only 5 are missing here:
EN ISO 150:2007 Raw, refined and boiled linseed oil for paints and varnishes - Specifications and methods of test (ISO 150:2006)
EN ISO 276:2010 Binders for paints and varnishes - Linseed stand oil - Requirements and methods of test (ISO 276:2002)
EN ISO 277:2010 Binders for paints and varnishes - Raw tung oil - Requirements and methods of test (ISO 277:2002)
EN 927-1:2013 Paints and varnishes - Coating materials and coating systems for exterior wood - Part 1: Classification and selection
EN 927-2:2014 Paints and varnishes - Coating materials and coating systems for exterior wood - Part 2: Performance specification
EN 927-3:2012 Paints and varnishes - Coating materials and coating systems for exterior wood - Part 3: Natural weathering test
EN 927-5:2006 Paints and varnishes - Coating materials and coating systems for exterior wood - Part 5: Assessment of the liquid water permeability
EN 927-6:2006 Paints and varnishes - Coating materials and coating systems for exterior wood - Part 6: Exposure of wood coatings to artificial weathering using fluorescent UV lamps and water
EN 1062-1:2004 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 1: Classification
EN 1062-3:2008 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 3: Determination of liquid water permeability
EN 1062-6:2002 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 6: Determination of carbon dioxide permeability
EN 1062-7:2004 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 7: Determination of ***** bridging properties
EN 1062-11:2002 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 11: Methods of conditioning before testing
EN 1062-11:2002/AC:2005 Paints and varnishes - Coating materials and coating systems for exterior masonry and concrete - Part 11: Methods of conditioning before testing
EN ISO 1513:2010 Paints and varnishes - Examination and preparation of test samples (ISO 1513:2010)
EN ISO 1514:2004 Paints and varnishes - Standard panels for testing (ISO 1514:2004)
EN ISO 1518-1:2011 Paints and varnishes - Determination of scratch resistance - Part 1: Constant-loading method (ISO 1518-1:2011)
EN ISO 1518-2:2011 Paints and varnishes - Determination of scratch resistance - Part 2: Variable-loading method (ISO 1518-2:2011)
EN ISO 1519:2011 Paints and varnishes - Bend test (cylindrical mandrel) (ISO 1519:2011)
EN ISO 1520:2006 Paints and varnishes - Cupping test (ISO 1520:2006)
EN ISO 1522:2006 Paints and varnishes - Pendulum damping test (ISO 1522:2006)
EN ISO 1524:2013 Paints, varnishes and printing inks - Determination of fineness of grind (ISO 1524:2013)
EN ISO 2409:2013 Paints and varnishes - Cross-cut test (ISO 2409:2013)
EN ISO 2431:2011 Paints and varnishes - Determination of flow time by use of flow cups (ISO 2431:2011)
EN ISO 2808:2007 Paints and varnishes - Determination of film thickness (ISO 2808:2007)
EN ISO 2810:2004 Paints and varnishes - Natural weathering of coatings - Exposure and assessment (ISO 2810:2004)
EN ISO 2811-1:2011 Paints and varnishes - Determination of density - Part 1: Pyknometer method (ISO 2811-1:2011)
EN ISO 2811-2:2011 Paints and varnishes - Determination of density - Part 2: Immersed body (plummet) method (ISO 2811-2:2011)
EN ISO 2811-3:2011 Paints and varnishes - Determination of density - Part 3: Oscillation method (ISO 2811-3:2011)
EN ISO 2811-4:2011 Paints and varnishes - Determination of density - Part 4: Pressure cup method (ISO 2811-4:2011)
EN ISO 2812-1:2007 Paints and varnishes - Determination of resistance to liquids - Part 1: Immersion in liquids other than water (ISO 2812-1:2007)
EN ISO 2812-2:2007 Paints and varnishes - Determination of resistance to liquids - Part 2: Water immersion method (ISO 2812-2:2007)
EN ISO 2812-3:2012 Paints and varnishes - Determination of resistance to liquids - Part 3: Method using an absorbent medium (ISO 2812-3:2012)
EN ISO 2812-4:2007 Paints and varnishes - Determination of resistance to liquids - Part 4: Spotting methods (ISO 2812-4:2007)
EN ISO 2812-5:2007 Paints and varnishes - Determination of resistance to liquids - Part 5: Temperature-gradient oven method (ISO 2812-5:2007)
EN ISO 2813:2014 Paints and varnishes - Determination of specular gloss of non-metallic paint films at 20°, 60° and 85° (ISO 2813:1994, including Technical Corrigendum 1:1997)
EN ISO 2815:2003 Paints and varnishes - Buchholz indentation test (ISO 2815:2003)
EN ISO 2884-1:2006 Paints and varnishes - Determination of viscosity using rotary viscometers - Part 1: Cone-and-plate viscometer operated at a high rate of shear (ISO 2884-1:1999)
EN ISO 2884-2:2006 Paints and varnishes - Determination of viscosity using rotary viscometers - Part 2: Disc or ball viscometer operated at a specified speed (ISO 2884-2:2003)
EN ISO 3219:1994 Plastics - Polymers/resins in the liquid state or as emulsions or dispersions - Determination of viscosity using a rotational viscometer with defined shear rate (ISO 3219:1993)
EN ISO 3231:1997 Paints and varnishes - Determination of resistance to humid atmospheres containing sulfur dioxide (ISO 3231:1993)
