if you are going to run simulation, your permeability should be tunned to the measured average effective permeabilty values from well test. Effectively you are simulating the flow conditions which is measured in pressure transient analysis. Log or Core permeabilities can be very different than well test one, so you should make good stories to justify the difference as well. Good luck
