Results 1 to 10 of 10
Thread: ISO Collection 129/300:ISO/TC 35 - Paints and varnishes
    full list:
    Standards and projects under the direct responsibility of ISO/TC 35 Secretariat
    ISO 4618:2014 Paints and varnishes -- Terms and definitions
    ISO 4619:1998 Driers for paints and varnishes
    ISO 4626:1980 Volatile organic liquids -- Determination of boiling range of organic solvents used as raw materials
    ISO 11890-1:2007 Paints and varnishes -- Determination of volatile organic compound (VOC) content -- Part 1: Difference method
    ISO 11890-2:2013 Paints and varnishes -- Determination of volatile organic compound (VOC) content -- Part 2: Gas-chromatographic method
    ISO 17895:2005 Paints and varnishes -- Determination of the volatile organic compound content of low-VOC emulsion paints (in-can VOC)
    General test methods for paints and varnishes
    ISO 1513:2010 Paints and varnishes -- Examination and preparation of test samples
    ISO 1514:2016 Paints and varnishes -- Standard panels for testing
    ISO 1518-1:2011 Paints and varnishes -- Determination of scratch resistance -- Part 1: Constant-loading method
    ISO 1518-2:2011 Paints and varnishes -- Determination of scratch resistance -- Part 2: Variable-loading method
    ISO 1519:2011 Paints and varnishes -- Bend test (cylindrical mandrel)
    ISO 1520:2006 Paints and varnishes -- Cupping test
    ISO 1522:2006 Paints and varnishes -- Pendulum damping test
    ISO 1524:2013 Paints* varnishes and printing inks -- Determination of fineness of grind
    ISO 2409:2013 Paints and varnishes -- Cross-cut test
    ISO 2431:2011 Paints and varnishes -- Determination of flow time by use of flow cups
    ISO 2808:2007 Paints and varnishes -- Determination of film thickness
    ISO 2810:2004 Paints and varnishes -- Natural weathering of coatings -- Exposure and assessment
    ISO 2811-1:2016 Paints and varnishes -- Determination of density -- Part 1: Pycnometer method
    ISO 2811-2:2011 Paints and varnishes -- Determination of density -- Part 2: Immersed body (plummet) method
    ISO 2811-3:2011 Paints and varnishes -- Determination of density -- Part 3: Oscillation method
    ISO 2811-4:2011 Paints and varnishes -- Determination of density -- Part 4: Pressure cup method
    ISO 2812-1:2007 Paints and varnishes -- Determination of resistance to liquids -- Part 1: Immersion in liquids other than water
    ISO 2812-2:2007 Paints and varnishes -- Determination of resistance to liquids -- Part 2: Water immersion method
    ISO 2812-3:2012 Paints and varnishes -- Determination of resistance to liquids -- Part 3: Method using an absorbent medium
    ISO 2812-4:2007 Paints and varnishes -- Determination of resistance to liquids -- Part 4: Spotting methods
    ISO 2812-5:2007 Paints and varnishes -- Determination of resistance to liquids -- Part 5: Temperature-gradient oven method
    ISO 2813:2014 Paints and varnishes -- Determination of gloss value at 20 degrees* 60 degrees and 85 degrees
    ISO 2815:2003 Paints and varnishes -- Buchholz indentation test
    ISO 2884-1:1999 Paints and varnishes -- Determination of viscosity using rotary viscometers -- Part 1: Cone-and-plate viscometer operated at a high rate of shear
    ISO 2884-2:2003 Paints and varnishes -- Determination of viscosity using rotary viscometers -- Part 2: Disc or ball viscometer operated at a specified speed
    ISO 3219:1993 Plastics -- Polymers/resins in the liquid state or as emulsions or dispersions -- Determination of viscosity using a rotational viscometer with defined shear rate
    ISO 3233-1:2013 Paints and varnishes -- Determination of the percentage volume of non-volatile matter -- Part 1: Method using a coated test panel to determine non-volatile matter and to determine dry film density by the Archimedes principle
    ISO 3233-2:2014 Paints and varnishes -- Determination of the percentage volume of non-volatile matter -- Part 2: Method using the determination of non-volatile-matter content in accordance with ISO 3251 and determination of dry film density on coated test panels by the A
    ISO 3233-3:2015 Paints and varnishes -- Determination of the percentage volume of non-volatile matter -- Part 3: Determination by calculation from the non-volatile-matter content determined in accordance with ISO 3251* the density of the coating material and the density
    ISO 3248:2016 Paints and varnishes -- Determination of the effect of heat
    ISO 3270:1984 Paints and varnishes and their raw materials -- Temperatures and humidities for conditioning and testing
    ISO 3668:1998 Paints and varnishes -- Visual comparison of the colour of paints
