Page 2 of 2 FirstFirst 1 2
Results 13 to 21 of 21
Thread: API 579-1 / ASME FFS-1 Fitness-For-Service
  1. Thanks Nabilia, you are very kind.
  3. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    Dear Nabilia;
    Could you please reup these files? Many thanks.
    Quote Originally Posted by Nabilia View Post
    API Standard 579-1/ASME FFS-1 2nd Ed. June 2007 - Fitness-For-Service
    API Standard 579-1/ASME FFS-1, JUNE 5, 2007 (API 579 2nd Ed.) Errata February 2009 - Fitness-For-Service
    API Standard 579-2/ASME FFS-2 2009 Aug. 2009 - Fitness-For-Service Example Problem Manual
  5. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    new API Documents ...
    # Document Number Date Title
    1. API STD 603 [28 Page(s)] API STD 603
    2013.02.01 Corrosion-resistant, Bolted Bonnet Gate Valves—Flanged and Butt-welding Ends - EIGHTH EDITION
    2. API MPMS 21.1 [104 Page(s)] API MPMS 21.1
    2013.02.01 Manual of Petroleum Measurement Standards Chapter 21.1 - Flow Measurement Using Electronic Metering Systems - Electronic Gas Measurement - Second Edition
    3. API SPEC 4F [62 Page(s)] API SPEC 4F
    2013.01.01 Specification for Drilling and Well Servicing Structures - Fouth Edition; EFFECTIVE DATE: AUGUST 1, 2013
    4. API STD 599 [28 Page(s)] API STD 599
    2013.01.01 Metal Plug Valves—Flanged, Threaded and Welding Ends - SEVENTH EDITION
    5. API RP 1114 [58 Page(s)] API RP 1114
    2013.01.01 Recommended Practice for the Design of Solution-Mined Underground Storage Facilities - Second Edition
    6. API MPMS 20.3 [90 Page(s)] API MPMS 20.3
    2013.01.01 Manual of Petroleum Measurement Standards Chapter 20.3 Measurement of Multiphase Flow - First Edition
    7. API MPMS 20.1 [78 Page(s)] API MPMS 20.1
    2013.01.01 Manual of Petroleum Measurement Standards Chapter 20 - Allocation Measurement Section 1 - Allocation Measurement - First Edition
    8. API RP 85 ADD [2 Page(s)] API RP 85 ADD
    2013.01.01 Use of Subsea Wet-gas Flowmeters in Allocation Measurement Systems - First Edition
    9. API RP 17P [80 Page(s)] API RP 17P
    2013.01.01 Design and Operation of Subsea Production Systems - Subsea Structures and Manifolds - First Edition; ISO 13628-15:2011 Adoption
    10. API MPMS 20.1 ADD [1 Page(s)] API MPMS 20.1 ADD
    11. API RP 500 [162 Page(s)] API RP 500
    2012.12.01 Recommended Practice for Classification of Locations for Electrical Installations at Petroleum Facilities Classified as Class I, Division 1 and Division 2 - Third Edition
    12. API SPEC 5L [192 Page(s)] API SPEC 5L
    2012.12.01 Specification for Line Pipe - FORTY-FIFTH EDITION; EFFECTIVE DATE: JULY 1, 2013
    13. API MPMS 9.3 [20 Page(s)] API MPMS 9.3
    2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.3 Standard Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermohydrometer Method - Third Edition
    14. API MPMS 9.1 [18 Page(s)] API MPMS 9.1
    2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.1 - Standard Test Method for Density, Relative Density, or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method - Third Edition
    15. API MPMS 9.2 [16 Page(s)] API MPMS 9.2
    2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.2 Standard Test Method for Density or Relative Density of Light Hydrocarbons by Pressure Hydrometer- Measurement Coordination - Third Edition
    16. API STD 53 [124 Page(s)] API STD 53
    2012.11.01 Blowout Prevention Equipment Systems for Drilling Wells - Fourth Edition
    17. API STD 675 [74 Page(s)] API STD 675
    2012.11.01 Positive Displacement Pumps - Controlled Volume for Petroleum, Chemical, and Gas Industry Services - Third Edition
    18. API STD 608 [28 Page(s)] API STD 608
    2012.11.01 Metal Ball Valves - Flanged, Threaded, and Welding Ends - FIFTH EDITION
    19. Not part of your company subscription. Click the icon to order a personal copy. API RP 5L2 RUSSIAN
    2012.10.11 Recommended Practice for Internal Coating of Line Pipe for Non-Corrosive Gas Transmission Service - Fourth Edition
    20. API RP 1595 [88 Page(s)] API RP 1595
    2012.10.01 Design, Construction, Operation, Maintenance, and Inspection of Aviation Pre-Airfield Storage Terminals - SECOND EDITION
    21. API RP 553 [122 Page(s)] API RP 553
    2012.10.01 Refinery Valves and Accessories for Control and Safety Instrumented Systems - Second Edition
    22. API SPEC 11AX ADD 2 CHINESE [1 Page(s)] API SPEC 11AX ADD 2 CHINESE
    2012.10.01 Specification for Subsurface Sucker Rod Pumps and Fittings - Twelfth Edition
    23. API RP 11S8 [28 Page(s)] API RP 11S8
    2012.10.01 Recommended Practice on Electric Submersible System Vibrations - Second Edition
    24. API API STD 6DX [63 Page(s)] API API STD 6DX
    2012.10.01 Petroleum and natural gas industries—Mechanical integrity and sizing of actuators and mounting kits for pipeline valves - First Edition
    25. API MPMS 19.4 [148 Page(s)] API MPMS 19.4
    2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.4 Evaporative Loss Reference Information and Speciation Methodology - Third Edition
    26. API SPEC 6D ADD 3 CHINESE [16 Page(s)] API SPEC 6D ADD 3 CHINESE
    2012.10.01 Specification for Pipeline Valves - Twenty-Third Edition; Effective date: April 1,2013
    27. API MPMS 19.1 [38 Page(s)] API MPMS 19.1
    2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.1 Evaporative Loss From Fixed-Roof Tanks - Fourth Edition
    28. API MPMS 19.2 [98 Page(s)] API MPMS 19.2
    2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.2 Evaporative Loss From Floating-Roof Tanks - Third Edition
    29. API SPEC 5CT ERTA [15 Page(s)] API SPEC 5CT ERTA
    2012.09.01 Specification for Casing and Tubing - NINTH EDITION
    30. API MPMS 14.3.1 [68 Page(s)] API MPMS 14.3.1
    2012.09.01 Orifice Metering of Natural Gas and Other Related Hydrocarbon Fluids - Concentric, Square-edged Orifice Meters Part 1: General Equations and Uncertainty Guidelines - FOURTH EDITION
    31. API SPEC 20E [30 Page(s)] API SPEC 20E
    2012.08.01 Alloy and Carbon Steel Bolting for Use in the Petroleum and Natural Gas Industries - FIRST EDITION
    32. API COMPOSITE LIST [1028 Page(s)] API COMPOSITE LIST
    2012.07.01 The API Composite List
    33. API STD 2350 [58 Page(s)] API STD 2350
    2012.05.01 Overfill Protection for Storage Tanks in Petroleum Facilities - Fourth Edition
    34. API RP 6DR [22 Page(s)] API RP 6DR
    2012.05.01 Recommended Practice for the Repair and Remanufacture of Pipeline Valves - Second Edition
    35. API MPMS 17.9 [34 Page(s)] API MPMS 17.9
    2012.05.01 Manual of Petroleum Measurement Standards Chapter 17 El Hydrocarbon Management HM 49 Marine Measurement Section 9—Vessel Experience Factor (VEF) - Second Edition
    36. API SPEC 8C [66 Page(s)] API SPEC 8C
    2012.04.01 Drilling and Production Hoisting Equipment (PSL 1 and PSL 2) - Fifth Edition
    37. API RP 4G [68 Page(s)] API RP 4G
    2012.04.01 Operation, Inspection, Maintenance, and Repair of Drilling and Well Servicing Structures - Fourth Edition
    38. API RP 2001 [86 Page(s)] API RP 2001
    2012.04.01 Fire Protection in Refineries - Ninth Edition
    39. API MPMS 12.1.1 [52 Page(s)] API MPMS 12.1.1
    2012.04.01 Manual of Petroleum Measurement Standards Chapter 12.1.1—Calculation of Static Petroleum Quantities—Upright Cylindrical Tanks and Marine Vessels - Third Edition
    40. API RP 688 [550 Page(s)] API RP 688
