Page 11 of 19 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 121 to 132 of 220
Thread: Petrel Step by Step
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Help
    Ok I am pondering should I learn Petrel for a simple 3D geological model simulation via Eclipse.
    The model consists of:
    A dome 3D anticline structure
    With 5 diff. layers
    What my team have done so far:
    The crude way of doing this is via eclipse data file which is to have a square block says dimension of 50 by 50 by 80 in DX,DY and DZ and "cut" the block from the outside and the inside to get our "dome or cone" shape using NTG 0 keyword.
    Obviously this is crude and only works for homogenous geo model and it is extremely difficult to populate the cell manually with different permeability and porosity consistent with geological layering.
    So far we have done a 2D model which is fairly easy since we used the TOPS keyword which automatically set-up the correct layer permeability and porosity since it is inclined.
    Now exporting this for 3D problem, do you guys reckon I can used Petrel in order to create this 3D model without seismic, petrophysical and other hard/soft data?
    Thanks for the help and tips.
  2. thanks very much sir, but i have a quiry regarding core date pertaining kx and Ky (PERMIBILITY) WHAT WE USE IN PETREL X OR Y OR AVERAGE?
  3.    Sponsored Links
  4. #3
    Jan 2009
    ALA, KZ
    Quote Originally Posted by ÃÈæ ÇáÚÈÇÓ View Post
    If you have full data you better to model x, y directions separately, but since the permeability is one of the match parameters during history match i would advise you to average x and y directions
  5. #4
    hello dear users. i need some information for Gaussian Random Function Simulation (GRFS) method. i see this method added in Petrel 2009 and see good result by using it
    please help me for recognize GRFS method
  6. #5
    downloaded thanks
  7.    Spons.
  8. #6
  9. in petrel can i ask petrel to present me k and Dz in A TABE for each well?
  10. #8
    You can do this by using Petrel RE:
    1. You'll be able to see Perm values under Models tab (Properties option), but you'll need to create DZ as a property, simply rigth click on Properties - Calculator - Name variable as DZ (or any name) - click on Geometry and select "Heitht () Height of the current cell". DZ property has been created.
    2. Creating Properties as a WellLog: go to Input tab, select Wells, right click and go to Make logs tab, select Perm and DZ and click on Make logs.
    3. Exporting well logs (Perm and DZ): under Input tab, rigth click on Wells once again, select "Export all well logs in folder". It's done.
  11. #9
    Re: Petrel Step by Step
  12. #10
    Temr, bro thanks for such a great piece of work.Highly appreciated as it helps alot to new guys in oil industry like myself alot. Eagerly waiting for next lessons. Thanks
  13. #11
    Jan 2009
    ALA, KZ
    Thanks for your words.
    People like you keep me running)
    Now i am developing my program so most of my efforts are going there
    So if anyone having specific question address them here and i will do my best to answer them
  14.    Spons.
  15. Re: Petrel Step by Step
    Hello,
    I need petrel 2010.1 c******-c-k only or Geoframe or , in return i have 1. Opendtect 4.2 license 2. petrel 2009 3.K-in-g-dom 4. interactive petrophysics 5.petromod 7.rep for reserve calculation 8. Hampson Russell . contect me greathelp2@gmail.com
  1. Replies: 11
  2. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