    ISO 4623-1:2000 Paints and varnishes -- Determination of resistance to filiform corrosion -- Part 1: Steel substrates
    ISO 4623-2:2016 Paints and varnishes -- Determination of resistance to filiform corrosion -- Part 2: Aluminium substrates
    ISO 4624:2016 Paints and varnishes -- Pull-off test for adhesion
    ISO 4628-1:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 1: General introduction and designation system
    ISO 4628-2:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 2: Assessment of degree of blistering
    ISO 4628-3:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 3: Assessment of degree of rusting
    ISO 4628-4:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 4: Assessment of degree of *****ing
    ISO 4628-5:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 5: Assessment of degree of flaking
    ISO 4628-6:2011 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 6: Assessment of degree of chalking by tape method
    ISO 4628-7:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 7: Assessment of degree of chalking by velvet method
    ISO 4628-8:2012 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 8: Assessment of degree of delamination and corrosion around a scribe or other artifici
    ISO 4628-10:2016 Paints and varnishes -- Evaluation of degradation of coatings -- Designation of quantity and size of defects* and of intensity of uniform changes in appearance -- Part 10: Assessment of degree of filiform corrosion
    ISO 6270-1:1998 Paints and varnishes -- Determination of resistance to humidity -- Part 1: Continuous condensation
    ISO 6270-2:2005 Paints and varnishes -- Determination of resistance to humidity -- Part 2: Procedure for exposing test specimens in condensation-water atmospheres
    ISO 6272-1:2011 Paints and varnishes -- Rapid-deformation (impact resistance) tests -- Part 1: Falling-weight test* large-area indenter
    ISO 6272-2:2011 Paints and varnishes -- Rapid-deformation (impact resistance) tests -- Part 2: Falling-weight test* small-area indenter
    ISO 6504-1:1983 Paints and varnishes -- Determination of hiding power -- Part 1: Kubelka-Munk method for white and light-coloured paints
    ISO 6504-3:2006 Paints and varnishes -- Determination of hiding power -- Part 3: Determination of contrast ratio of light-coloured paints at a fixed spreading rate
    ISO 6860:2006 Paints and varnishes -- Bend test (conical mandrel)
    ISO 7783:2011 Paints and varnishes -- Determination of water-vapour transmission properties -- Cup method
    ISO 7784-1:2016 Paints and varnishes -- Determination of resistance to abrasion -- Part 1: Method with abrasive-paper covered wheels and rotating test specimen
    ISO 7784-2:2016 Paints and varnishes -- Determination of resistance to abrasion -- Part 2: Method with abrasive rubber wheels and rotating test specimen
    ISO 7784-3:2016 Paints and varnishes -- Determination of resistance to abrasion -- Part 3: Method with abrasive-paper covered wheel and linearly reciprocating test specimen
    ISO 8130-1:1992 Coating powders -- Part 1: Determination of particle size distribution by sieving
    ISO 8130-2:1992 Coating powders -- Part 2: Determination of density by gas comparison pyknometer (referee method)
    ISO 8130-3:1992 Coating powders -- Part 3: Determination of density by liquid displacement pyknometer
    ISO 8130-4:1992 Coating powders -- Part 4: Calculation of lower explosion limit
    ISO 8130-4:1992/Cor 1:1993 Coating powders -- Part 4: Calculation of lower explosion limit
    ISO 8130-5:1992 Coating powders -- Part 5: Determination of flow properties of a powder/air mixture
    ISO 8130-6:1992 Coating powders -- Part 6: Determination of gel time of thermosetting coating powders at a given temperature
    ISO 8130-6:1992/Amd 1:1998 Coating powders -- Part 6: Determination of gel time of thermosetting coating powders at a given temperature
    ISO 8130-7:1992 Coating powders -- Part 7: Determination of loss of mass on stoving
    ISO 8130-8:1994 Coating powders -- Part 8: Assessment of the storage stability of thermosetting powders
    ISO 8130-9:1992 Coating powders -- Part 9: Sampling
    ISO 8130-10:1998 Coating powders -- Part 10: Determination of deposition efficiency
    ISO 8130-11:1997 Coating powders -- Part 11: Inclined-plane flow test
    ISO 8130-12:1998 Coating powders -- Part 12: Determination of compatibility
    ISO 8130-13:2001 Coating powders -- Part 13: Particle size analysis by laser diffraction
    ISO 8130-14:2004 Coating powders -- Part 14: Terminology
    ISO 9117-1:2009 Paints and varnishes -- Drying tests -- Part 1: Determination of through-dry state and through-dry time
