Results 1 to 12 of 31
Thread: CEN standards collection 26/370: EC ISS TC 105 - Test Methods For Steels Other Than..
    Re: CEN standards collection 26/370: EC ISS TC 105 - Test Methods For Steels Other Th
    full list 26.10.2017:
    EN ISO 148-1:2016 Metallic materials - Charpy pendulum impact test - Part 1: Test method (ISO 148-1:2016)
    EN ISO 148-2:2016 Metallic materials - Charpy pendulum impact test - Part 2: Verification of testing machines (ISO 148-2:2016)
    EN ISO 148-3:2016 Metallic materials - Charpy pendulum impact test - Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines (ISO 148-3:2016)
    EN ISO 204:2009 Metallic materials - Uniaxial creep testing in tension - Method of test (ISO 204:2009)
    EN ISO 376:2011 Metallic materials - Calibration of force-proving instruments used for the verification of uniaxial testing machines (ISO 376:2011)
    EN ISO 642:1999 Steel - Hardenability test by end quenching (Jominy test) (ISO 642:1999)
    EN ISO 643:2012 Steels - Micrographic determination of the apparent grain size (ISO 643:2012)
    EN ISO 2566-1:1999 Steel - Conversion of elongation values - Part 1: Carbon and low alloy steels (ISO 2566-1:1984)
    EN ISO 2566-2:1999 Steel - Conversion of elongation values - Part 2: Austenitic steels (ISO 2566-2:1984)
    EN ISO 2639:2002 Steels - Determination and verification of the depth of carburized and hardened cases (ISO 2639:2002)
    EN ISO 3651-1:1998 Determination of resistance to intergranular corrosion of stainless steels - Part 1: Austenitic and ferritic-austenitic (duplex) stainless steels - Corrosion test in nitric acid medium by measurement of loss in mass (Huey test) (ISO 3651-1:1998)
    EN ISO 3651-2:1998 Determination of resistance to intergranular corrosion of stainless steels - Part 2: Ferritic* austenitic and ferritic-austenitic (duplex) stainless steels - Corrosion test in media containing sulfuric acid (ISO 3651-2:1998)
    EN ISO 3785:2006 Metallic materials - Designation of test specimen axes in relation to product texture (ISO 3785:2006)
    EN ISO 3887:2003 Steels - Determination of depth of decarburization (ISO 3887:2003)
    EN ISO 4545-1:2005 Metallic materials - Knoop hardness test - Part 1: Test method (ISO 4545-1:2005)
    EN ISO 4545-2:2005 Metallic materials - Knoop hardness test - Part 2: Verification and calibration of testing machines (ISO 4545-2:2005)
    EN ISO 4545-3:2005 Metallic materials - Knoop hardness test - Part 3: Calibration of reference blocks (ISO 4545-3:2005)
    EN ISO 4545-4:2005 Metallic materials - Knoop hardness test - Part 4: Table of hardness values (ISO 4545-4:2005)
    EN ISO 6506-1:2014 Metallic materials - Brinell hardness test - Part 1: Test method (ISO 6506-1:2014)
    EN ISO 6506-2:2014 Metallic materials - Brinell hardness test - Part 2: Verification and calibration of testing machines (ISO 6506-2:2014)
    EN ISO 6506-3:2014 Metallic materials - Brinell hardness test - Part 3: Calibration of reference blocks (ISO 6506-3:2014)
    EN ISO 6506-4:2014 Metallic materials - Brinell hardness test - Part 4: Table of hardness values (ISO 6506-4:2014)
    EN ISO 6507-1:2005 Metallic materials - Vickers hardness test - Part 1: Test method (ISO 6507-1:2005)
    EN ISO 6507-2:2005 Metallic materials - Vickers hardness test - Part 2: Verification and calibration of testing machines (ISO 6507-2:2005)
    EN ISO 6507-3:2005 Metallic materials - Vickers hardness test - Part 3: Calibration of reference blocks (ISO 6507-3:2005)
    EN ISO 6507-4:2005 Metallic materials - Vickers hardness test - Part 4: Tables and hardness values (ISO 6507-4:2005)
    EN ISO 6508-1:2016 Metallic materials - Rockwell hardness test - Part 1: Test method (ISO 6508-1:2016)
    EN ISO 6508-2:2015 Metallic materials - Rockwell hardness test - Part 2: Verification and calibration of testing machines (scales A* B* C* D* E* F* G* H* K* N* T) (ISO 6508-2:2015)
    EN ISO 6508-3:2015 Metallic materials - Rockwell hardness test - Part 3: Calibration of reference blocks (scales A* B* C* D* E* F* G* H* K* N* T) (ISO 6508-3:2015)
    EN ISO 6892-1:2016 Metallic materials - Tensile testing - Part 1: Method of test at room temperature (ISO 6892-1:2016)
    EN ISO 6892-2:2011 Metallic materials - Tensile testing - Part 2: Method of test at elevated temperature (ISO 6892-2:2011)
    EN ISO 6892-3:2015 Metallic materials - Tensile testing - Part 3: Method of test at low temperature (ISO 6892-3:2015)
    EN ISO 7438:2016 Metallic materials - Bend test (ISO 7438:2016)
