Page 1 of 2 1 2 LastLast
Results 1 to 12 of 20
Thread: CEN Standards Collection 16/370: EC ISS TC 105 - Steels For Heat Treatment....
    3 valid editions are missing
    EN ISO 4957:1999 Tool steels (ISO 4957:1999)
    EN ISO 683-17:1999 Heat-treated steels, alloy steels and free-cutting steels - Part 17: Ball and roller bearing steels (ISO 683-17:1999)
    EN ISO 9444-2:2010 Continuously hot-rolled stainless steel - Tolerances on dimensions and form - Part 2: Wide strip and sheet/plate (ISO 9444-2:2009)
    EN ISO 9445-1:2010 Continuously cold-rolled stainless steel - Tolerances on dimensions and form - Part 1: Narrow strip and cut lengths (ISO 9445-1:2009)
    EN ISO 9445-2:2010 Continuously cold-rolled stainless steel - Tolerances on dimensions and form - Part 2: Wide strip and plate/sheet (ISO 9445-2:2009)
    EN 10083-1:2006 Steels for quenching and tempering - Part 1: General technical delivery conditions
    EN 10083-2:2006 Steels for quenching and tempering - Part 2: Technical delivery conditions for non alloy steels
    EN 10083-3:2006 Steels for quenching and tempering - Part 3: Technical delivery conditions for alloy steels
    EN 10083-3:2006/AC:2008 Steels for quenching and tempering - Part 3: Technical delivery conditions for alloy steels
    EN 10084:2008 Case hardening steels - Technical delivery conditions
    EN 10085:2001 Nitriding steels - Technical delivery conditions
    EN 10087:1998 Free-cutting steels - Technical delivery conditions for semi-finished products, hot-rolled bars and rods
    EN 10088-1:2014 Stainless steels - Part 1: List of stainless steels - missing VE
    EN 10088-2:2014 Stainless steels - Part 2: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for general purposes - missing VE
    EN 10088-3:2014 Stainless steels - Part 3: Technical delivery conditions for semi-finished products, bars, rods, wire, sections and bright products of corrosion resisting steels for general purposes - missing VE
    EN 10088-4:2009 Stainless steels - Part 4: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for construction purposes
    EN 10088-5:2009 Stainless steels - Part 5: Technical delivery conditions for bars, rods, wire, sections and bright products of corrosion resisting steels for construction purposes
    EN 10089:2002 Hot-rolled steels for quenched and tempered springs - Technical delivery conditions
    EN 10090:1998 Valve steels and alloys for internal combustion engines
    EN 10095:1999 Heat resisting steels and nickel alloys
    EN 10132-1:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 1: General
    EN 10132-2:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 2: Case hardening steels
    EN 10132-3:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 3: Steels for quenching and tempering
    EN 10132-4:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 4: Spring steels and other applications
    EN 10132-4:2000/AC:2002 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 4: Spring steels and other applications
    EN 10151:2002 Stainless steel strip for springs - Technical delivery conditions
    EN 10221:1995 Surface quality classes for hot-rolled bars and rods - Technical delivery conditions
    EN 10267:1998 Ferritic-pearlitic steels for precipitation hardening from hot-working temperatures
    EN 10277-1:2008 Bright steel products - Technical delivery conditions - Part 1: General
    EN 10277-2:2008 Bright steel products - Technical delivery conditions - Part 2: Steels for general engineering purposes
    EN 10277-3:2008 Bright steel products - Technical delivery conditions - Part 3: Free-cutting steels
    EN 10277-4:2008 Bright steel products - Technical delivery conditions - Part 4: Case hardening steels
    EN 10277-5:2008 Bright steel products - Technical delivery conditions - Part 5: Steels for quenching and tempering
    EN 10278:1999 Dimensions and tolerances of bright steel products
    EN 10302:2008 Creep resisting steels, nickel and cobalt alloys
    EN 10343:2009 Steels for quenching and tempering for construction purposes - Technical delivery conditions
    EN ISO 18286:2010 Hot-rolled stainless steel plates - Tolerances on dimensions and shape (ISO 18286:2008)
    or
    Re: CEN standards collection 16/100: EC ISS TC 105 - Steels For Heat Treatment....
    2 updated, only one valid edition missing:
    new links :
    or
    Dear borntosin,
    pls share ISO 9227, ISO 3651-1, ISO 3651-2, ISO 1463, ISO 3754, ISO 2639 LATEST STANDARDS
    THANKS IN ADVANCE
    tHANKING YOU
    BALAG
    Dear borntosin,
    THANKS IN ADVANCE
    tHANKING YOU
    BALAG
    ISO 9227 - shared under the CEN - Paints & Varnishes
    ISO 3651-1 & 2 - shared under CEN - Test methods for steels other than chemical analysis
    ISO 1463 - will share it later today or tomorrow
    ISO 3754 - VE is from 1976...dont have that standard, sorry
    ISO 2639 - also shared under CEN - Test methods for steels other than chemical analysis
    now it's complete...and one standard changed form GER to EN version
    or
    Quote Originally Posted by BornToSin View Post
    or
    hugefiles is down; mediafire partly down so no Access. Please upload again, thank you,
    explosion
    Heaven didn't want me ...
    And Hell 's afraid I'm takin' over !
    new links:
  13. Re: CEN standards collection 16/100: EC ISS TC 105 - Steels For Heat Treatment....
    Dear BornTosin
    can you post any of the below?
    TC 219 cathodic protection
    Fi Fi related
    TC 70
    TC 92
    TC 127
    TC 191
    TC 192
    any help pls?
    Thks in advance
    mike pehli
  14. #11
    do the search....2 sectors you requested are posted already...for the rest, if I have that standards and when I get some time I will post it...
  16. #12
    updated with better quality of some standards...new links:
  1. Replies: 30
    Last Post: 07-26-2019, 02:19 PM
  2. Replies: 6
    Last Post: 05-09-2018, 11:42 AM
  3. CEN Standards Collection 34/370: CEN TC 131 - Heat Exchangers
    Last Post: 11-21-2017, 07:06 PM
  4. Replies: 14
    Last Post: 11-19-2017, 07:14 PM
  5. Replies: 0
    Last Post: 10-14-2015, 06:09 PM