    ISO 9117-2:2010 Paints and varnishes -- Drying tests -- Part 2: Pressure test for stackability
    ISO 9117-3:2010 Paints and varnishes -- Drying tests -- Part 3: Surface-drying test using ballotini
    ISO 9117-4:2012 Paints and varnishes -- Drying tests -- Part 4: Test using a mechanical recorder
    ISO 9117-5:2012 Paints and varnishes -- Drying tests -- Part 5: Modified Bandow-Wolff test
    ISO 9117-6:2012 Paints and varnishes -- Drying tests -- Part 6: Print-free test
    ISO 9514:2005 Paints and varnishes -- Determination of the pot life of multicomponent coating systems -- Preparation and conditioning of samples and guidelines for testing
    ISO 10890:2010 Paints and varnishes -- Modelling of biocide release rate from antifouling paints by mass-balance calculation
    ISO 11503:1995 Paints and varnishes -- Determination of resistance to humidity (intermittent condensation)
    ISO 11997-1:2005 Paints and varnishes -- Determination of resistance to cyclic corrosion conditions -- Part 1: Wet (salt fog)/dry/humidity
    ISO 11997-2:2013 Paints and varnishes -- Determination of resistance to cyclic corrosion conditions -- Part 2: Wet (salt fog)/dry/humidity/UV light
    ISO 11998:2006 Paints and varnishes -- Determination of wet-scrub resistance and cleanability of coatings
    ISO 12013-1:2012 Paints and varnishes -- Determination of curing characteristics using a free damped oscillation method -- Part 1: Start temperature of the curing reaction
    ISO 12013-2:2012 Paints and varnishes -- Determination of curing characteristics using a free damped oscillation method -- Part 2: Glass transition temperature
    ISO 12137:2011 Paints and varnishes -- Determination of mar resistance
    ISO 13076:2012 Paints and varnishes -- Lighting and procedure for visual assessments of coatings
    ISO 13129:2012 Paints and varnishes -- Electrochemical measurement of the protection provided to steel by paint coatings -- Current interrupter (CI) technique* relaxation voltammetry (RV) technique and DC transient (DCT) measurements
    ISO 13803:2014 Paints and varnishes -- Determination of haze on paint films at 20 degrees
    ISO 14680-1:2000 Paints and varnishes -- Determination of pigment content -- Part 1: Centrifuge method
    ISO 14680-2:2000 Paints and varnishes -- Determination of pigment content -- Part 2: Ashing method
    ISO 14680-3:2000 Paints and varnishes -- Determination of pigment content -- Part 3: Filtration method
    ISO 15091:2012 Paints and varnishes -- Determination of electrical conductivity and resistance
    ISO 15110:2013 Paints and varnishes -- Artificial weathering including acidic deposition
    ISO 15181-1:2007 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 1: General method for extraction of biocides
    ISO 15181-2:2007 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 2: Determination of copper-ion concentration in the extract and calculation of the release rate
    ISO 15181-3:2007 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 3: Calculation of the zinc ethylene-bis(dithiocarbamate) (zineb) release rate by determination of the concentration of ethylenethiourea in the extract
    ISO 15181-4:2008 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 4: Determination of pyridine-triphenylborane (PTPB) concentration in the extract and calculation of the release rate
    ISO 15181-5:2008 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 5: Calculation of the tolylfluanid and dichlofluanid release rate by determination of the concentration of dimethyltolylsulfamide (DMST) and dimethylphenylsu
    ISO 15181-6:2012 Paints and varnishes -- Determination of release rate of biocides from antifouling paints -- Part 6: Determination of tralopyril release rate by quantitation of its degradation product in the extract
    ISO 15184:2012 Paints and varnishes -- Determination of film hardness by pencil test
    ISO 15528:2013 Paints* varnishes and raw materials for paints and varnishes -- Sampling
    ISO 15710:2002 Paints and varnishes -- Corrosion testing by alternate immersion in and removal from a buffered sodium chloride solution
    ISO 15711:2003 Paints and varnishes -- Determination of resistance to cathodic disbonding of coatings exposed to sea water
    ISO 16053:2010 Paints and varnishes -- Coating materials and coating systems for exterior wood -- Natural weathering test
    ISO 16474-1:2013 Paints and varnishes -- Methods of exposure to laboratory light sources -- Part 1: General guidance
    ISO 16474-2:2013 Paints and varnishes -- Methods of exposure to laboratory light sources -- Part 2: Xenon-arc lamps
