full list:
EN ISO 10693:2014 Soil quality - Determination of carbonate content - Volumetric method (ISO 10693:1995)
EN ISO 10930:2013 Soil quality - Measurement of the stability of soil aggregates subjected to the action of water (ISO 10930:2012)
EN ISO 11063:2013 Soil quality - Method to directly extract DNA from soil samples (ISO 11063:2012)
EN ISO 11260:2011 Soil quality - Determination of effective cation exchange capacity and base saturation level using barium chloride solution (ISO 11260:1994+Cor 1:1996)
EN ISO 11267:2014 Soil quality - Inhibition of reproduction of Collembola (Folsomia candida) by soil contaminants (ISO 11267:2014)
EN ISO 11268-1:2015 Soil quality - Effects of pollutants on earthworms - Part 1: Determination of acute toxicity to Eisenia fetida/Eisenia andrei (ISO 11268-1:2012)
EN ISO 11268-2:2015 Soil quality - Effects of pollutants on earthworms - Part 2: Determination of effects on reproduction of Eisenia fetida/Eisenia andrei (ISO 11268-2:2012)
EN ISO 11268-3:2015 Soil quality - Effects of pollutants on earthworms - Part 3: Guidance on the determination of effects in field situations (ISO 11268-3:2014)
EN ISO 11269-1:2012 Soil quality - Determination of the effects of pollutants on soil flora - Part 1: Method for the measurement of inhibition of root growth (ISO 11269-1:2012)
EN ISO 11269-2:2013 Soil quality - Determination of the effects of pollutants on soil flora - Part 2: Effects of contaminated soil on the emergence and early growth of higher plants (ISO 11269-2:2012)
EN ISO 11272:2014 Soil quality - Determination of dry bulk density (ISO 11272:1998)
EN ISO 11274:2014 Soil quality - Determination of the water-retention characteristic - Laboratory methods (ISO 11274:1998 + Cor 1:2009)
EN ISO 11275:2014 Soil quality - Determination of unsaturated hydraulic conductivity and water-retention characteristic - Wind's evaporation method (ISO 11275:2004)
EN ISO 11276:2014 Soil quality - Determination of pore water pressure - Tensiometer method (ISO 11276:1995)
EN ISO 11461:2014 Soil quality - Determination of soil water content as a volume fraction using coring sleeves - Gravimetric method (ISO 11461:2001)
EN ISO 11508:2014 Soil quality - Determination of particle density (ISO 11508:1998)
EN ISO 12404:2015 Soil quality - Guidance on the selection and application of screening methods (ISO 12404:2011)
EN 12457-1:2002 Characterisation of waste - Leaching - Compliance test for leaching of granular waste materials and sludges - Part 1: One stage batch test at a liquid to solid ratio of 2 l/kg for materials with high solid content and with particle size below 4 mm (withou
EN 12457-2:2002 Characterisation of waste - Leaching - Compliance test for leaching of granular waste materials and sludges - Part 2: One stage batch test at a liquid to solid ratio of 10 l/kg for materials with particle size below 4 mm (without or with size reduction)
EN 12457-3:2002 Characterisation of waste - Leaching - Compliance test for leaching of granular waste materials and sludges - Part 3: Two stage batch test at a liquid to solid ratio of 2 l/kg and 8 l/kg for materials with high solid content and with particle size below 4
EN 12457-4:2002 Characterisation of waste - Leaching - Compliance test for leaching of granular waste materials and sludges - Part 4: One stage batch test at a liquid to solid ratio of 10 l/kg for materials with particle size below 10 mm (without or with size reduction)
EN ISO 12782-1:2012 Soil quality - Parameters for geochemical modelling of leaching and speciation of constituents in soils and materials - Part 1: Extraction of amorphous iron oxides and hydroxides with ascorbic acid (ISO 12782-1:2012)
