Page 2 of 2 FirstFirst 1 2
Results 13 to 18 of 18
Thread: CEN Standards Collection 91/370: CEN TC 23 - Transportable Gas Cylinders
  1. #13
    Re: CEN Standards Collection 91/370: CEN TC 23 - Transportable Gas Cylinders
    update:
    EN versions:
    EN ISO 407:2004 Small medical gas cylinders - Pin-index yoke-type valve connections (ISO 407:2004)
    EN ISO 7225:2007 Gas cylinders - Precautionary labels (ISO 7225:2005)
    EN ISO 21007-1:2005 Gas cylinders - Identification and marking using radio frequency identification technology - Part 1: Reference architecture and terminology (ISO 21007-1:2005)
    EN ISO 22434:2011 Transportable gas cylinders - Inspection and maintenance of cylinder valves (ISO 22434:2006)
    EN ISO 22435:2007/A1:2012 Gas cylinders - Cylinder valves with integrated pressure regulators - Specification and type testing (ISO 22435:2007/Amd 1:2012)
    better quality:
    EN ISO 7866:2012 Gas cylinders - Refillable seamless aluminium alloy gas cylinders - Design* construction and testing (ISO 7866:2012)
    EN ISO 9809-3:2010 Gas cylinders - Refillable seamless steel gas cylinders - Design* construction and testing - Part 3: Normalized steel cylinders (ISO 9809-3:2010)
    EN ISO 10286:2015 Gas cylinders - Terminology (ISO 10286:2015)
    EN ISO 10297:2014 Gas cylinders - Cylinder valves - Specification and type testing (ISO 10297:2014* Corrected version 2014-11-01)
    EN ISO 10462:2013 Gas cylinders - Acetylene cylinders - Periodic inspection and maintenance (ISO 10462:2013)
    EN ISO 10692-1:2001 Gas cylinders - Gas cylinder valve connections for use in the microelectronics industry - Part 1: Outlet connections (ISO 10692-1:2001)
    EN ISO 10692-2:2001 Gas cylinders - Gas cylinder valve connections for use in the microelectronics industry - Part 2: Specification and type testing for valve to cylinder connections (ISO 10692-2:2001)
    EN ISO 11114-1:2012 Gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 1: Metallic materials (ISO 11114-1:2012)
    EN ISO 11114-2:2013 Gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 2: Non-metallic materials (ISO 11114-2:2013)
    EN ISO 11114-3:2010 Gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 3: Autogenous ignition test for non-metallic materials in oxygen atmosphere (ISO 11114-3:2010)
    EN ISO 11120:2015 Gas cylinders - Refillable seamless steel tubes of water capacity between 150 l and 3000 l - Design* construction and testing (ISO 11120:2015)
    EN ISO 11372:2011 Gas cylinders - Acetylene cylinders - Filling conditions and filling inspection (ISO 11372:2011)
    EN ISO 11623:2015 Gas cylinders - Composite construction - Periodic inspection and testing (ISO 11623:2015)
    EN ISO 12209:2013 Gas cylinders - Outlet connections for gas cylinder valves for compressed breathable air (ISO 12209:2013)
    EN ISO 14246:2014 Gas cylinders - Cylinder valves - Manufacturing tests and examinations (ISO 14246:2014)
    EN 15888:2014 Transportable gas cylinders - Cylinder bundles - Periodic inspection and testing
    EN ISO 17871:2015 Gas cylinders - Quick-release cylinder valves - Specification and type testing (ISO 17871:2015)
    EN ISO 21007-2:2015 Gas cylinders - Identification and marking using radio frequency identification technology - Part 2: Numbering schemes for radio frequency identification (ISO 21007-2:2015)
    the missing are:
    EN ISO 12209:2013/A1:2016 Gas cylinders - Outlet connections for gas cylinder valves for compressed breathable air - Amendment 1: Outlet connection up to a maximum cylinder working pressure of 500 bar (ISO 12209:2013/Amd 1:2016)
    EN ISO 24431:2016 Gas cylinders - Seamless* welded and composite cylinders for compressed and liquefied gases (excluding acetylene) - Inspection at time of filling (ISO 24431:2016)
    new link:
    update:
    added new/missing:
    EN 13807:2017 Transportable gas cylinders - Battery vehicles and multiple-element gas containers (MEGCs) - Design* manufacture* identification and testing
