Page 3 of 19 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 25 to 36 of 220
Thread: Petrel Step by Step
  1. just a comment for Gocad, it's not an in house software, it was started in a research consortium w*w.gocad.org, but the company like che*ron develop their make their own plugin/
    Jan 2009
    ALA, KZ
    Quote Originally Posted by pantherKL View Post
    Thanks for the comment ...
    Dear all i am now in the trip will come back soon with the presents..........
    Stay tuned
    thank you very much, really its very intresting
  6. back to petrel,
    does anyone have a demo data for petrel like segy, las file etc? we need to follow manual with data..
  7. #29
    Feb 2010
    Tierra
    here is the study material for Petrel, though its an old edition, but it will help a lot :
  9. #30
    Feb 2010
    Tierra
    other course material for petrel, may be someone has posted it earlier
  10. Than k u verymuch, and Please continue "temr".................Please.............Please.. ...........So many members are wait for u?????????
  11. #32
    I need to put some horizontal wells in my reservoir, How do i do that?
    Can you help ?
  12. #33
    Jan 2009
    ALA, KZ
    Hello everybody!
    It is take time as i make the input data by myself
    Here is Chapter 3 part 1 well heads
    Excell file link
    [link Point to another website Only the registered members can access] well head file link
    [link Point to another website Only the registered members can access] Chapter link
    [link Point to another website Only the registered members can access] Chapter 4 part1.
    In this chapter we will load well data needed for the project which are
    1.well heads data
    2.well logs data
    3.event data
    4.production data
    5.comment log data
    6. Tops data
    Well heads
    Start petrel an safe you project
    Now you have plain project .
    The first thing you need to do is load you well heads data
    The following data is a must
    1. Well name
    2. X-coordinate
    3. Y-coordinate
    4. Kelli bushing
    5. Bottom depth
    6. Well Deviation.
    For this project i skip deviation but will give you short description
    All data mentioned above are well know . I want to keep you attention on kelly bushing
    kelly bushing or rotary bushing is fn adapter that serves to connect the rotary table to the kelly.
    But in petrel this is altitude or sub sea true vertical depth (SSTVD) of rotary table
    Why rotary table not well head ?? The main reason that you make logging form rotary table and measure depth(MD) from the table. Kb and well deviation then used to convert your MD values to SSTVD values.
    I supply the file with small macro for you is the main task to analysis it as i will use this file in my next examples
    Note . In order to make the button working you need to enable macros in you excel do the following
    in the excel file you have all data needed so press the button
    After pressing the button the will be file in the directory where you place excel file
    This is text file with all the data needed to load your well heads
    Return to your input window in Petrel
    Wright click and choose import to the tree
    You will be taken to petrel import window
    if you open file type window you will see the list of formats that supported by petrel
    Note: there two major types of format ASCII and binary try to use ASCII format when taking or giving data as you can read data in this format.
    From drop down menu choose well heads
    and choose our file heads.inc
    Petrel red the file and show dialog
    As i used headers i old petrel the data i use in text file . But if you are not use headers you can do manual assign of columns in the file
    Press cancel and do the following
    Open in test editor file heads.inc
    delete 3 first rows save and close the file
    Now repeat opening of well heads
    this is standart window if you are not using headers or yor headers corrupted
    So now lets make manual load
    Press left button of your mouse and select all colums and press remove button . Now click 5 time on add button
    You will get following window
    Now from drop down menu tell petrel what each column means
    Keep in mind this option. It says to petrel how many rows it should skip during reading of file in this case 7 not 9 change it to 7 and press ok for all
    Now you get well folder with your wells
    Click and launch new 3D window here
    Select all wells by pressing to wells
    To change appearance of you wells double click on well folder and you will be taken to well global settings window
    In Style window you can change appearance of wells
    Now lets go to the menu we have under well folder.
    There 5 subfolders under wells
    1. Global well logs
    2. Global completion
    3. Well attributes
    4. Well filters
    5. Saved search
    Global well logs - folder were petrel process and store well logs
    Global completions - folder were petrel stores completion or event data like perforations, casings diameters, plugs etc.
    Global observed data - folder where you can store production o volumetric data like oil gas water rates and injections.
    Well filters - define and store of custom well filters
    Saved searches - folder to save create search of wells
    This is end for now ..........................
  13. #34
    Jan 2009
    ALA, KZ
    Quote Originally Posted by Tejaswy View Post
    Can you help ?
    Will be in next chapter
  14. #35
    Ya thanks for that.
    How long will that take.?
    Not to rush you ....I am in a rush so!!!!
  16. thank's
  1. Replies: 11
  2. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
