I have defined CaCl2Brine properties as Hypo component (these were taken from DIPPR)
The purpose was to have an x3 effect evaporation unit; so I had Duhring chart to know that at what temperature; mixture of a specified w.t% CaCl2 will boil.
This binary plot was constructed using HYSYS (w.t%)
If you compare this with following Duhring plot
My PFD (using NRTL no BIPs)
You will see that HYSYS under-predicts BPE. For instance if my last effect is going to achieve 60w.t% of CaCl2 solution the temperature of that separator per Duhring is to be ~160C (ACTUALLY IT IS) but HYSYS predicts ~135C
My question is what property while defining Hypo effects this behaviour? How can I make binary plot somewhat closer to Duhring plot?