    ISO 16474-3:2013 Paints and varnishes -- Methods of exposure to laboratory light sources -- Part 3: Fluorescent UV lamps
    ISO 16474-4:2013 Paints and varnishes -- Methods of exposure to laboratory light sources -- Part 4: Open-flame carbon-arc lamps
    ISO 16773-1:2016 Electrochemical impedance spectroscopy (EIS) on coated and uncoated metallic specimens -- Part 1: Terms and definitions
    ISO 16773-2:2016 Electrochemical impedance spectroscopy (EIS) on coated and uncoated metallic specimens -- Part 2: Collection of data
    ISO 16773-3:2016 Electrochemical impedance spectroscopy (EIS) on coated and uncoated metallic specimens -- Part 3: Processing and analysis of data from dummy cells
    ISO 16773-4:2009 Paints and varnishes -- Electrochemical impedance spectroscopy (EIS) on high-impedance coated specimens -- Part 4: Examples of spectra of polymer-coated specimens
    ISO 16862:2003 Paints and varnishes -- Evaluation of sag resistance
    ISO 16925:2014 Paints and varnishes -- Determination of the resistance of coatings to pressure water-jetting
    ISO 16927:2014 Paints and varnishes -- Determination of the overcoatability and recoatability of a coating
    ISO 17132:2007 Paints and varnishes -- T-bend test
    ISO 17463:2014 Paints and varnishes -- Guidelines for the determination of anticorrosive properties of organic coatings by accelerated cyclic electrochemical technique
    ISO 17872:2007 Paints and varnishes -- Guidelines for the introduction of scribe marks through coatings on metallic panels for corrosion testing
    ISO/TS 19397:2015 Determination of the film thickness of coatings using an ultrasonic gage
    ISO 19399:2016 Paints and varnishes -- Wedge-cut method for determination of film thickness (scribe and drill method)
    ISO 20566:2013 Paints and varnishes -- Determination of the scratch resistance of a coating system using a laboratory-scale car-wash
    ISO 20567-1:2005 Paints and varnishes -- Determination of stone-chip resistance of coatings -- Part 1: Multi-impact testing
    ISO 20567-2:2005 Paints and varnishes -- Determination of stone-chip resistance of coatings -- Part 2: Single-impact test with a guided impact body
    ISO 20567-3:2012 Paints and varnishes -- Determination of stone-chip resistance of coatings -- Part 3: Single-impact test with a free-flying impact body
    ISO 21227-1:2003 Paints and varnishes -- Evaluation of defects on coated surfaces using optical imaging -- Part 1: General guidance
    ISO 21227-2:2006 Paints and varnishes -- Evaluation of defects on coated surfaces using optical imaging -- Part 2: Evaluation procedure for multi-impact stone-chipping test
    ISO 21227-3:2007 Paints and varnishes -- Evaluation of defects on coated surfaces using optical imaging -- Part 3: Evaluation of delamination and corrosion around a scribe
    ISO 21227-4:2008 Paints and varnishes -- Evaluation of defects on coated surfaces using optical imaging -- Part 4: Evaluation of filiform corrosion
    ISO 28199-1:2009 Paints and varnishes -- Evaluation of properties of coating systems related to the application process -- Part 1: Relevant vocabulary and preparation of test panels
    ISO 28199-1:2009/Cor 1:2009 Paints and varnishes -- Evaluation of properties of coating systems related to the application process -- Part 1: Relevant vocabulary and preparation of test panels
    ISO 28199-2:2009 Paints and varnishes -- Evaluation of properties of coating systems related to the application process -- Part 2: Colour stability* process hiding power* re-dissolving* overspray absorption* wetting* surface texture and mottling
    ISO 28199-3:2009 Paints and varnishes -- Evaluation of properties of coating systems related to the application process -- Part 3: Visual assessment of sagging* formation of bubbles* pinholing and hiding power
    Test methods for binders for paints and varnishes
    ISO 150:2006 Raw* refined and boiled linseed oil for paints and varnishes -- Specifications and methods of test
    ISO 276:2002 Binders for paints and varnishes -- Linseed stand oil -- Requirements and methods of test
    ISO 277:2002 Binders for paints and varnishes -- Raw tung oil -- Requirements and methods of test
    ISO 3251:2008 Paints* varnishes and plastics -- Determination of non-volatile-matter content
    ISO 3681:1996 Binders for paints and varnishes -- Determination of saponification value -- Titrimetric method
    ISO 4625-1:2004 Binders for paints and varnishes -- Determination of softening point -- Part 1: Ring-and-ball method
    ISO 4625-2:2004 Binders for paints and varnishes -- Determination of softening point -- Part 2: Cup-and-ball method
