Page 2 of 2 FirstFirst 1 2
Results 13 to 19 of 19
Thread: Hysys Vs ChemCad Vs Aspen plus Vs ProII
  1. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Quote Originally Posted by Reynold Panjaitan View Post
    Hello mr...!
    i have a little problem.
    i can't find a properties of fatty alcohol C12/14 when i try with hysis 3.1.
    I want to calculate how much the process variables for column destillation for fatty alcohol C12/14.
    1. Should I match with petroleum derivatives that same carbon chain?
    2. Or enter the value of the properties of fatty alcohol c12/14 handbook
    3. Or use other software like aspenplus
    In hysis is more about petroleum.
    So anybody can help me? Because my background in oleochemical. thank for your attention sir!
    Use AspenPlus. It has a complete database for fatty alcohols, including raw materials like methyl esters, fatty acids, and even wax esters
  3. Smile Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Thank you very much sir juncruz. I would first try aspen plus.
  5. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Thank u mkhurram79,
  6. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    I will suggest you to use Hysys. As it takes normally less time to understand at least I found it user-friendly. As I worked on all these three simulators. Hysys will be good choice to start any Project. While doing simulations if you find any problem or need any help please let us know. All the best.
    Chemcad is also usefull but now dont use.
  7. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Can someone provide CHEMCAD 6.3 with c***k.
  9. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    wich one is better with electrolytes? I´m triying to run a chlorine-soda simulation and I will like to know which one i must use.
    thanks in advance
  10. Re: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    thanks bros
  1. Draw Unit operation like HYSYS and PROII simulator
    By SIM2 in forum Engineering Programming
    Last Post: 02-03-2014, 07:48 PM
  2. Article: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    By mkhurram79 in forum Home Articles
    Last Post: 09-20-2011, 09:25 AM
  3. Article: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Last Post: 04-18-2011, 09:08 PM