    2012.04.01 Pulsation and Vibration Control in Positive Displacement Machinery Systems for Petroleum, Petrochemical, and Natural Gas Industry Services - First Edition
    41. API SPEC 8C CHINESE [69 Page(s)] API SPEC 8C CHINESE
    42. API RP 1161 [106 Page(s)] API RP 1161
    2012.04.01 Recommended Practice for Pipeline Operator Qualification (OQ) - Second Edition; Addendum 1: January 2013
    43. API MPMS 14.7 [18 Page(s)] API MPMS 14.7
    2012.04.01 Manual of Petroleum Measurement Standards Chapter 14.7 - Mass Measurement of Natural Gas Liquids - Fourth Edition
    44. API MPMS 17.5 [51 Page(s)] API MPMS 17.5
    2012.04.01 Manual of Petroleum Measurement Standards Chapter 17.5 - El Hydrocarbon Management - HM 64 - Guidelines for Voyage Analysis and Reconciliation of Cargo Quantities - Third Edition; Includes Access to Additional Content
    45. API SPEC 2C [136 Page(s)] API SPEC 2C
    2012.03.01 Offshore Pedestal-mounted Cranes - Seventh Edition
    46. API OCCUPATIONAL INJURIES [27 Page(s)] API OCCUPATIONAL INJURIES
    2012.03.01 2011 Survey of Occupational Injuries, Illnesses, and Fatalities in the Petroleum Industry Summary Report Aggregate Data Only
    47. API SPEC 20A [42 Page(s)] API SPEC 20A
    2012.03.01 Carbon Steel, Alloy Steel, Stainless Steel, and Nickel Base Alloy Castings for Use in the Petroleum and Natural Gas Industry - First Edition
    48. API RP 932-B [54 Page(s)] API RP 932-B
    2012.03.01 Design, Materials, Fabrication, Operation, and Inspection Guidelines for Corrosion Control in Hydroprocessing Reactor Effluent Air Cooler (REAC) Systems - Second Edition
    49. API SPEC 2C CHINESE [142 Page(s)] API SPEC 2C CHINESE
    50. API TR 17TR6 [54 Page(s)] API TR 17TR6
    2012.03.01 Attributes of Production Chemicals in Subsea Production Systems - First Edition
    51. API TR 17TR5 [54 Page(s)] API TR 17TR5
    2012.03.01 Avoidance of Blockages in Subsea Production Control and Chemical Injection Systems - First Edition
    52. API RP 5LT [16 Page(s)] API RP 5LT
    2012.03.01 Recommended Practice for Truck Transportation of Line Pipe - First Edition
    53. API STD 653 ADD 2 CHINESE [106 Page(s)] API STD 653 ADD 2 CHINESE
    2012.01.01 Tank Inspection, Repair, Alteration, and Reconstruction - Fourth Edition; Includes Addendum 1: 8/2010
    54. API SPEC 17D ERTA 2 [3 Page(s)] API SPEC 17D ERTA 2
    2012.01.01 Design and Operation of Subsea Production Systems-Subsea Wellhead and Tree Equipment - Second Edition
    55. API TR 17TR4 [16 Page(s)] API TR 17TR4
    2012.01.01 Subsea Equipment Pressure Ratings - First Edition
    56. API SPEC Q2 [36 Page(s)] API SPEC Q2
    2011.12.01 Specification for Quality Management System Requirements for Service Supply Organizations for the Petroleum and Natural Gas Industries - First Edition
    57. API SPEC Q2 CHINESE [36 Page(s)] API SPEC Q2 CHINESE
    58. API MPMS 5.8 [38 Page(s)] API MPMS 5.8
    2011.11.01 Manual of Petroluem Measurement Standards Chapter 5.8 Measurement of Liquid Hydrocarbons by Ultrasonic Flow Meters - Second Edition
    59. API MPMS 4.5 [26 Page(s)] API MPMS 4.5
    2011.11.01 Manual of Petroleum Measurement Standards Chapter 4.5 Master Meter Provers - Third Edition
    60. API SPEC 6A ADD 1 CHINESE [11 Page(s)] API SPEC 6A ADD 1 CHINESE
    2011.11.01 Specification for Wellhead and Christmas Tree Equipment - Twentieth Edition; Incorporates Errata: 11/2011
    61. API RP 2FPS [208 Page(s)] API RP 2FPS
    2011.10.01 Planning, Designing, and Constructing Floating Production Systems - SECOND EDITION
    62. API RP 9B [44 Page(s)] API RP 9B
    2011.10.01 Application, Care, and Use of Wire Rope for Oil Field Service - THIRTEENTH EDITION; INCORPORATED ERRATA:APRIL 2012; ERRATA: January 2013
