Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 13 to 24 of 43
Thread: PVElite 2013
  1. #13
    Re: PVElite 2013
    2 ALL:
    Please share PVElite 2013 installer,THX.
    Re: PVElite 2013
    waiting*-----
    Muhammad Khurram
  5. Re: PVElite 2013
    Hi everybody,
    Please share me the link to down the Pvelite 2012 and the license.
    You can send the link into the following gmail:
    sonino001@gmail.com
    Thanks alot.
  6. #16
    Re: PVElite 2013
    Have anybody the serial to PV ELITE 2013??. I have found the installer but dont have the serial..
    Thaks a lot
  7. #17
    Re: PVElite 2013
    to : idea
    can you share the installer please
  9. #18
    solution Guest
    Re: PVElite 2013
    PV Elite® 2013
    New Features
    PV Elite® is a Windows (XP/Vista/7) based program. This version has been developed and tested on Windows 7, Windows XP and Windows Vista. PV Elite 2013 has not been tested under Windows 8.
    NOTES:
    Launching the program PVE.EXE starts PV Elite. This program’s internal version is: 15.00.00.000.
    Below is a listing of the new features in this year’s version. Many of the new features and improvements come directly from your comments. There have also been a number of new features that have been included in builds to the 2012 version during the last year which are now in this version.
    Code Updates and Analysis changes:
    • Some new Code updates are incorporated in this version. The updates includes:
    1. PD 5500 2012 Edition Incorporated.
    2. Tema 9th Edition
    3. API-579 2007 Edition, General Metal Loss
    Internationalization
    • PV Elite® can now work in multiple languages including:
    1. English
    2. French
    3. Spanish
    4. Portuguese
    5. Italian
    • The AS/NZ 2011 Wind Code was updated.
    Productivity Enhancements
    • All new Updated User Interface.
    1. Ribbon Style
    2. All new Icons (Large or Small)
    3. Different color Themes
    4. All programs revised for this change
    • Quick calculation Screen
    1. Text Highlight
    2. Search
    3. Select all and Copy all
    • Output Processor
    1. Report List Coloring
    2. Search and Highlight
    4. DXF and Rigging result directly available from the output program
    5. Drag and drop of reports in the report list
    • PV Elite now supports project templates.
    • CodeCalc has been completely re-written into a modern style application.
    • Graphics
    1. Color code by thickness, material, temperature etc.
    2. Lock Axis rotation
    3. 2D and 3D screen now separated
    • Printing
    1. Print directly to PDF
    2. Available in Input, Output, CodeCalc, Material Editor etc.
    • Material Databases can be sorted by column
    • New Analysis Features
    1. Integrated API 579 Part 4 General Metal Loss
    2. ASME VIII-1 Material Data 1943 through 1974
    3. PD 5500 Jacket Analysis
    4. PD 5500 Limpet Coil Analysis
    5. EN 13445 Limpet Coil Analysis
    6. ASME VIII-1 Fatigue Analysis updated (from latest Div. 2)
    7. PV Elite 2012 R1 Features included
    8. EN-13445 Exp Joints
    9. European Structural Steel
    10. EN-13445 Local Stress Analysis
    11. Improved Metric defaults
    12. Japanese Wind Code
    13. European Nozzle Load table
    14. ASME Stainless Steel MDMTs computed
    15. Complete Exchanger MDMTs Computed (tubesheets)
    16. MDMT table sorted for Shell side and Tube side results
    17. Use differential pressure for tube design
    18. Indian Earthquake Code, vertical acceleration component added
    19. Updated EN-13445 Materials Added
    QA/Validation and Verification
    • We continue to add new QA problems to the benchmark solution set.
    Please note that periodically fixes to the software will be posted to the web site at the location sited below. If you are having trouble with a particular calculation, check the Intergraph web site to see if there is a later version available that may fix your problem (also available from the PV Elite® help menu). You should always run the latest version of the software.
  10. Re: PVElite 2013
    how can i download this software?
  11. #20
    Re: PVElite 2013
    CAN ANYONE TELL ME HOW TO PVELITE 2008 OR 2010 WORK ON WIN7 SP1 64BIT?
    MRBEEN
    mrbeen789@gmila.com
  12. #21
    Re: PVElite 2013
    I can upload Pvelite 2013 (963 MB) and cadworx 2013 (726 MB) free just whether somebody share me caesar II 2013 with k.....y.
    regards
  13. Re: PVElite 2013
    Hi friend
    I just came back, I have Caesar II 2013 with -----.
    If you want
    PM me
    regards
    Quote Originally Posted by kohkin View Post
    regards
  14. #23
    Re: PVElite 2013
    this c..... doesn't work.
    regards
  16. Question Re: PVElite 2013
    Hello,
    Do any one have a working PV elite 2013 ******?
  1. The Way To Use PVELITE 2013 ON Window 7- 64bit
    By m.boka in forum Mechanical Engineering
    Last Post: 11-10-2014, 09:54 AM
  2. PVElite 2013
    By cadcae in forum Mechanical Engineering
    Last Post: 12-10-2013, 05:59 AM
  3. PVElite 2013
    By CCCP in forum Mechanical Engineering
    Last Post: 07-02-2013, 02:10 PM