EN ISO 3233-1:2013 Paints and varnishes - Determination of the percentage volume of non-volatile matter - Part 1: Method using a coated test panel to determine non-volatile matter and to determine dry film density by the Archimedes principle (ISO 3233-1:2013)
EN ISO 3233-2:2014 Paints and varnishes - Determination of the percentage volume of non-volatile matter - Part 2: Method using the determination of non-volatile-matter content in accordance with ISO 3251 and determination of dry film density on coated test panels by the Arc
EN ISO 3233-3:2015 Paints and varnishes - Determination of the percentage volume of non-volatile matter - Part 3: Determination by calculation from the non-volatile-matter content determined in accordance with ISO 3251, the density of the coating material and the density of the solvent in the coating material (ISO 3233-3:2015) - missing
EN ISO 3248:2000 Paints and varnishes - Determination of the effect of heat (ISO 3248:1998)
EN ISO 3251:2008 Paints, varnishes and plastics - Determination of non-volatile-matter content (ISO 3251:2008)
EN ISO 3668:2001 Paints and varnishes - Visual comparison of the colour of paints (ISO 3668:1998)
EN ISO 3681:1998 Binders for paints and varnishes - Determination of saponification value - Titrimetric method (ISO 3681:1996)
EN ISO 4618:2014 Paints and varnishes - Terms and definitions (ISO 4618:2014)
EN ISO 4619:2010 Driers for paints and varnishes (ISO 4619:1998)
EN ISO 4623-1:2002 Paints and varnishes - Determination of resistance to filiform corrosion - Part 1: Steel substrates (ISO 4623-1:2000)
EN ISO 4623-2:2004 Paints and varnishes - Determination of resistance to filiform corrosion - Part 2: Aluminium substrates (ISO 4623-2:2003)
EN ISO 4623-2:2004/AC:2006 Paints and varnishes - Determination of resistance to filiform corrosion - Part 2: Aluminium substrates (ISO 4623-2:2003/Cor.1:2005)
EN ISO 4624:2003 Paints and varnishes - Pull-off test for adhesion (ISO 4624:2002)
EN ISO 4625-1:2006 Binders for paints and varnishes - Determination of softening point - Part 1: Ring-and-ball method (ISO 4625-1:2004)
EN ISO 4625-2:2006 Binders for paints and varnishes - Determination of softening point - Part 2: Cup-and-ball method (ISO 4625-2:2004)
EN ISO 4628-1:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 1: General introduction and designation system (ISO 4628-1:2003)
EN ISO 4628-2:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 2: Assessment of degree of blistering (ISO 4628-2:2003)
EN ISO 4628-3:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 3: Assessment of degree of rusting (ISO 4628-3:2003)
EN ISO 4628-4:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 4: Assessment of degree of *****ing (ISO 4628-4:2003)
EN ISO 4628-5:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 5: Assessment of degree of flaking (ISO 4628-5:2003)
EN ISO 4628-6:2011 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 6: Assessment of degree of chalking by tape method (ISO 4628-6:2011)
EN ISO 4628-7:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 7: Assessment of degree of chalking by velvet method (ISO 4628-7:2003)
EN ISO 4628-8:2012 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 8: Assessment of degree of delamination and corrosion around a scribe or other artificial
EN ISO 4628-10:2003 Paints and varnishes - Evaluation of degradation of coatings - Designation of quantity and size of defects, and of intensity of uniform changes in appearance - Part 10: Assessment of degree of filiform corrosion (ISO 4628-10:2003)
EN ISO 4629:1998 Binders for paints and varnishes - Determination of hydroxyl value - Titrimetric method (ISO 4629:1996)
EN ISO 4630-1:2004 Clear liquids - Estimation of colour by the Gardner colour scale - Part 1: Visual method (ISO 4630-1:2004)
EN ISO 4630-2:2004 Clear liquids - Estimation of colour by the Gardner colour scale - Part 2: Spectrophotometric method (ISO 4630-2:2004)
EN ISO 6270-1:2001 Paints and varnishes - Determination of resistance to humidity - Part 1: Continuous condensation (ISO 6270-1:1998)
EN ISO 6270-2:2005 Paints and varnishes - Determination of resistance to humidity - Part 2: Procedure for exposing test specimens in condensation-water atmospheres (ISO 6270-2:2005)
EN ISO 6271-1:2004 Clear liquids - Estimation of colour by the platinum-cobalt scale - Part 1: Visual method (ISO 6271-1:2004)
EN ISO 6271-2:2004 Clear liquids - Estimation of colour by the platinum-cobalt scale - Part 2: Spectrophotometric method (ISO 6271-2:2004)
EN ISO 6272-1:2011 Paints and varnishes - Rapid-deformation (impact resistance) tests - Part 1: Falling-weight test, large-area indenter (ISO 6272-1:2011)
EN ISO 6272-2:2011 Paints and varnishes - Rapid-deformation (impact resistance) tests - Part 2: Falling-weight test, small-area indenter (ISO 6272-2:2011)
EN ISO 6504-1:2006 Paints and varnishes - Determination of hiding power - Part 1: Kubelka-Munk method for white and light-coloured paints (ISO 6504-1:1983)
EN ISO 6504-3:2007 Paints and varnishes - Determination of hiding power - Part 3: Determination of contrast ratio of light-coloured paints at a fixed spreading rate (ISO 6504-3:2006)