EN ISO 12782-2:2012 Soil quality - Parameters for geochemical modelling of leaching and speciation of constituents in soils and materials - Part 2: Extraction of crystalline iron oxides and hydroxides with dithionite (ISO 12782-2:2012)
EN ISO 12782-3:2012 Soil quality - Parameters for geochemical modelling of leaching and speciation of constituents in soils and materials - Part 3: Extraction of aluminium oxides and hydroxides with ammonium oxalate/oxalic acid (ISO 12782-3:2012)
EN ISO 12782-4:2012 Soil quality - Parameters for geochemical modelling of leaching and speciation of constituents in soils and materials - Part 4: Extraction of humic substances from solid samples (ISO 12782-4:2012)
EN ISO 12782-5:2012 Soil quality - Parameters for geochemical modelling of leaching and speciation of constituents in soils and materials - Part 5: Extraction of humic substances from aqueous samples (ISO 12782-5:2012)
EN 12920:2006+A1:2008 Characterization of waste - Methodology for the determination of the leaching behaviour of waste under specified conditions
EN 13137:2001 Characterization of waste - Determination of total organic carbon (TOC) in waste* sludges and sediments
EN ISO 13196:2015 Soil quality - Screening soils for selected elements by energy-dispersive X-ray fluorescence spectrometry using a handheld or portable instrument (ISO 13196:2013)
EN 13656:2002 Characterization of waste - Microwave assisted digestion with hydrofluoric (HF)* nitric (HNO3) and hydrochloric (HCl) acid mixture for subsequent determination of elements
EN 13657:2002 Characterization of waste - Digestion for subsequent determination of aqua regia soluble portion of elements
EN 14039:2004 Characterization of waste - Determination of hydrocarbon content in the range of C10 to C40 by gas chromatography
EN ISO 14238:2013 Soil quality - Biological methods - Determination of nitrogen mineralization and nitrification in soils and the influence of chemicals on these processes (ISO 14238:2012)
EN ISO 14240-1:2011 Soil quality - Determination of soil microbial biomass - Part 1: Substrate-induced respiration method (ISO 14240-1:1997)
EN ISO 14240-2:2011 Soil quality - Determination of soil microbial biomass - Part 2: Fumigation-extraction method (ISO 14240-2:1997)
EN ISO 14254:2011 Soil quality - Determination of exchangeable acidity in barium chloride extracts (ISO 14254:2001)
EN 14345:2004 Characterization of waste - Determination of hydrocarbon content by gravimetry
EN 14346:2006 Characterization of waste - Calculation of dry matter by determination of dry residue or water content
CEN/TS 14405:2004 Characterization of waste - Leaching behaviour tests - Up-flow percolation test (under specified conditions)
EN 14429:2015 Characterization of waste - Leaching behaviour test - Influence of pH on leaching with initial acid/base addition
EN 14582:2016 Characterization of waste - Halogen and sulfur content - Oxygen combustion in closed systems and determination methods
CEN/TR 14589:2003 Characterization of waste - State of the art document - Chromium VI specification in solid matrices
EN 14735:2005 Characterization of waste - Preparation of waste samples for ecotoxicity tests
EN 14735:2005/AC:2006 Characterization of waste - Preparation of waste samples for ecotoxicity tests
EN 14997:2015 Characterization of waste - Leaching behaviour test - Influence of pH on leaching with continuous pH control
EN 15002:2015 Characterization of waste - Preparation of test portions from the laboratory sample
EN ISO 15009:2016 Soil quality - Gas chromatographic determination of the content of volatile aromatic hydrocarbons* naphthalene and volatile halogenated hydrocarbons - Purge-and-trap method with thermal desorption (ISO 15009:2016)
CEN/TR 15018:2005 Characterization of waste - Digestion of waste samples using alkali-fusion techniques
