You are getting negative compressibilities... 1/Bg should always be positive
Is it purely gas model? If so, try extending the defined pressures significantly higher.. I've seen cases where some point cells having numerical convergence issues want to solve to a pressure higher than initialization, which if not covered in your PVT tables can cause the situation you are seeing.
Plot you 1/Bg's vs pressure and eyeball if they are smooth and continuous - if not, make them.