EN ISO 6744-1:2004 Binders for paints and varnishes - Alkyd resins - Part 1: General methods of test (ISO 6744-1:1999)
EN ISO 6744-2:2004 Binders for paints and varnishes - Alkyd resins - Part 2: Determination of phthalic anhydride content (ISO 6744-2:1999)
EN ISO 6744-3:2004 Binders for paints and varnishes - Alkyd resins - Part 3: Determination of unsaponifiable matter content (ISO 6744-3:1999)
EN ISO 6744-4:2004 Binders for paints and varnishes - Alkyd resins - Part 4: Determination of fatty acid content (ISO 6744-4:1999)
EN ISO 6860:2006 Paints and varnishes - Bend test (conical mandrel) (ISO 6860:2006)
EN ISO 7142:2007 Binders for paints and varnishes - Epoxy resins - General methods of test (ISO 7142:2007)
EN ISO 7143:2007 Binders for paints and varnishes - Methods of test for characterizing water-based binders (ISO 7143:2007)
EN ISO 7783:2011 Paints and varnishes - Determination of water-vapour transmission properties - Cup method (ISO 7783:2011)
EN ISO 7784-1:2006 Paints and varnishes - Determination of resistance to abrasion - Part 1: Rotating abrasive-paper-covered wheel method (ISO 7784-1:1997)
EN ISO 7784-2:2006 Paints and varnishes - Determination of resistance to abrasion - Part 2: Rotating abrasive rubber wheel method (ISO 7784-2:1997)
EN ISO 7784-3:2006 Paints and varnishes - Determination of resistance to abrasion - Part 3: Reciprocating test panel method (ISO 7784-3:2000)
EN ISO 8130-1:2010 Coating powders - Part 1: Determination of particle size distribution by sieving (ISO 8130-1:1992)
EN ISO 8130-2:2010 Coating powders - Part 2: Determination of density by gas comparison pyknometer (referee method) (ISO 8130-2:1992)
EN ISO 8130-3:2010 Coating powders - Part 3: Determination of density by liquid displacement pyknometer (ISO 8130-3:1992)
EN ISO 8130-4:2010 Coating powders - Part 4: Calculation of lower explosion limit (ISO 8130-4:1992, including Cor 1:1993)
EN ISO 8130-5:2010 Coating powders - Part 5: Determination of flow properties of a powder/air mixture (ISO 8130-5:1992)
EN ISO 8130-6:2010 Coating Powders - Part 6: Determination of gel time of thermosetting coating powders at a given temperature (ISO 8130-6:1992, including Amd 1:1998)
EN ISO 8130-7:2010 Coating powders - Part 7: Determination of loss of mass on stoving (ISO 8130-7:1992)
EN ISO 8130-8:2010 Coating powders - Part 8: Assessment of the storage stability of thermosetting powders (ISO 8130-8:1994)
EN ISO 8130-9:1999 Coating powders - Part 9: Sampling (ISO 8130-9:1992)
EN ISO 8130-10:2010 Coating powders - Part 10: Determination of deposition efficiency (ISO 8130-10:1998)
EN ISO 8130-11:2010 Coating powders - Part 11: Inclined-plane flow test (ISO 8130-11:1997)
EN ISO 8130-12:2010 Coating powders - Part 12: Determination of compatibility (ISO 8130-12:1998)
EN ISO 8130-13:2010 Coating powders - Part 13: Particle size analysis by laser diffraction (ISO 8130-13:2001)
EN ISO 8130-14:2004 Coating powders - Part 14: Terminology (ISO 8130-14:2004)
EN ISO 8501-1:2007 Preparation of steel substrates before application of paints and related products - Visual assessment of surface cleanliness - Part 1: Rust grades and preparation grades of uncoated steel substrates and of steel substrates after overall removal of previou
EN ISO 8501-2:2001 Preparation of steel substrates before application of paints and related products - Visual assessment of surface cleanliness - Part 2: preparation grades of previously coated steel substrates after localized removal of previous coatings (ISO 8501-2:1994) - missing VE
EN ISO 8501-3:2007 Preparation of steel substrates before application of paints and related products - Visual assessment of surface cleanliness - Part 3: Preparation grades of welds, edges and other areas with surface imperfections (ISO 8501-3:2006)
EN ISO 8501-4:2006 Preparation of steel substrates before application of paints and related products - Visual assessment of surface cleanliness - Part 4: Initial surface conditions, preparation grades and flash rust grades in connection with high-pressure water jetting (ISO
EN ISO 8502-2:2005 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 2: Laboratory determination of chloride on cleaned surfaces (ISO 8502-2:2005)
EN ISO 8502-3:1999 Preparation of steel substrates before application of paint and related products - Tests for the assessment of surface cleanliness - Part 3: Assessment of dust on steel surfaces prepared for painting (pressure-sensitive tape method) (ISO 8502-3:1992)
EN ISO 8502-4:1999 Preparation of steel substrates before application of paint and related products - Tests for the assessment of surface cleanliness - Part 4: Guidance on the estimation of the probability of condensation prior to paint application (ISO 8502-4:1993)
EN ISO 8502-5:2004 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 5: Measurement of chloride on steel surfaces prepared for painting (ion detection tube method) (ISO 8502-5:1998)
EN ISO 8502-6:2006 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 6: Extraction of soluble contaminants for analysis - The Bresle method (ISO 8502-6:2006)