EN 15169:2007 Characterization of waste - Determination of loss on ignition in waste* sludge and sediments
EN 15192:2006 Characterisation of waste and soil - Determination of Chromium(VI) in solid material by alkaline digestion and ion chromatography with spectrophotometric detection
EN 15216:2007 Characterization of waste - Determination of total dissolved solids (TDS) in water and eluates
EN 15308:2016 Characterization of waste - Determination of selected polychlorinated biphenyls (PCB) in solid waste by gas chromatography with electron capture or mass spectrometric detection
EN 15309:2007 Characterization of waste and soil - Determination of elemental composition by X-ray fluorescence
CEN/TS 15364:2006 Characterization of waste - Leaching behaviour tests - Acid and base neutralization capacity test
EN 15527:2008 Characterization of waste - Determination of polycyclic aromatic hydrocarbons (PAH) in waste using gas chromatography mass spectrometry (GC/MS)
CEN/TS 15862:2012 Characterisation of waste - Compliance leaching test - One stage batch leaching test for monoliths at fixed liquid to surface area ratio (L/A) for test portions with fixed minimum dimensions
EN 15863:2015 Characterization of waste - Leaching behaviour test for basic characterization - Dynamic monolithic leaching test with periodic leachant renewal* under fixed conditions
CEN/TS 15864:2015 Characterization of waste - Leaching behaviour test for basic characterization - Dynamic monolithic leaching test with continuous leachant renewal under conditions relevant for specified scenario(s)
EN 15933:2012 Sludge* treated biowaste and soil - Determination of pH
EN 15934:2012 Sludge* treated biowaste* soil and waste - Calculation of dry matter fraction after determination of dry residue or water content
EN 15935:2012 Sludge* treated biowaste* soil and waste - Determination of loss on ignition
EN 15936:2012 Sludge* treated biowaste* soil and waste - Determination of total organic carbon (TOC) by dry combustion
CEN/TS 15937:2013 Sludge* treated biowaste and soil - Determination of specific electrical conductivity
EN ISO 15952:2011 Soil quality - Effects of pollutants on juvenile land snails (Helicidae) - Determination of the effects on growth by soil contamination (ISO 15952:2006)
CEN/TS 16023:2013 Characterization of waste - Determination of gross calorific value and calculation of net calorific value
EN ISO 16072:2011 Soil quality - Laboratory methods for determination of microbial soil respiration (ISO 16072:2002)
CEN/TR 16110:2010 Characterization of waste - Guidance on the use of ecotoxicity tests applied to waste
EN 16123:2013 Characterization of waste - Guidance on selection and application of screening methods
EN 16166:2012 Sludge* treated biowaste and soil - Determination of adsorbable organically bound halogens (AOX)
EN 16167:2012 Sludge* treated biowaste and soil - Determination of polychlorinated biphenyls (PCB) by gas chromatography with mass selective detection (GC-MS) and gas chromatography with electron-capture detection (GC-ECD)
EN 16168:2012 Sludge* treated biowaste and soil - Determination of total nitrogen using dry combustion method
EN 16169:2012 Sludge* treated biowaste and soil - Determination of Kjeldahl nitrogen
EN 16170:2016 Sludge* treated biowaste and soil - Determination of elements using inductively coupled plasma optical emission spectrometry (ICP-OES)
EN 16171:2016 Sludge* treated biowaste and soil - Determination of elements using inductively coupled plasma mass spectrometry (ICP-MS)
CEN/TS 16172:2013 Sludge* treated biowaste and soil - Determination of elements using graphite furnace atomic absorption spectrometry (GF-AAS)