    the missing are:
    EN ISO 11114-1:2012/A1:2017 Gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 1: Metallic materials - Amendment 1 (ISO 11114-1:2012/Amd 1:2017)
    new link:
    update...better quality or EN versions:
    EN 1802:2002 Transportable gas cylinders - Periodic inspection and testing of seamless aluminium alloy gas cylinders
    EN 1803:2002 Transportable gas cylinders - Periodic inspection and testing of welded carbon steel gas cylinders
    EN 1968:2002 Transportable gas cylinders - Periodic inspection and testing of seamless steel gas cylinders
    EN 1968:2002/A1:2005 Transportable gas cylinders - Periodic inspection and testing of seamless steel gas cylinders
    EN 12862:2000 Transportable gas cylinders - Specification for the design and construction of refillable transportable welded aluminium alloy gas cylinders
    EN 13099:2003 Transportable gas cylinders - Conditions for filling gas mixtures into receptacles
    EN 13293:2002 Transportable gas cylinders - Specification for the design and construction of refillable transportable seamless normalized carbon manganese steel gas cylinders of water capacity up to 0*5 litre for compressed* liquefied and dissolved gases and up to 1 li
    EN 13322-1:2003/A1:2006 Transportable gas cylinders - Refillable welded steel gas cylinders - Design and construction - Part 1: Carbon steel
    EN 13322-2:2003/A1:2006 Transportable gas cylinders - Refillable welded steel gas cylinders - Design and construction - Part 2: Stainless steel
    EN 13365:2002/A1:2005 Transportable gas cylinders - Cylinder bundles for permanent and liquefied gases (excluding acetylene) - Inspection at time of filling
    EN 13385:2002 Transportable gas cylinders - Battery vehicles for permanent and liquefied gases (excluding acetylene) - Inspection at time of filling
    EN 13720:2002 Transportable gas cylinders - Filling conditions for acetylene battery vehicles
    EN ISO 15996:2005 Gas cylinders - Residual pressure valves - General requirements and type testing (ISO 15996:2005)
    EN ISO 15996:2005/A1:2007 Gas cylinders - Residual pressure valves - General requirements and type testing (ISO 15996:2005)
    EN ISO 16148:2016 Gas cylinders - Refillable seamless steel gas cylinders and tubes - Acoustic emission examination (AT) and follow-up ultrasonic examination (UT) for periodic inspection and testing (ISO 16148:2016)
    missing are:
    EN ISO 10297:2014/A1:2017 Gas cylinders - Cylinder valves - Specification and type testing - Amendment 1: Pressure drums and tubes (ISO 10297:2014/Amd 1:2017)
    EN ISO 11114-4:2017 Transportable gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 4: Test methods for selecting steels resistant to hydrogen embrittlement (ISO 11114-4:2017)
  6. #16
    the missing is:
  7. #17
    full list 28.10.2017:
    EN 720-1:1999 Transportable gas cylinders - Gases and gas mixtures - Part 1: Properties of pure gases
    EN 1089-3:2011 Transportable gas cylinders - Gas cylinder identification (excluding LPG) - Part 3: Colour coding
    EN 1919:2000 Transportable gas cylinders - Cylinders for liquefied gases (excluding acetylene and LPG) - Inspection at time of filling
    EN 1920:2000 Transportable gas cylinders - Cylinders for compressed gases (excluding acetylene) - Inspection at time of filling
    EN 1964-3:2000 Transportable gas cylinders - Specification for the design and construction of refillable transportable seamless steel gas cylinders of water capacities from 0,5 litre up to and including 150 litres - Part 3: Cylinders made of seamless stainless steel wit
    EN ISO 3807:2013 Gas cylinders - Acetylene cylinders - Basic requirements and type testing (ISO 3807:2013, Corrected version 2014-11-01)
    EN ISO 7225:2007/A1:2012 Gas cylinders - Precautionary labels (ISO 7225:2005/Amd 1:2012)
    EN ISO 7866:2012 Gas cylinders - Refillable seamless aluminium alloy gas cylinders - Design, construction and testing (ISO 7866:2012)