EN ISO 8502-9:2000 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 9: Field method for the conductometric determination of water-soluble salts (ISO 8502-9:1998)
EN ISO 8502-11:2006 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 11: Field method for the turbidimetric determination of water-soluble sulfate (ISO 8502-11:2006)
EN ISO 8502-12:2004 Preparation of steel substrates before application of paints and related products - Tests for the assessment of surface cleanliness - Part 12: Field method for the titrimetric determination of water-soluble ferrous ions (ISO 8502-12:2003)
EN ISO 8503-1:2012 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 1: Specifications and definitions for ISO surface profile comparators for the assessment of abra
EN ISO 8503-2:2012 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 2: Method for the grading of surface profile of abrasive blast-cleaned steel - Comparator proced
EN ISO 8503-3:2012 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 3: Method for the calibration of ISO surface profile comparators and for the determination of su
EN ISO 8503-4:2012 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 4: Method for the calibration of ISO surface profile comparators and for the determination of su
EN ISO 8503-5:2004 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 5: Replica tape method for the determination of the surface profile (ISO 8503-5:2003)
EN ISO 8504-1:2001 Preparation of steel substrates before application of paints and related products - Surface preparation methods - Part 1: General principles (ISO 8504-1:2000)
EN ISO 8504-2:2001 Preparation of steel substrates before application of paints and related products - Surface preparation methods - Part 2: Abrasive blast-cleaning (ISO 8504-2:2000)
EN ISO 8504-3:2001 Preparation of steel substrates before application of paints and related products - Surface preparation methods - Part 3: Hand- and power-tool cleaning (ISO 8504-3:1993)
EN ISO 8623:2015 Tall-oil fatty acids for paints and varnishes - Specifications and test methods (ISO 8623:2015)
EN ISO 9038:2013 Determination of sustained combustibility of liquids (ISO 9038:2013)
EN ISO 9117-1:2009 Paints and varnishes - Drying tests - Part 1: Determination of through-dry state and through-dry time (ISO 9117-1:2009)
EN ISO 9117-2:2010 Paints and varnishes - Drying tests - Part 2: Pressure test for stackability (ISO 9117-2:2010)
EN ISO 9117-3:2010 Paints and varnishes - Drying tests - Part 3: Surface-drying test using ballotini (ISO 9117-3:2010)
EN ISO 9117-4:2012 Paints and varnishes - Drying tests - Part 4: Test using a mechanical recorder (ISO 9117-4:2012)
EN ISO 9117-5:2012 Paints and varnishes - Drying tests - Part 5: Modified Bandow-Wolff test (ISO 9117-5:2012)
EN ISO 9117-6:2012 Paints and varnishes - Drying tests - Part 6: Print-free test (ISO 9117-6:2012)
EN ISO 9227:2012 Corrosion tests in artificial atmospheres - Salt spray tests (ISO 9227:2012)
EN ISO 9514:2005 Paints and varnishes - Determination of the pot life of multicomponent coating systems - Preparation and conditioning of samples and guidelines for testing (ISO 9514:2005)
EN ISO 10283:2007 Binders for paints and varnishes - Determination of monomeric diisocyanates in isocyanate resins (ISO 10283:2007)
EN ISO 10890:2010 Paints and varnishes - Modelling of biocide release rate from antifouling paints by mass-balance calculation (ISO 10890:2010)
EN ISO 10927:2011 Plastics - Determination of the molecular mass and molecular mass distribution of polymer species by matrix-assisted laser desorption/ionization time-of-flight mass spectrometry (MALDI-TOF-MS) (ISO 10927:2011)
EN ISO 11124-1:1997 Preparation of steel substrates before application of paints and related products - Specifications for metallic blast-cleaning abrasives - Part 1: General introduction and classification (ISO 11124-1:1993)
EN ISO 11124-2:1997 Preparation of steel substrates before application of paints and related products - Specifications for metallic blast-cleaning abrasives - Part 2: Chilled-iron grit (ISO 11124-2:1993)
EN ISO 11124-3:1997 Preparation of steel substrates before application of paints and related products - Specifications for metallic blast-cleaning abrasives - Part 3: High-carbon cast-steel shot and grit (ISO 11124-3:1993)
EN ISO 11124-4:1997 Preparation of steel substrates before application of paints and related products - Specifications for metallic blast-cleaning abrasives - Part 4: Low-carbon cast-steel shot (ISO 11124-4:1993)
EN ISO 11125-1:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 1: Sampling (ISO 11125-1:1993)
EN ISO 11125-2:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 2: Determination of particle size distribution (ISO 11125-2:1993)
EN ISO 11125-3:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 3: Determination of hardness (ISO 11125-3:1993)
EN ISO 11125-4:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 4: Determination of apparent density (ISO 11125-4:1993)
EN ISO 11125-5:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 5: Determination of percentage defective particles and of microstructure (ISO 11125-5:1993)
