Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: Convergence Problems
  1. Convergence Problems
    Hey all,
    I am facing a lot of convergence problems and I have no idea where can be the origin of these problems...
    I have about 135k cells, a couple of faults, i use corner point cells, 3 OWCs, 3phases (but with gas still dissolved because P > Pb).
    I left perm, poro and NTG homogenous for now to keep it simple...
    Then i introduced one well and let it produce for 1 month.
    When i start now the simulation, it takes a loooot of time, because eclipse is reducing the timestep due to the convergence problems...
    Even if i just simulate three days it takes a hell of a time... I played a little bit with the tuning keyword, but i guess the convergence probs are too big and they originate from somewhere else...
    I am totally new to eclipse, so i really dont know where to look ? What might be the problem for it ?
    If it is helpful i could post the "problem" "warning" and the convergence related messages...
    I appreciate any advice !
    Maybe it's related with the corner points. And how about the PVTs? Do you mention for each phase? 3 OWCs? To make more simple, put only one OWC. And look what happens next.
    And you can discuss with us afterwards.
  5. Yes i mentioned all of them PVDG, PVTO, PVTW... when i just define one OWC its way faster and no convergence problems so far... :/
    Dec 2007
    Novi Sad, Serbia
    This problem can be related to PVT... is it black or comp?
  7. black
    edit: sorry there are still convergence problems also with just one OWC,but not that much like before...
  9. ----
    Dec 2007
    Novi Sad, Serbia
    Check the PVO file .... it can often be a problem...how did you created it ? in PVTi or by correlations? The most often problem is that bubble point pressure in PVO must be equal to your maximum pressure.
  11. I did it by correlation...
    "The most often problem is that bubble point pressure in PVO must be equal to your maximum pressure. "
    You mean, that i should give eclipse just the correlated values up to Pb ??? I assume, that i got you wrong, because that doesn't make sense to me.
    OK...I went one step back and left my schedule section out and just initialized the model: I got several warning of this type:
    @ NEGATIVE COMPRESSIBILITY FOUND IN GAS
    @ PRESSURE TABLE 1 AND OIL PRESSURE
    @ TABLE 1 AT A SAMPLE PRESSURE VALUE
    @ 182.31034 . ADJUST SATURATED FLUID
    @ PROPERTY VALUES AT THIS PRESSURE.
    @ NEGATIVE COMPRESSIBILITIES OCCUR
    @ FOR GAS SATURATIONS LESS THAN 0.03998
    Obviously there is sth. wrong in my PVT data... any idea what is the reason for the "negative compressibility" ?
    Dec 2007
    Novi Sad, Serbia
    First of all your PMAX in the .data file should be the bubble point pressure in the PVO file...that's mean that you should increase Rs until you reach a bubble point pressure that equals your PMAX...
    You can use a small reservoir simulation trick, copy the compressibility data table (dBo/dP ,..) from the debug file into excel and try to change the Bo that cause a negative compressibility then change that value in .PVO..i will upload an excel file, i believe it will help you to solve the problem...
    Dec 2007
    Novi Sad, Serbia
    You can use this .xls file to correct your Bo
  14. #11
    Quote Originally Posted by ivan_aljeburi View Post
    thnx
    Muhammad Khurram
  16. thx a lot, but already got rid of the problem !!
    When i change PMAX to my Pb, then during my simulation the control mode of the wells is changed to BHP... Any idea how to solve that ?
    right now i am again messing around with convergence probs again... any idea on that ?
    @--PROBLEM AT TIME 4.0 DAYS ( 5-JAN-1988):
    @ SOLUTION IN WELL H19 NOT CONVERGED AFTER 14 ITERATIONS
    @ RESIDUAL ERROR IN OIL, WATER AND GAS FLOWS =
    @ 5.40361E+04 -1.04940E-09 9.30135E-04
    @ TRY INCREASING MXWSIT IN TUNING RECORD 3
  1. Eclipse Convergence problems
    By halim78 in forum Reservoir
    Last Post: 03-07-2014, 04:40 PM
  2. eclipse convergence problem
    By tinni in forum Reservoir
    Last Post: 06-28-2012, 02:56 AM