    EN ISO 7866:2012/AC:2014 Gas cylinders - Refillable seamless aluminium alloy gas cylinders - Design, construction and testing - Technical Corrigendum 1 (ISO 7866:2012/Cor 1:2014)
    EN ISO 9809-1:2010 Gas cylinders - Refillable seamless steel gas cylinders - Design, construction and testing - Part 1: Quenched and tempered steel cylinders with tensile strength less than 1 100 MPa (ISO 9809-1:2010)
    EN ISO 9809-2:2010 Gas cylinders - Refillable seamless steel gas cylinders - Design, construction and testing - Part 2: Quenched and tempered steel cylinders with tensile strength greater than or equal to 1 100 MPa (ISO 9809-2:2010)
    EN ISO 9809-3:2010 Gas cylinders - Refillable seamless steel gas cylinders - Design, construction and testing - Part 3: Normalized steel cylinders (ISO 9809-3:2010)
    EN ISO 10156:2017 Gas cylinders - Gases and gas mixtures - Determination of fire potential and oxidizing ability for the selection of cylinder valve outlets (ISO 10156:2017)
    EN ISO 10297:2014 Gas cylinders - Cylinder valves - Specification and type testing (ISO 10297:2014, Corrected version 2014-11-01)
    EN ISO 10961:2012 Gas cylinders - Cylinder bundles - Design, manufacture, testing and inspection (ISO 10961:2010)
    EN ISO 11117:2008 Gas cylinders - Valve protection caps and valve guards - Design, construction and tests (ISO 11117:2008)
    EN ISO 11117:2008/AC:2010 Gas cylinders - Valve protection caps and valve guards - Design, construction and tests - Technical Corrigendum 1 (ISO 11117:2008/Cor 1:2009)
    EN ISO 11118:2015 Gas cylinders - Non-refillable metallic gas cylinders - Specification and test methods (ISO 11118:2015)
    EN ISO 11120:2015 Gas cylinders - Refillable seamless steel tubes of water capacity between 150 l and 3000 l - Design, construction and testing (ISO 11120:2015)
    EN ISO 11363-1:2010 Gas cylinders - 17E and 25E taper threads for connection of valves to gas cylinders - Part 1: Specifications (ISO 11363-1:2010)
    EN ISO 11363-1:2010/AC:2012 Gas cylinders - 17E and 25E taper threads for connection of valves to gas cylinders - Part 1: Specifications - Technical Corrigendum 2 (ISO 11363-1:2010/Cor 2:2012)
    EN ISO 11363-2:2010 Gas cylinders - 17E and 25E taper threads for connection of valves to gas cylinders - Part 2: Inspection gauges (ISO 11363-2:2010)
    EN ISO 11439:2013 Gas cylinders - High pressure cylinders for the on-board storage of natural gas as a fuel for automotive vehicles (ISO 11439:2013)
    EN ISO 11621:2005 Gas cylinders - Procedures for change of gas service (ISO 11621:1997)
    EN 12245:2009+A1:2011 Transportable gas cylinders - Fully wrapped composite cylinders
    EN 12257:2002 Transportable gas cylinders - Seamless, hoop-wrapped composite cylinders
    EN ISO 13088:2012 Gas cylinders - Acetylene cylinder bundles - Filling conditions and filling inspection (ISO 13088:2011)
    EN 13096:2003 Transportable gas cylinders - Conditions for filling gases into receptacles - Single component gases
    EN 13096:2003/AC:2006 Transportable gas cylinders - Conditions for filling gases into receptacles - Single component gases
    EN 13293:2002 Transportable gas cylinders - Specification for the design and construction of refillable transportable seamless normalized carbon manganese steel gas cylinders of water capacity up to 0,5 litre for compressed, liquefied and dissolved gases and up to 1 li
    EN 13322-1:2003 Transportable gas cylinders - Refillable welded steel gas cylinders - Design and construction - Part 1: Carbon steel
    EN 13322-2:2003 Transportable gas cylinders - Reffilable welded steel gas cylinders - Design and construction - Part 2: Stainless steel
    EN ISO 13341:2010 Gas cylinders - Fitting of valves to gas cylinders (ISO 13341:2010)
    EN ISO 13341:2010/A1:2015 Gas cylinders - Fitting of valves to gas cylinders - Amendment 1 (ISO 13341:2010/Amd 1:2015)