EN ISO 11125-6:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 6: Determination of foreign matter (ISO 11125-6:1993)
EN ISO 11125-7:1997 Preparation of steel substrates before application of paints and related products - Test methods for metallic blast-cleaning abrasives - Part 7: Determination of moisture (ISO 11125-7:1993)
EN ISO 11126-1:1997 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 1: General introduction and classification (ISO 11126-1:1993, including Technical Corrigenda 1:1997 and 2:1
EN ISO 11126-3:1997 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 3: Copper refinery slag (ISO 11126-3:1993)
EN ISO 11126-4:1998 Preparation of steel substrates before application of paintsand related products - Specifications for non-metallic blast-cleaning abrasives - Part 4: Coal furnace slag (ISO 11126-4:1993)
EN ISO 11126-5:1998 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 5: Nickel refinery slag (ISO 11126-5:1993)
EN ISO 11126-6:1997 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 6: Iron furnace slag (ISO 11126-6:1993)
EN ISO 11126-7:1999 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 7: Fused aluminium oxide (ISO 11126-7:1995)
EN ISO 11126-8:1997 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 8: Olivine sand (ISO 11126-8:1993)
EN ISO 11126-9:2004 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 9: Staurolite (ISO 11126-9:1999)
EN ISO 11126-10:2004 Preparation of steel substrates before application of paints and related products - Specifications for non-metallic blast-cleaning abrasives - Part 10: Almandite garnet (ISO 11126-10:2000)
EN ISO 11127-1:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 1: Sampling (ISO 11127-1:2011)
EN ISO 11127-2:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 2: Determination of particle size distribution (ISO 11127-2:2011)
EN ISO 11127-3:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 3: Determination of apparent density (ISO 11127-3:2011)
EN ISO 11127-4:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 4: Assessment of hardness by a glass slide test (ISO 11127-4:2011)
EN ISO 11127-5:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 5: Determination of moisture (ISO 11127-5:2011)
EN ISO 11127-6:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 6: Determination of water-soluble contaminants by conductivity measurement (ISO 11127-6:2011)
EN ISO 11127-7:2011 Preparation of steel substrates before application of paints and related products - Test methods for non-metallic blast-cleaning abrasives - Part 7: Determination of water-soluble chlorides (ISO 11127-7:2011)
EN ISO 11664-1:2011 Colorimetry - Part 1: CIE standard colorimetric observers (ISO 11664-1:2007)
EN ISO 11664-2:2011 Colorimetry - Part 2: CIE standard illuminants (ISO 11664-2:2007)
EN ISO 11664-3:2013 Colorimetry - Part 3: CIE tristimulus values (ISO 11664-3:2012)
EN ISO 11664-4:2011 Colorimetry - Part 4: CIE 1976 L*a*b* Colour space (ISO 11664-4:2008)
EN ISO 11664-5:2011 Colorimetry - Part 5: CIE 1976 L*u*v* Colour space and u', v' uniform chromaticity scale diagram (ISO 11664-5:2009)
EN ISO 11668:2001 Binders for paints and varnishes - Chlorinated polymerization resins - General methods of test (ISO 11668:1997)
EN ISO 11890-1:2007 Paints and varnishes - Determination of volatile organic compound (VOC) content - Part 1: Difference method (ISO 11890-1:2007)
EN ISO 11890-2:2013 Paints and varnishes - Determination of volatile organic compound (VOC) content - Part 2: Gas-chromatographic method (ISO 11890-2:2013)
EN ISO 11908:1998 Binders for paints and varnishes - Amino resins - General methods of test (ISO 11908:1996)
EN ISO 11909:2007 Binders for paints and varnishes - Polyisocyanate resins - General methods of test (ISO 11909:2007)
EN ISO 11997-1:2006 Paints and varnishes - Determination of resistance to cyclic corrosion conditions - Part 1: Wet (salt fog)/dry/humidity (ISO 11997-1:2005)
EN ISO 11997-2:2013 Paints and varnishes - Determination of resistance to cyclic corrosion conditions - Part 2: Wet (salt fog)/dry/humidity/UV light (ISO 11997-2:2013)
EN ISO 11998:2006 Paints and varnishes - Determination of wet-scrub resistance and cleanability of coatings (ISO 11998:2006)
EN ISO 12137:2011 Paints and varnishes - Determination of mar resistance (ISO 12137:2011)
EN 12206-1:2004 Paints and varnishes - Coating of aluminium and aluminium alloys for architectural purposes - Part 1: Coatings prepared from coating powder
EN ISO 12944-1:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 1: General introduction (ISO 12944-1:1998)
EN ISO 12944-2:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 2: Classification of environments (ISO 12944-2:1998)
EN ISO 12944-3:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 3: Design considerations (ISO 12944-3:1998)
EN ISO 12944-4:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 4: Types of surface and surface preparation (ISO 12944-4:1998)
EN ISO 12944-5:2007 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 5: Protective paint systems (ISO 12944-5:2007)
