Originally Posted by
polo44600
Hello all,
voici une "petite" partie de ma doc :
here, my documentations
si vous ètes interressé je peux uploader sur Rapidshare en Aout
if you want i can upload on Rapidshare in August
API 1102 Crossings
API 1104 Welding of Pipelines
API 2000 - Venting Tanks -April 1998
API 2534 Measurement - Turbine meter
API 2C Off shore cranes
API 520 PSV SIZING
API 527 PSV Seat Tightness
API 542 ELEC LOW VOLTAGE
API 543 ELEC MEDIUM VOLTAGE
API 544 5 to 15 kV Switchgear
API 560 Fired Heaters
API 598 Valve Inspection and Testing
API 5L Line Pipe Specifications
API 607 Firetest Soft Seat Quarter Turn Valves
API 610 - Centrifugal Pumps
API 611 General service - Steam Turbine
API 616 - Gas Turbines -August 1998
API 617 - Centrifugal compressors -April 1988
API 618 - Reciprocating Compressors 1995
API 620 Welded Storage Tanks
API 650 Welded Steel Tanks
API 653 Tank Inspection
API 660 Shell and Tube Exchangers
API 661 Air Cooled Exchangers
API 674 - PD Pumps -May 1980
API 675 - PD Pumps Controlled volume 1994
API 676 - PD Pumps - Rotary -December 1994
API 681 - Vacuum Pumps and Compressors 1996
API 6D Spec for Pipeline valves
API 6FA Firetest - Valves
API 6FC Firetest - Valves with Automatic Backseats
API 700 Checklist for Plant completion
API 750 Management of Process hazards
API 752 Hazards Plants and Buildings
API Catalog
API Publications
API RP 1110 Hydrotesting
API RP 1621 Liquid stock control
API RP 500 Electrical Classifications
API RP 505 Elec Class Zone 0-1-2
API RP 520 PSV SIZING
API RP 521 PSV quide for Pressure Systems
API RP 540 Electrical installations
API RP 551 Process Measurement Instrumentation
API RP 552 Transmission Systems
API RP 553 Refinery Control Valves
API RP 554 Process Inst and control
API RP 572 Inspection of pressure vessels
API RP 576 Inspection of PSVs
API RP 579 Fit for service
ASME 1 Rules for construction of Power Boilers
ASME 31.3 Process piping
ASME 5 Pressure Vessel Code
ASME 8 Rules for Construction of Vessels
ASME 9 Qualification Standard for Welders
ASME B16-11 2005.pdf
ASME B16.01-Cast Iron Pipe and flanges-1989
ASME B16.05- Pipe Flanges and Flanged Fittings1996
ASME B16.09- Factory made wrought steel Fittings-1993
ASME B16.10 Face to Face valve Dimensions
ASME B16.11.pdf
ASME B16.20 Metallic Gaskets-1993
ASME B16.21- Nonmetallic Gaskets1992
ASME B16.25- Buttwelding Ends-1997
ASME B16.28- Wrought Steel-1994
ASME B16.34- Valves-1996
ASME B16.47 Large diameter steel flanges
ASME B16.5.pdf
ASME B31 Code Simplified Piping Systems & Pipeline Asme Code Simplified.pdf
ASME B31.01 Power Piping
ASME B31.03 Chemical Plant and Refinery Piping code
ASME B31.04 Liquid Transportation Systems
ASME B31.08 Pressure Piping
ASME B31G Remaining strength of corroded Pipelines
ASME B36-10M Welded and Seamless Wrought Steel Pipe
ASME B36-19M Stainless Steel Pipe
ASME B36.10M_2000.pdf
ASME MFC 3M Measurement of fluid flow
ASME Pipes and Fittings Standards.doc
ASME VIII Div. 2 2007.pdf
Asme Welding Codes.pdf
ASME _B31.3-2004-Process Piping.pdf
ASME _B31[1].3-2004-Process Piping.pdf
DIN 22102
DIN 22131
DIN 2501 Brides.pdf
DIN 2512 Brides.pdf
DIN 2526 Brides.pdf
DIN 2527 Brides.pdf
DIN 2558 Brides.pdf
DIN 2565 Brides.pdf
DIN 2573 Brides.pdf
DIN 2605-2 Coudes.pdf
DIN 2615-1 T‚s.pdf
DIN 2616-1 R‚ductions
DIN 2616-2 R‚ductions
DIN 2617 Caps.pdf
DIN 2630 Brides.pdf
DIN 2641 Brides.pdf
DIN 2652 Brides.pdf
DIN 2673 Brides.pdf
DIN 28115 Brides.pdf
DIN 86029_30 Brides.p
DIN 86044 Bride plate
din _piping.pdf
NF 001 Accessoires tuyauterie
NF 002 Acier
NF 003 Aluminium
NF 004 Assemblage Soud‚s - Soudage
NF 005 Batiments
NF 006 Boulonnerie
NF 007 Essais et Controles
NF 008 Hydraulique
NF 009 Pont roulant
NF 010 Protection contre la Foudre
NF NF A 49-716 Constitution externeriques verticaux
NF 012 Robinetterie
NF 013 Transporteurs … courroies
NF 014 Tube
NF AFNOR.pdf
NF list
NF NF 12241 1998.pdf
NF NF A 49-716 Constitution externedu revetement du tube.pdf
NF NF A 49-716 Constitution externe.pdf
NF NF A 49-716 Constitution externefication des nuances d'acier.pdf
NF NF A 49-716 Constitution externeaud en aciers de constructions
