Thread: ISO Collection 124/300:ISO/TC 114 - Horology
    Standards and projects under the direct responsibility of ISO/TC 114 Secretariat
    ISO 1112:2009 Horology -- Functional and non-functional jewels
    ISO 3158:1976 Timekeeping instruments -- Symbolization of control positions
    ISO 3159:2009 Timekeeping instruments -- Wrist-chronometers with spring balance oscillator
    ISO 12819:2009 Methods of evaluation of the battery life of a battery-powered watch
    ISO 13074:2012 Analogue quartz clocks -- Fitting dimensions of movements to hands
    ISO/TS 18684:2015 Timekeeping instruments -- Watch external parts made of hard materials -- General requirements and test methods
    IEC 60086-3:2016 Primary batteries -- Part 3: Watch batteries
    Shock resistant watches
    ISO 1413:2016 Horology -- Shock-resistant wrist watches
    Water-resistant watches
    ISO 6425:1996 Divers' watches
    ISO 22810:2010 Horology -- Water-resistant watches
    Luminescence
    ISO 3157:1991 Radioluminescence for time measurement instruments -- Specifications
    ISO 4168:2002 Timekeeping instruments -- Conditions for carrying out checks on radioluminescent deposits
    ISO 17514:2004 Time-measuring instruments -- Photoluminescent deposits -- Test methods and requirements
    Precious metal coverings
    ISO 3160-1:1998 Watch-cases and accessories -- Gold alloy coverings -- Part 1: General requirements
    ISO 3160-1:1998/Amd 1:2000 Watch-cases and accessories -- Gold alloy coverings -- Part 1: General requirements
    ISO 3160-2:2015 Watch-cases and accessories -- Gold alloy coverings -- Part 2: Determination of fineness* thickness* corrosion resistance and adhesion
    ISO 16253:2007 Watch-cases and accessories -- Vapour phase deposited coatings
    ISO 23160:2011 Watch cases and accessories -- Tests of the resistance to wear* scratching and impacts
    Overall dimensions
    ISO 3764:2016 Timekeeping instruments -- Movements -- Types* dimensions and nomenclature
    ISO 3765:1998 Timekeeping instruments -- Wristwatches -- Dimensions of bracelet-to-case fastening elements
    ISO 10552:2014 Timekeeping instruments -- Crowns and sealed tubes -- Designs and dimensions
    ISO 14856:2001 Timekeeping instruments -- Wristwatch-cases -- Fixing dimensions of non-spring-bar types
    Technical definitions
    ISO 6426-1:1982 Horological vocabulary -- Part 1: Technical and scientific definitions
    ISO 6426-2:2002 Horological vocabulary -- Part 2: Technical and commercial definitions
    ISO 6426-2:2002/Amd 1:2012 Horological vocabulary -- Part 2: Technical and commercial definitions
    ISO 6426-2:2002/Cor 1:2003 Horological vocabulary -- Part 2: Technical and commercial definitions
    Indication of accuracy
    ISO 10553:2003 Horology -- Procedure for evaluating the accuracy of quartz watches
    Antimagnetism
    ISO 764:2002 Horology -- Magnetic resistant watches
    Watch-glasses
    ISO 14368-1:2000 Mineral and sapphire watch-glasses -- Part 1: Dimensions and tolerances
    ISO 14368-1:2000/Cor 1:2006 Mineral and sapphire watch-glasses -- Part 1: Dimensions and tolerances
    ISO 14368-2:2003 Mineral and sapphire watch-glasses -- Part 2: Assembly to the case by adhesive or using a gasket
    ISO 14368-3:2003 Mineral and sapphire watch-glasses -- Part 3: Qualitative criteria and test methods
    Table and wall clocks
    ISO 19235:2015 Analogue quartz clocks -- Timing accuracy
    and the missing are:
    links:
    or
    Re: ISO Collection 124/300:ISO/TC 114 - Horology
    update:
    added missing standards:
    the missing is only:
    update:
    BQ:
    still missing:
    full list 28.12.2017.
    ISO 3160-2:2015 Watch-cases and accessories -- Gold alloy coverings -- Part 2: Determination of fineness, thickness, corrosion resistance and adhesion
    ISO 16253:2017 Watch-cases and accessories -- Vapour phase deposited coatings
    ISO 23160:2011 Watch cases and accessories -- Tests of the resistance to wear, scratching and impacts
    ISO 3764:2016 Timekeeping instruments -- Movements -- Types, dimensions and nomenclature
    the missing:
