now also completed sector....thanx
thanks to amjadmalik75 sector is complete:
update:
EN ISO 643:2012 Steels - Micrographic determination of the apparent grain size (ISO 643:2012) - EN version
EN ISO 6892-1:2016 Metallic materials - Tensile testing - Part 1: Method of test at room temperature (ISO 6892-1:2016) - added new standard
missing one now is:
EN ISO 6508-1:2016 Metallic materials - Rockwell hardness test - Part 1: Test method (ISO 6508-1:2016)
links:
or
Dear Borntosin,
Please Post ISO 13665 PLEASE;
WITH REGARDS
AKASH
update:
EN ISO 6508-1:2016 Metallic materials - Rockwell hardness test - Part 1: Test method (ISO 6508-1:2016) - added missing standard
sector complete again
or
update:
EN ISO 148-1:2016 Metallic materials - Charpy pendulum impact test - Part 1: Test method (ISO 148-1:2016) - added new edition of standard
EN ISO 148-3:2016 Metallic materials - Charpy pendulum impact test - Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines (ISO 148-3:2016) - added new edition of standard
the new missing ones are:
EN ISO 148-2:2016 Metallic materials - Charpy pendulum impact test - Part 2: Verification of testing machines (ISO 148-2:2016)
EN ISO 14577-4:2016 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 4: Test method for metallic and non-metallic coatings (ISO 14577-4:2016)
new links:
or
or
update:
better quality of:
EN ISO 6892-2:2011 Metallic materials - Tensile testing - Part 2: Method of test at elevated temperature (ISO 6892-2:2011)
EN ISO 7438:2016 Metallic materials - Bend test (ISO 7438:2016)
EN ISO 16808:2014 Metallic materials - Sheet and strip - Determination of biaxial stress-strain curve by means of bulge test with optical measuring systems (ISO 16808:2014)
EN ISO 20482:2013 Metallic materials - Sheet and strip - Erichsen cupping test (ISO 20482:2013)
EN ISO 26203-2:2011 Metallic materials - Tensile testing at high strain rates - Part 2: Servo-hydraulic and other test systems (ISO 26203-2:2011)
still missing:
new links:
or
update:
better quality:
EN 10319-1:2003 Metallic materials - Tensile stress relaxation testing - Part 1: Procedure for testing machines
EN ISO 12004-1:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 1: Measurement and application of forming-limit diagrams in the press shop (ISO 12004-1:2008)
EN ISO 12004-2:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 2: Determination of forming-limit curves in the laboratory (ISO 12004-2:2008)
still missing one is:
new link:
update...added missing one:
complete again
update...
better quality or EN versions:
EN ISO 3651-1:1998 Determination of resistance to intergranular corrosion of stainless steels - Part 1: Austenitic and ferritic-austenitic (duplex) stainless steels - Corrosion test in nitric acid medium by measurement of loss in mass (Huey test) (ISO 3651-1:1998)
EN ISO 7799:2000 Metallic materials - Sheet and strip 3 mm thick or less - Reverse bend test (ISO 7799:1985)
EN ISO 10113: 2014 Metallic materials - Sheet and strip - Determination of plastic strain ratio (ISO 10113:2006* Corrected version 2007-08-01)
EN 10319-2:2006 Metallic materials - Tensile stress relaxation testing - Part 2: Procedure for bolted joint models
still complete....
does anyone have EN ISO 7500-2:2015?