NF NF A 49-716 Constitution externer pour appareil … pression
NF NF A 49-716 Constitution externeier pour appareils sous pression
NF NF A 49-716 Constitution externeves Pr‚vention de l'explosion et protection contre l'explosion Partie 1 Notions fondamentales et m‚thodologie.pdf
NF NF A 49-716 Constitution externe‚gulation de gaz.pdf
NF NF A 49-716 Constitution externe).pdf
NF NF A 49-716 Constitution externee interne des structures m‚talliques.pdf
NF NF A 49-716 Constitution externes … souder en bout pour appareil de robinetterie Butt Welding.pdf
NF NF A 49-716 Constitution externeon des PN.pdf
NF NF A 49-716 Constitution externeelles m‚talliques (DESP 97-23 CE)
NF NF A 49-716 Constitution externedes produits et ‚l‚ments de construction Partie 1 Classement … partir des donn‚es d'essais de r‚action au feu.pdf
NF NF A 49-716 Constitution externets pour les brides d‚sign‚es PN
NF NF A 49-716 Constitution externeements relatifs au gaz naturel liqu‚fi‚-Interface terre navire (1997).pdf
NF NF A 49-716 Constitution externes assemblages … brides circulaires avec joint.pdf
NF NF A 49-716 Constitution externetemp‚rature.pdf
NF NF A 49-716 Constitution externeation et pompes … chaleur - Exigences de s‚curit‚ et d'environnement - ‚dition 2000
NF NF A 49-716 Constitution externees industriels Partie 2.pdf
NF NF A 49-716 Constitution externeion Terminologie et symboels.pdf
NF NF A 49-716 Constitution externeachines Notions fondamentales Principes g‚n‚raux de conception.pdf
NF NF A 49-716 Constitution externetrole et du gaz naturel Contr“le & att‚nuation des feux et des explosions dans les installations en mer.pdf
NF NF A 49-716 Constitution externeice en ‚l‚ments pr‚fabriqu‚s
NF NF A 49-716 Constitution externeux ).pdf
NF NF A 49-716 Constitution externeconstructions Charges d'exploitation des bƒtiments.pdf
NF NF A 49-716 Constitution externeap‚s physiques (Juillet 1978).pdf
NF NF A 49-716 Constitution externentier BTP … ‚chelles … marches ou escaliers Mai 2002.pdf
NF NF A 49-716 Constitution externer destin‚s … l'accŠs et … l'‚vacuation du personnel.pdf
NF NF A 49-716 Constitution externeon tuyauteries
NF NF A 49-716 Constitution externetion du dialogue Homme-Ordinateur.pdf
NF NF A 49-716 Constitution externeappareils … pression.pdf
NF NF A 49-716 Constitution externee M‚nard.pdf
NF NF A 49-716 Constitution externet essai - P‚n‚nomŠtre Type A.pdf
NF NF A 49-716 Constitution externee des caoutchouc.pdf
ABS 2003 Navires en Acier
Affaires Maritimes
BUREAU VERITAS 2005
BV 2000
CM66
CODAP (R‚v 09-07, Edition 2005)
CODETI
CODRES Code Francais de Construction de reservoir cylindrique verticaux en acier
Construction Navale Calcul r‚glementaire
DNV
Dossiers DESP PED - Directive europ‚enne 97-23-CE
DTU20 travaux de bƒtiment ouvrages en ma‡onneriedepetits ‚l‚ments
DTU21 travaux de bƒtiments ex‚cution des travauxenb‚ton
equipements marin.xls
EUROCODE Base de calcul des structures
Glosssaire CODAP, CLAP, AQUAP, CCAP.doc
IT89
LLoyd's
Machines
Militaires
Neige et vent
Nucl‚aire RCCM 2000+2002 en anglais
RŠglement PANAMA
R‚cipients sous pression
r‚glementation R‚seau Eau Pulv‚ris‚e.xls
Solas
Logiciel avec c*r*a*c*k:
Software with c*r*a*c*k:
Calul Bentley.AutoPipe.XM.v09.00.00.08
Calul COADE CAESAR 5.1
Calul Convert
Calul evolution
Calul Flowmaster
Calul PDC
Calul Pipe.Pack.V10.SP3
Calul PipeFlow1037
Calul pipe_flow_2009
Calul Pipe_Flow_Expert_v1.08_Incl_******-DIGERATI
Calul Portable_Engineering_Power_Tools_-_Plus_Edition_v2.0.4
Calul rdm6
Calul Robobat 19, 20 & 21
Calul SF PRESSURE DROP 6.2
CAO DAO 3D MODELS
CAO DAO Acad LT 2009
CAO DAO Alias_I-Run_v3.4.5
CAO DAO AutoCad 2008 32bits
CAO DAO AutoCad 2010 32bits
CAO DAO Autodesk Inventor 11
CAO DAO Autoplant_2004
CAO DAO Bentley Microstation V8
CAO DAO CadFix71
CAO DAO CadPipe
CAO DAO Catia.P3.V5R17
CAO DAO Coade Cadworx 2008
CAO DAO Coade Cadworx Pack 2008
CAO DAO Coade Cadworx PRO Pack 2009
CAO DAO Intergraph Plant Design system 8.0
CAO DAO NavisWorks Jetstream
CAO DAO PDMS 11.6
CAO DAO PDMS 12
CAO DAO plate_n_sheet_4.05
CAO DAO ProSteeelV18
CAO DAO Rhinoc‚ros
CAO DAO SolidWorks 2007
Thank's at all for this very good forum
Polo44600
A French Piping designer
