bukling ,upheaval for buried pipeline hight pressure , please I need this documents...
thanks in advance
help
thanks in advance
thank you
please upload loose body flange design (slip on type).
thanks,
Sameer
thanq
Pleasse helpme for hight preassure 6500 # injection gas piping class is require
Thanks a lot!
hi mr Galala
Can you please share the spreadsheets of pressure vessel design calculation?
best regards
sarsi_c@hotmail.com
Can anybody upload the files again ?
The links are dead.
Thanks in advance
Dear Mr. Galala,
Can you please upload the links again.
Thanks & Regards,
Amit
Dear Mr. Galala,
Thanks & Regards,
Amit
Hello everyone,
About the API 6A, We can use the calculation for blind flange thickness from ASME VIII part UG or not. For example, I try to test with flange 2.1/16" API 15000 with ASME VIII part UG, the thickness of flange is very bigger than thickness follow API 6A. ( ~ 139mm vs 50mm thickness).
Looking forward to hearing your reply soon.