EN ISO 12944-6:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 6: Laboratory performance test methods (ISO 12944-6:1998)
EN ISO 12944-7:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 7: Execution and supervision of paint work (ISO 12944-7:1998)
EN ISO 12944-8:1998 Paints and varnishes - Corrosion protection of steel structures by protective paint systems - Part 8: Development of specifications for new work and maintenance (ISO 12944-8:1998)
EN ISO 13076:2012 Paints and varnishes - Lighting and procedure for visual assessments of coatings (ISO 13076:2012)
EN ISO 13129:2012 Paints and varnishes - Electrochemical measurement of the protection provided to steel by paint coatings - Current interrupter (CI) technique, relaxation voltammetry (RV) technique and DC transient (DCT) measurements (ISO 13129:2012)
EN 13300:2001 Paints and varnishes - Water-borne coating materials and coating systems for interior walls and ceilings - Classification
EN 13300:2001/AC:2002 Paints and varnishes - Water-borne coating materials and coating systems for interior walls and ceilings - Classification
EN 13438:2013 Paints and varnishes - Powder organic coatings for hot dip galvanised or sherardised steel products for construction purposes
EN 13523-0:2014 Coil coated metals - Test methods - Part 0: General introduction
EN 13523-1:2009 Coil coated metals - Test methods - Part 1: Film thickness
EN 13523-2:2014 Coil coated metals - Test methods - Part 2: Gloss
EN 13523-3:2014 Coil coated metals - Test methods - Part 3: Colour difference - Instrumental comparison
EN 13523-4:2014 Coil coated metals - Test methods - Part 4: Pencil hardness
EN 13523-5:2014 Coil coated metals - Test methods - Part 5: Resistance to rapid deformation (impact test)
EN 13523-6:2002 Coil coated metals - Test methods - Part 6: Adhesion after indentation (cupping test)
EN 13523-7:2014 Coil coated metals - Test methods - Part 7: Resistance to *****ing on bending (T-bend test)
EN 13523-8:2010 Coil coated metals - Test methods - Part 8: Resistance to salt spray (fog)
EN 13523-9:2014 Coil coated metals - Test methods - Part 9: Resistance to water immersion - missing VE
EN 13523-10:2010 Coil coated metals - Test methods - Part 10: Resistance to fluorescent UV radiation and water condensation
EN 13523-11:2011 Coil coated metals - Test methods - Part 11: Resistance to solvents (rubbing test)
EN 13523-12:2004 Coil coated metals - Test methods - Part 12: Resistance to scratching
EN 13523-13:2014 Coil coated metals - Test methods - Part 13: Resistance to accelerated ageing by the use of heat
EN 13523-14:2014 Coil coated metals - Test methods - Part 14: Chalking (Helmen method)
EN 13523-15:2015 Coil coated metals - Test methods - Part 15: Metamerism
EN 13523-16:2004 Coil coated metals - Test methods - Part 16: Resistance to abrasion
EN 13523-17:2011 Coil coated metals - Test methods - Part 17: Adhesion of strippable films
EN 13523-18:2002 Coil coated metals - Test methods - Part 18: Resistance to staining
EN 13523-19:2011 Coil coated metals - Test methods - Part 19: Panel design and method of atmospheric exposure testing
EN 13523-20:2011 Coil coated metals - Test methods - Part 20: Foam adhesion
EN 13523-21:2010 Coil coated metals - Test methods - Part 21: Evaluation of outdoor exposed panels
EN 13523-22:2010 Coil coated metals - Test methods - Part 22: Colour difference - Visual comparison
EN 13523-23:2002 Coil coated metals - Test methods - Part 23: Colour stability in humid atmospheres containing sulfur dioxide
EN 13523-24:2004 Coil coated metals - Test methods - Part 24: Resistance to blocking and pressure marking
EN 13523-25:2014 Coil coated metals - Test methods - Part 25: Resistance to humidity
EN 13523-26:2014 Coil coated metals - Test methods - Part 26: Resistance to condensation of water - missing VE
EN 13523-27:2009 Coil coated metals - Test methods - Part 27: Resistance to humid poultice (Cataplasm test)
EN 13523-29:2010 Coil coated metals - Test methods - Part 29: Resistance to environmental soiling (Dirt pick-up and striping)
EN ISO 13632:2012 Binders for paints and varnishes - Rosin - Sampling and sample preparation for colour measurement (ISO 13632:2012)
EN ISO 13803:2014 Paints and varnishes - Determination of reflection haze on paint films at 20 degrees (ISO 13803:2014)
EN ISO 14446:2010 Binders for paints and varnishes - Determination of the viscosity of industrial cellulose nitrate solutions and classification of such solutions (ISO 14446:1999)
EN ISO 14680-1:2006 Paints and varnishes - Determination of pigment content - Part 1: Centrifuge method (ISO 14680-1:2000)
EN ISO 14680-2:2006 Paints and varnishes - Determination of pigment content - Part 2: Ashing method (ISO 14680-2:2000)
EN ISO 14680-3:2006 Paints and varnishes - Determination of pigment content - Part 3: Filtration method (ISO 14680-3:2000)
EN 15060:2006 Paints and varnishes - Guide for the classification and selection of coating systems for wood based materials in furniture for interior use
EN ISO 15091:2012 Paints and varnishes - Determination of electrical conductivity and resistance (ISO 15091:2012)
