Muzaffar84,
My computer is vista home premium Sp1 32 bit. I try it on another vista system pc, the result is same.
Thank you
Muzaffar84,
Thank you
Muzaffar84,
I try to install aspenone V7 in vista home premium 64 bit system. Everything is ok until to "microsoft SQL server 2005 compatibility". I saw in another thread that you met same issue. Could you tell me how did you solve it?
Thank you
Thank you guys for sharing. I am happily using V7 on my vista Home premium 32 bit seemlessly..
Simple solution to run software that doesn't work on VISTA is to use VMware Workstation. Simply install Windows XP through VMware then install the software you want. That's the only way i could run HYSYS for example and works like a charm.
P.S. Vmware creates a virtual machine that enables you to install any operating system without altering your current operating system (all system files of the virtual OS are stored in a single file that you can place anywhere on your HDD)
another free option of vmware is virtualbox ([link Point to another website Only the registered members can access]
I solved the problems and successfully installed v7 in vista system using the method in No 4 above. Specially thanks to Muzaffar84, Polaris44 and all sharing their experience here. Hope you guys work well on it too.