    ISO 4629-1:2016 Binders for paints and varnishes -- Determination of hydroxyl value -- Part 1: Titrimetric method without using a catalyst
    ISO 4629-2:2016 Binders for paints and varnishes -- Determination of hydroxyl value -- Part 2: Titrimetric method using a catalyst
    ISO 4630:2015 Clear liquids -- Estimation of colour by the Gardner colour scale
    ISO 6271:2015 Clear liquids -- Estimation of colour by the platinum-cobalt colour scale
    ISO 6744-1:1999 Binders for paints and varnishes -- Alkyd resins -- Part 1: General methods of test
    ISO 6744-2:1999 Binders for paints and varnishes -- Alkyd resins -- Part 2: Determination of phthalic anhydride content
    ISO 6744-3:1999 Binders for paints and varnishes -- Alkyd resins -- Part 3: Determination of unsaponifiable matter content
    ISO 6744-4:1999 Binders for paints and varnishes -- Alkyd resins -- Part 4: Determination of fatty acid content
    ISO 7142:2007 Binders for paints and varnishes -- Epoxy resins -- General methods of test
    ISO 7143:2007 Binders for paints and varnishes -- Methods of test for characterizing water-based binders
    ISO 8623:2015 Tall-oil fatty acids for paints and varnishes -- Test methods and characteristic values
    ISO 10283:2007 Binders for paints and varnishes -- Determination of monomeric diisocyanates in isocyanate resins
    ISO 11668:1997 Binders for paints and varnishes -- Chlorinated polymerization resins -- General methods of test
    ISO 11908:1996 Binders for paints and varnishes -- Amino resins -- General methods of test
    ISO 11909:2007 Binders for paints and varnishes -- Polyisocyanate resins -- General methods of test
    ISO 13632:2012 Binders for paints and varnishes -- Rosin -- Sampling and sample preparation for colour measurement
    ISO 13885-1:2008 Binders for paints and varnishes -- Gel permeation chromatography (GPC) -- Part 1: Tetrahydrofuran (THF) as eluent
    ISO 14446:1999 Binders for paints and varnishes -- Determination of the viscosity of industrial cellulose nitrate solutions and classification of such solutions
    ISO 15234:1999 Paints and varnishes -- Testing of formaldehyde-emitting coatings and melamine foams -- Determination of the steady-state concentration of formaldehyde in a small test chamber
    ISO 15715:2003 Binders for paints and varnishes -- Determination of turbidity
    ISO 15880:2000 Paints* varnishes and binders -- Determination of MEQ value of water-based coating materials and binders
    ISO 16482-1:2013 Binders for paints and varnishes -- Determination of the non-volatile-matter content of aqueous rosin-resin dispersions -- Part 1: Oven method
    ISO 16482-2:2013 Binders for paints and varnishes -- Determination of the non-volatile-matter content of aqueous rosin-resin dispersions -- Part 2: Microwave method
    ISO 16805:2003 Binders for paints and varnishes -- Determination of glass transition temperature
    ISO 19334:2010 Binders for paints and varnishes -- Gum rosin -- Gas-chromatographic analysis
    Preparation of steel substrates before application of paints and related products
    ISO 8501-1:2007 Preparation of steel substrates before application of paints and related products -- Visual assessment of surface cleanliness -- Part 1: Rust grades and preparation grades of uncoated steel substrates and of steel substrates after overall removal of previ
    ISO 8501-2:1994 Preparation of steel substrates before application of paints and related products -- Visual assessment of surface cleanliness -- Part 2: Preparation grades of previously coated steel substrates after localized removal of previous coatings
    ISO 8501-3:2006 Preparation of steel substrates before application of paints and related products -- Visual assessment of surface cleanliness -- Part 3: Preparation grades of welds* edges and other areas with surface imperfections
    ISO 8501-4:2006 Preparation of steel substrates before application of paints and related products -- Visual assessment of surface cleanliness -- Part 4: Initial surface conditions* preparation grades and flash rust grades in connection with high-pressure water jetting
    ISO 8502-2:2005 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 2: Laboratory determination of chloride on cleaned surfaces
    ISO 8502-3:1992 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 3: Assessment of dust on steel surfaces prepared for painting (pressure-sensitive tape method)
    ISO 8502-4:1993 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 4: Guidance on the estimation of the probability of condensation prior to paint application