EN ISO 15110:2013 Paints and varnishes - Artificial weathering including acidic deposition (ISO 15110:2013)
EN ISO 15181-2:2007 Paints and varnishes - Determination of release rate of biocides from antifouling paints - Part 2: Determination of copper-ion concentration in the extract and calculation of the release rate (ISO 15181-2:2007)
EN ISO 15181-3:2007 Paints and varnishes - Determination of release rate of biocides from antifouling paints - Part 3: Calculation of the zinc ethylene-bis(dithiocarbamate) (zineb) release rate by determination of the concentration of ethylenethiourea in the extract (ISO 151
EN ISO 15181-4:2008 Paints and varnishes - Determination of release rate of biocides from antifouling paints - Part 4: Determination of pyridine-triphenylborane (PTPB) concentration in the extract and calculation of the release rate (ISO 15181-4:2008)
EN ISO 15181-5:2008 Paints and varnishes - Determination of release rate of biocides from antifouling paints - Part 5: Calculation of the tolylfluanid and dichlofluanid release rate by determination of the concentration of dimethyltolylsulfamide (DMST) and dimethylphenylsulf
EN ISO 15181-6:2014 Paints and varnishes - Determination of release rate of biocides from antifouling paints - Part 6: Determination of tralopyril release rate by quantitation of its degradation product in the extract (ISO 15181-6:2012)
EN ISO 15184:2012 Paints and varnishes - Determination of film hardness by pencil test (ISO 15184:2012)
EN ISO 15234:2010 Paints and varnishes - Testing of formaldehyde-emitting coatings and melamine foams - Determination of the steady-state concentration of formaldehyde in a small test chamber (ISO 15234:1999)
EN 15457:2014 Paints and varnishes - Laboratory method for testing the efficacy of film preservatives in a coating against fungi
EN 15458:2014 Paints and varnishes - Laboratory method for testing the efficacy of film preservatives in a coating against algae
EN ISO 15528:2013 Paints, varnishes and raw materials for paints and varnishes - Sampling (ISO 15528:2013)
EN ISO 15710:2006 Paints and varnishes - Corrosion testing by alternate immersion in and removal from a buffered sodium chloride solution (ISO 15710:2002)
EN ISO 15711:2004 Paints and varnishes - Determination of resistance to cathodic disbonding of coatings exposed to sea water (ISO 15711:2003)
EN ISO 15715:2006 Binders for paints and varnishes - Determination of turbidity (ISO 15715:2003)
EN 15773:2009 Industrial application of powder organic coatings to hot dip galvanized or sherardized steel articles [duplex systems] - Specifications, recommendations and guidelines
EN ISO 15880:2004 Paints, varnishes and binders - Determination of MEQ value of water-based coating materials and binders (ISO 15880:2000)
EN ISO 16014-5:2012 Plastics - Determination of average molecular mass and molecular mass distribution of polymers using size-exclusion chromatography - Part 5: Method using light-scattering detection (ISO 16014-5:2012)
EN 16074:2011 Paints and varnishes - Determination of non-volatile-matter content and spreading rate of coil coating materials
EN 16105:2011 Paints and varnishes - Laboratory method for determination of release of substances from coatings in intermittent contact with water
EN ISO 16276-1:2007 Corrosion protection of steel structures by protective paint systems - Assessment of, and acceptance criteria for, the adhesion/cohesion (fracture strength) of a coating - Part 1: Pull-off testing (ISO 16276-1:2007)
EN ISO 16276-2:2007 Corrosion protection of steel structures by protective paint systems - Assessment of, and acceptance criteria for, the adhesion/cohesion (fracture strength) of a coating - Part 2: Cross-cut testing and X-cut testing (ISO 16276-2:2007)
CEN/TS 16358:2012 Paints and varnishes - Coating materials and coating systems for exterior wood - Assessment of air inclusions/microfoam in coating films
CEN/TS 16359:2012 Paints and varnishes - Coating materials and coating systems for exterior wood - Assessment of knot staining resistance of wood coatings
CEN/TS 16360:2012 Paints and varnishes - Coating materials and coating systems for exterior wood - Assessment of film extensibility by indentation of a coating on a wooden substrate
EN 16402:2013 Paints and varnishes - Assessment of emissions of substances from coatings into indoor air - Sampling, conditioning and testing
EN ISO 16474-1:2013 Paints and varnishes - Methods of exposure to laboratory light sources - Part 1: General guidance (ISO 16474-1:2013)
EN ISO 16474-2:2013 Paints and varnishes - Methods of exposure to laboratory light sources - Part 2: Xenon-arc lamps (ISO 16474-2:2013)
EN ISO 16474-3:2013 Paints and varnishes - Methods of exposure to laboratory light sources - Part 3: Fluorescent UV lamps (ISO 16474-3:2013)
EN 16492:2014 Paints and varnishes - Evaluation of the surface disfigurement caused by fungi and algae on coatings
CEN/TS 16498:2013 Paints and varnishes - Coating materials and coating systems for exterior wood - Assessment of tannin staining
CEN/TS 16499:2013 Paints and varnishes - Coating materials and coating systems for exterior wood - Resistance to blocking of paints and varnishes on wood
