Page 2 of 2 FirstFirst 1 2
Results 13 to 16 of 16
Thread: Internal pressure and external pressure in pressure vessel
  1. #13
    why dont use EN (BS)'es? 13445 ? there IS a lot of pressures in vessels inthere..
    Oct 2008
    The Netherlands
    Blog Entries
    14
    The question was
    Quote Originally Posted by ekosusilo View Post
    No i'm a piping engineer, but now i should design tank with diameter 9m and high 13.5, the client want the tank based on ASME Sec VIII Div.1. I already read the ASME Sec VIII Div.1, except the wind and seismic, maybe the high also should be the consideration? or there is a high limitation to determining the pressure?
    I have refered to Bednar Book = Pressure vessel Handbook
    See attachment for some extracts of that book
    Thanks,
    Echo
    Now Mr. Duazo2009 said
    You Don't know what you're talking about..in designing a pressure vessels, design ,pressure and temperature should not be assumed.. in a certain equipment operating pressure and temperature are always given and there's a formula to calculate the design pressure and temperature, you have to clarify what kind of pressure is it whether it absolute pressure or gauge pressure... the way you're are expalaining,
    my answer = you miss my point , I was talking about another face of the problem, e.g = Loads, pressure , seismic , weight..and how to combine them , also telling that API is not suitable here
    it seems that you don't know how to design...
    my answer = I am 55 years old , spend more 20 years doing vessels , tanks , pipe stress etc for Shell , Exxon and Lloyds (Design assessment and approval ) and I am also ...for your information an ASME member since 1987 , I guess you were at school at that time.
    Do you think I could stay in the business without being able to do it ... ,
    Now, if you want to teach people as you pretend , first do not attack them , and please remain polite and respectfull , do not take things personal , we are here to learn from each other , nothing more , so respect the others and stop answering me
    and attacking me, In my faith only Allah can judge me , if you see me using a a wrong formula or a wrong drawing , simply correct me without personal attack
    that you are just refering to the entire codes but you don't know which section and paragraph it is found .. isn't it..
    my answer = see above , ...do you now me ? have we met ? have we worked together ? are you an asme member ? are you a cousin of Bednar or Moise ? have you published something ?have you heard then about ethics ? is this what they teach home ? are going to rise kids this way ? do you still have friends ? can you communicate with other people ?.. you see it is easy to attack when hiding behind a screen ?
    so my overall assesment regarding your reccomendation is absurd! and i repeat don't pretend that you know pressure vessel design..
    my answer = it is your righ to talk !! I have no pretention ,We are always learning ..and its nice to stay humble and modest ,thats all..
    then stop attacking , and respect the other .. End of discussion , please do not answer me anymore , but try to answer the thread and focus on helping by being more Constructive and proactive , and open to others ..and sorry to say = less agressive
    Take note: data sheet will be made after finalizing the design which is the results of your calculations.
    My answer = in the place where I am , first process data sheet is prepared ( With design condition , major dimensions, generic material ..) , then Mechanical data sheet is made with a basic drawing , showing major thinkness and loads ,.., then a requisition is prepared , the Vendor or manufacturer will make his own calculations and review all loads , he is responsible and liable for the mechanical design
    Is it different on your job ???
    anyway please focus on subject on not on the attacks , keep your energy positive and let people appreciate your collaboration .
    Now if interested = Start reading the attachment and then you may comment ...other nonsense I do not need it
    Attached Files Attached Files
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by FATHI View Post
    The question was
    Mr. Fathi.
    For your info.
    yes Mr. Fathi i am a member of ASME / PSME and a a reistered and Licensed Mechanical Engineer, the file you've attached here is extracted from a textbook only without any permission from the author / publisher to extract...no need to argue with you because the reality is, you really don't know.. you're just relying only in one textbook which has never and could not not be used as a reference in manual design calculation even in Compress and PV Elite software.. and to tell you frankly.. you don't know pressure vessel design.. i will be impressed if you would say that you're using a Pressure Vessel Handbook by: Eugene F. Magyesy as your reference... the way you answered it seems that you really don't know what you are talking about..
    P.S. don't let myself not to answer you because you're not my boss and even my superior... you're just an ordinary person who want to gain more information from others..
  6. #16
    Oct 2008
    The Netherlands
    Blog Entries
    14
    ..ok you 1000 % right
    this discussion is not constructive that way !!! ...
    After all life is much better than that we are both wasting our time in such childish game !!!
  1. Pressure Vessels External Pressure Technology (get book)
    By SHEMYY in forum Mechanical Engineering
    Last Post: 08-28-2015, 08:40 PM
  2. Max. External Pressure of Pressure Vessel's Shell/Head
    By Naya Din in forum Mechanical Engineering
    Last Post: 06-14-2014, 04:39 AM
  3. Pressure Vessel Internal Parts Material
    By Shamsul Ramli in forum Mechanical Engineering
    Last Post: 01-21-2014, 10:36 AM
  4. Half pipe jacketed vessel under external pressure
    By nalasoc in forum Mechanical Engineering
    Last Post: 06-29-2013, 09:02 PM
  5. ITP for internal pressure vessel inspection
    By rmx8000 in forum Materials Science &Corrosion
    Last Post: 11-02-2010, 02:37 PM