EN 16173:2012 Sludge* treated biowaste and soil - Digestion of nitric acid soluble fractions of elements
EN 16174:2012 Sludge* treated biowaste and soil - Digestion of aqua regia soluble fractions of elements
EN 16175-1:2016 Sludge* treated biowaste and soil - Determination of mercury - Part 1: Cold-vapour atomic absorption spectrometry (CV-AAS)
EN 16175-2:2016 Sludge* treated biowaste and soil - Determination of mercury - Part 2: Cold-vapour atomic fluorescence spectrometry (CV-AFS)
CEN/TR 16176:2011 Characterization of waste - Screening methods for elemental composition by X-ray fluorescence spectrometry for on-site verification
CEN/TS 16177:2012 Sludge* treated biowaste and soil - Extraction for the determination of extractable ammonia* nitrate and nitrite
CEN/TS 16178:2012 Sludge* treated biowaste and soil - Determination of pharmaceutical products
EN 16179:2012 Sludge* treated biowaste and soil - Guidance for sample pretreatment
CEN/TS 16181:2013 Sludge* treated biowaste and soil - Determination of polycyclic aromatic hydrocarbons (PAH) by gas chromatography (GC) and high performance liquid chromatography (HPLC)
CEN/TS 16182:2012 Sludge treated biowaste and soil - Determination of nonylphenols (NP) and nonylphenol-mono- and diethoxylates using gas chromatography with mass selective detection (GC-MS)
CEN/TS 16183:2012 Sludge* treated biowaste and soil - Determination of selected phthalates using capillary gas chromatography with mass spectrometric detection (GC-MS)
CEN/TR 16184:2011 Characterization of Waste - State-of-the-art document - Analysis of eluates
CEN/TS 16188:2012 Sludge* treated biowaste and soil - Determination of elements in aqua regia and nitric acid digests - Flame atomic absorption spectrometry method (FAAS)
CEN/TS 16189:2012 Sludge* treated biowaste and soil - Determination of linear alkylbenzene sulfonates (LAS) by high-performance liquid chromatography (HPLC) with fluorescence detection (FLD) or mass selective detection (MS)
CEN/TS 16190:2012 Sludge* treated biowaste and soil - Determination of dioxins and furans and dioxin-like polychlorinated biphenyls by gas chromatography with high resolution mass selective detection (HR GC-MS)
EN 16192:2011 Characterization of waste - Analysis of eluates
CEN/TR 16193:2013 Sludge* treated biowaste and soil - Detection and enumeration of Escherichia coli
EN 16377:2013 Characterization of waste - Determination of brominated flame retardants (BFR) in solid waste
EN ISO 16387:2014 Soil quality - Effects of contaminants on Enchytraeidae (Enchytraeus sp.) - Determination of effects on reproduction (ISO 16387:2014)
EN 16424:2014 Characterization of waste - Screening methods for the element composition by portable X-ray fluorescence instruments
EN ISO 16558-1:2015 Soil quality - Risk-based petroleum hydrocarbons - Part 1: Determination of aliphatic and aromatic fractions of volatile petroleum hydrocarbons using gas chromatography (static headspace method) (ISO 16558-1:2015)
CEN ISO/TS 16558-2:2015 Soil quality - Risk-based petroleum hydrocarbons - Part 2: Determination of aliphatic and aromatic fractions of semi-volatile petroleum hydrocarbons using gas chromatography with flame ionization detection (GC/FID) (ISO/TS 16558-2:2015)
CEN/TS 16660:2015 Characterization of waste - Leaching behaviour test - Determination of the reducing character and the reducing capacity
CEN/TS 16675:2014 Characterisation of waste - Test methods for the determination of the monolithic status of waste
EN ISO 16703:2011 Soil quality - Determination of content of hydrocarbon in the range C10 to C40 by gas chromatography (ISO 16703:2004)
CEN/TS 16800:2015 Guideline for the validation of physico-chemical analytical methods