EN 16566:2014 Paints and varnishes - Fillers for internal and/or external works - Adaptation of fillers to European standards
EN 16623: 2015 Paints and varnishes - Reactive coatings for fire protection of metallic substrates - Definitions, requirements, characteristics and marking
CEN/TS 16700:2014 Paints and varnishes - Coating materials and coating systems for exterior wood - Assessment of resistance to impact of a coating on a wooden substrate
EN ISO 16773-1:2007 Paints and varnishes - Electrochemical impedance spectroscopy (EIS) on high-impedance coated specimens - Part 1: Terms and definitions (ISO 16773-1:2007)
EN ISO 16773-2:2007 Paints and varnishes - Electrochemical impedance spectroscopy (EIS) on high-impedance coated specimens - Part 2: Collection of data (ISO 16773-2:2007)
EN ISO 16773-3:2009 Paints and varnishes - Electrochemical impedance spectroscopy (EIS) on high-impedance coated specimens - Part 3: Processing and analysis of data from dummy cells (ISO 16773-3:2009)
EN ISO 16773-4:2009 Paints and varnishes - Electrochemical impedance spectroscopy (EIS) on high-impedance coated specimens - Part 4: Examples of spectra of polymer-coated specimens (ISO 16773-4:2009)
EN ISO 16862:2006 Paints and varnishes - Evaluation of sag resistance (ISO 16862:2003)
EN ISO 16925:2014 Paints and varnishes - Determination of the resistance of coatings to pressure water-jetting (ISO 16925:2014)
EN ISO 16927:2014 Paints and varnishes - Determination of the overcoatability and recoatability of a coating (ISO 16927:2014)
EN ISO 17132:2007 Paints and varnishes - T-bend test (ISO 17132:2007)
EN ISO 17463:2014 Paints and varnishes - Guidelines for the determination of anticorrosive properties of organic coatings by accelerated cyclic electrochemical technique (ISO 17463:2014)
EN ISO 17872:2007 Paints and varnishes - Guidelines for the introduction of scribe marks through coatings on metallic panels for corrosion testing (ISO 17872:2007)
EN ISO 17895:2005 Paints and varnishes - Determination of the volatile organic compound content of low-VOC emulsion paints (in-can VOC) (ISO 17895:2005)
EN ISO 19334:2011 Binders for paints and varnishes - Gum rosin - Gas-chromatographic analysis (ISO 19334:2010)
EN ISO 20566:2013 Paints and varnishes - Determination of the scratch resistance of a coating system using a laboratory-scale car-wash (ISO 20566:2013)
EN ISO 20567-1:2006 Paints and varnishes - Determination of stone-chip resistance of coatings - Part 1: Multi-impact testing (ISO 20567-1:2005)
EN ISO 20567-2:2006 Paints and varnishes - Determination of stone-chip resistance of coatings - Part 2: Single-impact test with a guided impact body (ISO 20567-2:2005)
EN ISO 20567-3:2012 Paints and varnishes - Determination of stone-chip resistance of coatings - Part 3: Single-impact test with a free-flying impact body (ISO 20567-3:2012)
EN ISO 21227-1:2003 Paints and varnishes - Evaluation of defects on coated surfaces using optical imaging - Part 1: General guidance (ISO 21227-1:2003)
EN ISO 21227-2:2006 Paints and varnishes - Evaluation of defects on coated surfaces using optical imaging - Part 2: Evaluation procedure for multi-impact stone-chipping test (ISO 21227-2:2006)
EN ISO 21227-3:2007 Paints and varnishes - Evaluation of defects on coated surfaces using optical imaging - Part 3: Evaluation of delamination and corrosion around a scribe (ISO 21227-3:2007)
EN ISO 21227-4:2008 Paints and varnishes - Evaluation of defects on coated surfaces using optical imaging - Part 4: Evaluation of filiform corrosion (ISO 21227-4:2008)
EN 23270:1991 Paints and varnishes and their raw materials - Temperatures and humidities for conditioning and testing (ISO 3270:1984)
EN ISO 28199-1:2009 Paints and varnishes - Evaluation of properties of coating systems related to the application process - Part 1: Relevant vocabulary and preparation of test panels (ISO 28199-1:2009)
EN ISO 28199-1:2009/AC:2009 Paints and varnishes - Evaluation of properties of coating systems related to the application process - Part 1: Relevant vocabulary and preparation of test panels - Technical Corrigendum 1 (ISO 28199-1:2009/Cor 1:2009) - missing
EN ISO 23811:2009 Paints and varnishes - Determination of percentage volume of non-volatile matter by measuring the non-volatile matter content and the density of the coating material, and calculation of the theoretical spreading rate (ISO 23811:2009)
EN ISO 28199-2:2009 Paints and varnishes - Evaluation of properties of coating systems related to the application process - Part 2: Colour stability, process hiding power, re-dissolving, overspray absorption, wetting, surface texture and mottling (ISO 28199-2:2009)
EN ISO 28199-3:2009 Paints and varnishes - Evaluation of properties of coating systems related to the application process - Part 3: Visual assessment of sagging, formation of bubbles, pinholing and hiding power (ISO 28199-3:2009)
EN ISO 29601:2011 Paints and varnishes - Corrosion protection by protective paint systems - Assessment of porosity in a dry film (ISO 29601:2011)
or