    EN 13365:2002 Transportable gas cylinders - Cylinder bundles for permanent and liquefied gases (excluding acetylene) - Inspection at time of filling
    EN 13807:2017 Transportable gas cylinders - Battery vehicles and multiple-element gas containers (MEGCs) - Design, manufacture, identification and testing
    EN ISO 13769:2009 Gas cylinders - Stamp marking (ISO 13769:2007)
    EN 14208:2004 Transportable gas cylinders - Specification for welded pressure drums up to 1000 litre capacity for the transport of gases - Design and construction
    EN ISO 14246:2014/A1:2017 Gas cylinders - Cylinder valves - Manufacturing tests and examinations - Amendment 1 (ISO 14246:2014/Amd 1:2017)
    EN ISO 14456:2016 Gas cylinders - Gas properties and associated classification (FTSC) codes (ISO 14456:2015)
    CEN/TR 14473:2014 Transportable gas cylinders - Porous materials for acetylene cylinders
    EN 14513:2005 Transportable gas cylinders - Bursting disc pressure relief devices (excluding acetylene gas cylinders)
    EN 14638-1:2006 Transportable gas cylinders - Refillable welded receptacles of a capacity not exceeding 150 litres - Part 1: Welded austenitic stainless steel cylinders made to a design justified by experimental methods
    EN 14638-3:2010 Transportable gas cylinders - Refillable welded receptacles of a capacity not exceeding 150 litres - Part 3: Welded carbon steel cylinders made to a design justified by experimental methods
    EN 14638-3:2010/AC:2012 Transportable gas cylinders - Refillable welded receptacles of a capacity not exceeding 150 litres - Part 3: Welded carbon steel cylinders made to a design justified by experimental methods
    EN 14876:2007 Transportable gas cylinders - Periodic inspection and testing of welded steel pressure drums
    EN ISO 15245-1:2001 Gas cylinders - Parallel threads for connection of valves to gas cylinders - Part 1: Specification (ISO 15245-1:2001)
    EN ISO 15245-1:2001/A1:2013 Gas cylinders - Parallel threads for connection of valves to gas cylinders - Part 1: Specification (ISO 15245-1:2001)
    EN ISO 15245-2:2001 Gas cylinders - Parallel threads for connection of valves to gas cylinders - Part 2: Gauge inspection (ISO 15245-2:2001)
    CEN/TR 15444:2006 Transportable gas cylinders - Gas cylinders conforming to the TPED to be used for PED applications - Applicability and justifications
    EN ISO 15996:2017 Gas cylinders - Residual pressure valves - Specification and type testing of cylinder valves incorporating residual pressure devices (ISO 15996:2017)
    EN 16509:2014 Transportable gas cylinders - Non-refillable, small transportable, steel cylinders of capacities up to and including 120 ml containing compressed or liquefied gases (compact cylinders) - Design, construction, filling and testing
    EN 16753:2016 Gas cylinders - Periodic inspection and testing, in situ (without dismantling) of refillable seamless steel tubes of water capacity between 150 l and 3 000 l, used for compressed gases
    EN ISO 17879:2017 Gas cylinders - Self-closing cylinder valves - Specification and type testing (ISO 17879:2017)
    EN ISO 22435:2007 Gas cylinders - Cylinder valves with integrated pressure regulators - Specification and type testing (ISO 22435:2007)
    EN ISO 24431:2016 Gas cylinders - Seamless, welded and composite cylinders for compressed and liquefied gases (excluding acetylene) - Inspection at time of filling (ISO 24431:2016)
    EN ISO 25760:2015 Gas cylinders - Operational procedures for the safe removal of valves from gas cylinders (ISO 25760:2009)
    the missing:
  9. #18
    Hi, do you have EN 13769:2018?
  1. ISO Collection 78/300:ISO/TC 58 - Gas cylinders
    Last Post: 07-23-2019, 08:14 AM
  2. Replies: 2
    Last Post: 07-29-2017, 03:33 AM
  3. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
  4. CEN Standards Collection
    By Sajid Ali Khan in forum Mechanical Engineering
    Last Post: 06-12-2016, 12:55 AM
  5. CEN Standards Collection
    Last Post: 03-25-2016, 10:08 PM