    EN ISO 7500-1:2015 Metallic materials - Calibration and verification of static uniaxial testing machines - Part 1: Tension/compression testing machines - Calibration and verification of the force-measuring system (ISO 7500-1:2015)
    EN ISO 7500-2:2006 Metallic materials - Verification of static uniaxial testing machines - Part 2: Tension creep testing machines - Verification of the applied force (ISO 7500-2:2006)
    EN ISO 7799:2000 Metallic materials - Sheet and strip 3 mm thick or less - Reverse bend test (ISO 7799:1985)
    EN ISO 9513:2012 Metallic materials - Calibration of extensometer systems used in uniaxial testing (ISO 9513:2012)
    EN ISO 9513:2012/AC:2013 Metallic materials - Calibration of extensometer systems used in uniaxial testing (ISO 9513:2012)
    EN ISO 10113: 2014 Metallic materials - Sheet and strip - Determination of plastic strain ratio (ISO 10113:2006* Corrected version 2007-08-01)
    EN 10160:1999 Ultrasonic testing of steel flat product of thickness equal or greater than 6 mm (reflection method)
    EN 10229:1998 Evaluation of resistance of steel products to hydrogen induced *****ing (HIC)
    EN 10247:2007 Micrographic examination of the non-metallic inclusion content of steels using standard pictures
    EN ISO 10275:2014 Metallic materials - Sheet and strip - Determination of tensile strain hardening exponent (ISO 10275:2007)
    EN 10306:2001 Iron and steel - Ultrasonic testing of H beams with parallel flanges and IPE beams
    EN 10307:2001 Non-destructive testing - Ultrasonic testing of austenitic and austenitic-ferritic stainless steels flat products of thickness equal to or greater than 6 mm (reflection method)
    EN 10308:2001 Non destructive testing - Ultrasonic testing of steel bars
    EN 10319-1:2003 Metallic materials - Tensile stress relaxation testing - Part 1: Procedure for testing machines
    EN 10319-2:2006 Metallic materials - Tensile stress relaxation testing - Part 2: Procedure for bolted joint models
    EN 10325:2006 Steel - Determination of yield strength increase by the effect of heat treatment [Bake-Hardening-Index]
    EN 10328:2005 Iron and steel - Determination of the conventional depth of hardening after surface heating
    EN ISO 10113:2014 Metallic materials - Sheet and strip - Determination of plastic strain ratio (ISO 10113:2006)
    EN ISO 12004-1:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 1: Measurement and application of forming-limit diagrams in the press shop (ISO 12004-1:2008)
    EN ISO 12004-2:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 2: Determination of forming-limit curves in the laboratory (ISO 12004-2:2008)
    EN ISO 14556:2015 Metallic materials - Charpy V-notch pendulum impact test - Instrumented test method (ISO 14556:2015)
    EN ISO 14577-1:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 1: Test method (ISO 14577-1:2015)
    EN ISO 14577-2:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 2: Verification and calibration of testing machines (ISO 14577-2:2015)
    EN ISO 14577-3:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 3: Calibration of reference blocks (ISO 14577-3:2015)
    EN ISO 14577-4:2016 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 4: Test method for metallic and non-metallic coatings (ISO 14577-4:2016)
    EN ISO 16808:2014 Metallic materials - Sheet and strip - Determination of biaxial stress-strain curve by means of bulge test with optical measuring systems (ISO 16808:2014)
    EN ISO 16859-1:2015 Metallic materials - Leeb hardness test - Part 1: Test method (ISO 16859-1:2015)
    EN ISO 16859-2:2015 Metallic materials - Leeb hardness test - Part 2: Verification and calibration of the testing devices (ISO 16859-2:2015)
    EN ISO 16859-3:2015 Metallic materials - Leeb hardness test - Part 3: Calibration of reference test blocks (ISO 16859-3:2015)
    EN ISO 18265:2013 Metallic materials - Conversion of hardness values (ISO 18265:2013)
    EN ISO 20482:2013 Metallic materials - Sheet and strip - Erichsen cupping test (ISO 20482:2013)
    EN ISO 26203-1:2010 Metallic materials - Tensile testing at high strain rates - Part 1: Elastic-bar-type systems (ISO 26203-1:2010)
    EN ISO 26203-2:2011 Metallic materials - Tensile testing at high strain rates - Part 2: Servo-hydraulic and other test systems (ISO 26203-2:2011)
    complete
    Dear BornToSin
    Thank you!, Very usefull...
    Best Regards
  1. Replies: 19
    Last Post: 11-19-2017, 08:53 PM
  2. Replies: 14
    Last Post: 11-19-2017, 07:14 PM
  3. Replies: 7
    Last Post: 06-02-2017, 03:43 AM
  4. Replies: 7
    Last Post: 05-29-2017, 04:12 AM
  5. Replies: 1
    Last Post: 02-05-2017, 03:30 AM