    63. API STD 2220 [38 Page(s)] API STD 2220
    2011.10.01 Contractor Safety Performance Process - Third Edition
    64. API RP 2221 [100 Page(s)] API RP 2221
    2011.10.01 Contractor and Owner Safety Program Implementation - Third Edition
    65. API MPMS 7.3 [42 Page(s)] API MPMS 7.3
    2011.10.01 Manual of Petroleum Measurement Standards Chapter 7.3 Temperature Determination—Fixed Automatic Tank Temperature Systems - SECOND EDITION
    66. API MPMS 7 ADD 1 [2 Page(s)] API MPMS 7 ADD 1
    2011.10.01 Manual of Petroleum Measurement Standards Chapter 7 - Temperature Determination - First Edition
    67. API STD 622 [42 Page(s)] API STD 622
    2011.10.01 Type Testing of Process Valve Packing for Fugitive Emissions - Second Edition
    68. API MPMS 11.2.4 ERTA [1 Page(s)] API MPMS 11.2.4 ERTA
    2011.09.01 Manual of Petroleum Measurement Standards Chapter 11—Physical Properties Data Section 2, Part 4—Temperature Correction for the Volume of NGL and LPG Tables 23E, 24E, 53E, 54E, 59E, and 60E - First Edition
    69. API MPMS 11.4.1 ERTA [1 Page(s)] API MPMS 11.4.1 ERTA
    2011.09.01 Manual of Petroleum Measurement Standards Chapter 11—Physical Properties Data Section 4—Properties of Reference Materials Part 1—Density of Water and Water Volumetric Correction Factors for Water Calibration of Volumetric Provers - First Edition
    70. API PUBL 4776 [72 Page(s)] API PUBL 4776
    2011.09.01 A Guide to Understanding, Assessment, and Regulation of PAHs in the Aquatic Environment
    71. API SPEC 6D ADD 2 CHINESE [15 Page(s)] API SPEC 6D ADD 2 CHINESE
    2011.08.01 Specification for Pipeline Valves - Twenty-Third Edition; Incorporates Errata 6: 8/2011
    72. API SPEC 5CT [284 Page(s)] API SPEC 5CT
    2011.07.01 Specification for Casing and Tubing - NINTH EDITION
    73. API SPEC 5CT CHINESE [321 Page(s)] API SPEC 5CT CHINESE
    2011.07.01 Specification for Casing and Tubing - Ninth Edition; Incorporates Errata: September 2012
    74. API MPMS 11.3.3 [28 Page(s)] API MPMS 11.3.3
    2011.07.01 Manual of Petroleum Measurement Standards Chapter 11.3.3 Miscellaneous Hydrocarbon Product Properties - Ethanol Density and Volume Correction Factors - First Edition
    75. API RP 2611 [54 Page(s)] API RP 2611
    2011.06.01 Terminal Piping Inspection— Inspection of In-Service Terminal Piping Systems - First Edition
    76. API RP 19G4 [62 Page(s)] API RP 19G4
    2011.06.01 Practices for Side-pocket Mandrels and Related Equipment - FIRST EDITION; ISO 17078-4:2010 Adoption
    77. API SPEC 19G3 [58 Page(s)] API SPEC 19G3
    2011.06.01 Running Tools, Pulling Tools, and Kick-over Tools and Latches for Side-pocket Mandrels - FIRST EDITION; ISO 17078-3:2009 Adoption
    78. API SPEC 17D [272 Page(s)] API SPEC 17D
    2011.05.01 Design and Operation of Subsea Production Systems-Subsea Wellhead and Tree Equipment - Second Edition; Incorporating Errata: September 2011; ISO 13628-4 Adoption; Effective February 1, 2013 [for Valve and Actuator Design Validation (Test Requirements) Only]
    79. API SPEC 9A [72 Page(s)] API SPEC 9A
    2011.05.01 Specification for Wire Rope - Twenty-Sixth Edition; Incorporating Errata: October, 2012
    80. API RP 13K [66 Page(s)] API RP 13K
    2011.05.01 Recommended Practice for Chemical Analysis of Barite - Third Edition
    81. API RP 13K RUSSIAN [66 Page(s)] API RP 13K RUSSIAN
    2011.05.01 RECOMMENDED PRACTICE FOR CHEMICAL ANALYSIS OF BARITE - Third Edition
    82. API SPEC 9A CHINESE [83 Page(s)] API SPEC 9A CHINESE
    2011.05.01 Specification for Wire Rope - Twenty-sixth Edition
    83. API SPEC 17D CHINESE [272 Page(s)] API SPEC 17D CHINESE