EN ISO 17184:2014 Soil quality - Determination of carbon and nitrogen by near-infrared spectrometry (NIRS) (ISO 17184:2014)
EN ISO 17380:2013 Soil quality - Determination of total cyanide and easily liberatable cyanide - Continuous-flow analysis method (ISO 17380:2013)
EN ISO 18772:2014 Soil quality - Guidance on leaching procedures for subsequent chemical and ecotoxicological testing of soils and soil materials (ISO 18772:2008)
EN ISO 20963:2011 Soil quality - Effects of pollutants on insect larvae (Oxythyrea funesta) - Determination of acute toxicity (ISO 20963:2005)
CEN ISO/TS 21268-1:2009 Soil quality - Leaching procedures for subsequent chemical and ecotoxicological testing of soil and soil materials - Part 1: Batch test using a liquid to solid ratio of 2 l/kg dry matter (ISO/TS 21268-1:2007)
CEN ISO/TS 21268-2:2009 Soil quality - Leaching procedures for subsequent chemical and ecotoxicological testing of soil and soil materials - Part 2: Batch test using a liquid to solid ratio of 10 l/kg dry matter (ISO/TS 21268-2:2007)
CEN ISO/TS 21268-3:2009 Soil quality - Leaching procedures for subsequent chemical and ecotoxicological testing of soil and soil materials - Part 3: Up-flow percolation test (ISO/TS 21268-3:2007)
CEN ISO/TS 21268-4:2009 Soil quality - Leaching procedures for subsequent chemical and ecotoxicological testing of soil and soil materials - Part 4: Influence of pH on leaching with initial acid/base addition (ISO/TS 21268-4:2007)
EN ISO 22030:2011 Soil quality - Biological methods - Chronic toxicity in higher plants (ISO 22030:2005)
EN ISO 22155:2016 Soil quality - Gas chromatographic determination of volatile aromatic and halogenated hydrocarbons and selected ethers - Static headspace method (ISO 22155:2016)
EN ISO 22892:2011 Soil quality - Guidelines for the identification of target compounds by gas chromatography and mass spectrometry (ISO 22892:2006)
EN ISO 23470:2011 Soil quality - Determination of effective cation exchange capacity (CEC) and exchangeable cations using a hexamminecobalt trichloride solution (ISO 23470:2007)
EN ISO 23611-1:2011 Soil quality - Sampling of soil invertebrates - Part 1: Hand-sorting and formalin extraction of earthworms (ISO 23611-1:2006)
EN ISO 23611-2:2011 Soil quality - Sampling of soil invertebrates - Part 2: Sampling and extraction of micro-arthropods (Collembola and Acarina) (ISO 23611-2:2006)
EN ISO 23611-3:2011 Soil quality - Sampling of soil invertebrates - Part 3: Sampling and soil extraction of enchytraeids (ISO 23611-3:2007)
EN ISO 23611-4:2011 Soil quality - Sampling of soil invertebrates - Part 4: Sampling* extraction and identification of soil-inhabiting nematodes (ISO 23611-4:2007)
EN ISO 23611-5:2013 Soil quality - Sampling of soil invertebrates - Part 5: Sampling and extraction of soil macro-invertebrates (ISO 23611-5:2011)
EN ISO 23611-6:2013 Soil quality - Sampling of soil invertebrates - Part 6: Guidance for the design of sampling programmes with soil invertebrates (ISO 23611-6:2012)
EN ISO 23753-1:2011 Soil Quality - Determination of dehydrogenase activity in soil - Part 1: Method using triphenyltetrazolium chloride (TTC) (ISO 23753-1:2005)
EN ISO 23753-2:2011 Soil Quality - Determination of dehydrogenase activity in soils - Part 2: Method using iodotetrazolium chloride (INT) (ISO 23753-2:2005)
CEN ISO/TS 29843-1:2014 Soil quality - Determination of soil microbial diversity - Part 1: Method by phospholipid fatty acid analysis (PLFA) and phospholipid ether lipids (PLEL) analysis (ISO/TS 29843-1:2010)
CEN ISO/TS 29843-2:2014 Soil quality - Determination of soil microbial diversity - Part 2: Method by phospholipid fatty acid analysis (PLFA) using the simple PLFA extraction method (ISO/TS 29843-2:2011* Corrected version 2012-02-01)
missing are:
links:
or