    84. API SPEC 17D ERTA 2 CHINESE [3 Page(s)] API SPEC 17D ERTA 2 CHINESE
    85. API TR 938-C [58 Page(s)] API TR 938-C
    2011.04.01 Use of Duplex Stainless Steels in the Oil Refining Industry - Second Edition
    86. API BULL D16 [75 Page(s)] API BULL D16
    2011.04.01 Suggested Procedure for Development of a Spill Prevention Control and Countermeasure Plan - Fifth Edition
    87. API RP 571 [372 Page(s)] API RP 571
    2011.04.01 Damage Mechanisms Affecting Fixed Equipment in the Refining Industry - Second Edition
    88. API RP 1615 [106 Page(s)] API RP 1615
    2011.04.01 Installation of Underground Petroleum Storage Systems - Sixth Edition
    89. API TR 934-B [42 Page(s)] API TR 934-B
    2011.04.01 Fabrication Considerations for Vanadium-Modified Cr-Mo Steel Heavy Wall Pressure Vessels - First Edition
    90. API RP 556 [78 Page(s)] API RP 556
    2011.04.01 Instrumentation, Control, and Protective Systems for Gas Fired Heaters - Second Edition
    91. API RP 2GEO [120 Page(s)] API RP 2GEO
    2011.04.01 Geotechnical and Foundation Design Considerations - First Edition; ISO 19901-4:2003 Adoption
    92. API BULL D16 TEMPLATE [88 Page(s)] API BULL D16 TEMPLATE
    2011.04.01 Suggested Procedure for Development of Spill Prevention Control and Countermeasure Plans - Plan Template - Fifth Edition
    93. API RP 556 RUSSIAN [140 Page(s)] API RP 556 RUSSIAN
    94. API TR 2571 [82 Page(s)] API TR 2571
    2011.03.01 Fuel Gas Measurement - First Edition
    95. API STD 685 [186 Page(s)] API STD 685
    2011.02.01 Sealless Centrifugal Pumps for Petroleum, Petrochemical, and Gas Industry Process Service - SECOND EDITION
    96. API STD 616 [180 Page(s)] API STD 616
    2011.01.01 Gas Turbines for Petroleum, Chemical, and Gas Industry Services - Fifth Edition
    97. API HF3 [34 Page(s)] API HF3
    2011.01.01 Practices for Mitigating Surface Impacts Associated with Hydraulic Fracturing - First Edition
    98. API SPEC 10A [52 Page(s)] API SPEC 10A
    2010.12.01 Specification for Cements and Materials for Well Cementing - Twenty-Fourth Edition
    99. API SPEC 7-2 ADD 1 [46 Page(s)] API SPEC 7-2 ADD 1
    2010.12.01 Specification for Threading and Gauging of Rotary Shouldered Thread Connections - First Edition; ISO 10424-2:2007 Adoption; Effective Date: June 2011
    100. API RP 17A ADD 1 [18 Page(s)] API RP 17A ADD 1
    2010.12.01 Design and Operation of Subsea Production Systems—General Requirements and Recommendations - Fourth Edition; ISO 13628-1:2005 Adoption
  6. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    Dear all,
    Anyone could post New downloading link.
  7. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    The link is dead. Could you please re-upload ?
  9. #18
    Can anyone please provide this? Thank you in advance for your help.
  10. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    Hi Nabilia,
    Is it possible to share "API Standard 579-1/ASME FFS-1 2nd Ed. June 2007 - Fitness-For-Service" again? Thanks.
  11. #20
    Hi everyone,
    Here is the 2007 for you.
  12. Re: API 579-1 / ASME FFS-1 Fitness-For-Service
    Thanks man! I appreciate that! Cheers! o/
  1. Fitness for Service
    By Nabili in forum Petroleum Refining
    Last Post: 05-21-2024, 02:27 AM
  2. API 579 - Fitness-For-Service
    By Gasflo in forum Mechanical Engineering
    Last Post: 08-24-2018, 01:20 PM
  3. Fitness For Service
    Last Post: 10-13-2015, 01:00 PM
  4. API 579 Fitness for service
    By Jinny Varkey in forum Pipeline And Fluid Flow
    Last Post: 07-19-2011, 07:23 PM
  5. Fitness for service
    By cosili in forum Materials Science &Corrosion
    Last Post: 02-20-2010, 09:28 PM