    ISO 8502-5:1998 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 5: Measurement of chloride on steel surfaces prepared for painting (ion detection tube method)
    ISO 8502-6:2006 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 6: Extraction of soluble contaminants for analysis -- The Bresle method
    ISO 8502-9:1998 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 9: Field method for the conductometric determination of water-soluble salts
    ISO 8502-11:2006 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 11: Field method for the turbidimetric determination of water-soluble sulfate
    ISO 8502-12:2003 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 12: Field method for the titrimetric determination of water-soluble ferrous ions
    ISO 8503-1:2012 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 1: Specifications and definitions for ISO surface profile comparators for the assessment of ab
    ISO 8503-2:2012 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 2: Method for the grading of surface profile of abrasive blast-cleaned steel -- Comparator pro
    ISO 8503-3:2012 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 3: Method for the calibration of ISO surface profile comparators and for the determination of
    ISO 8503-4:2012 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 4: Method for the calibration of ISO surface profile comparators and for the determination of
    ISO 8503-5:2003 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 5: Replica tape method for the determination of the surface profile
    ISO 8504-1:2000 Preparation of steel substrates before application of paints and related products -- Surface preparation methods -- Part 1: General principles
    ISO 8504-2:2000 Preparation of steel substrates before application of paints and related products -- Surface preparation methods -- Part 2: Abrasive blast-cleaning
    ISO 8504-3:1993 Preparation of steel substrates before application of paints and related products -- Surface preparation methods -- Part 3: Hand- and power-tool cleaning
    ISO 11124-1:1993 Preparation of steel substrates before application of paints and related products -- Specifications for metallic blast-cleaning abrasives -- Part 1: General introduction and classification
    ISO 11124-2:1993 Preparation of steel substrates before application of paints and related products -- Specifications for metallic blast-cleaning abrasives -- Part 2: Chilled-iron grit
    ISO 11124-3:1993 Preparation of steel substrates before application of paints and related products -- Specifications for metallic blast-cleaning abrasives -- Part 3: High-carbon cast-steel shot and grit
    ISO 11124-4:1993 Preparation of steel substrates before application of paints and related products -- Specifications for metallic blast-cleaning abrasives -- Part 4: Low-carbon cast-steel shot
    ISO 11125-1:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 1: Sampling
    ISO 11125-2:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 2: Determination of particle size distribution
    ISO 11125-3:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 3: Determination of hardness
    ISO 11125-4:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 4: Determination of apparent density
    ISO 11125-5:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 5: Determination of percentage defective particles and of microstructure
    ISO 11125-6:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 6: Determination of foreign matter
    ISO 11125-7:1993 Preparation of steel substrates before application of paints and related products -- Test methods for metallic blast-cleaning abrasives -- Part 7: Determination of moisture
    ISO 11126-1:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 1: General introduction and classification
    ISO 11126-1:1993/Cor 1:1997 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 1: General introduction and classification
    ISO 11126-1:1993/Cor 2:1997 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 1: General introduction and classification
    ISO 11126-3:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 3: Copper refinery slag
    ISO 11126-4:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 4: Coal furnace slag
    ISO 11126-5:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 5: Nickel refinery slag
    ISO 11126-6:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 6: Iron furnace slag
    ISO 11126-7:1995 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 7: Fused aluminium oxide
    ISO 11126-7:1995/Cor 1:1999 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 7: Fused aluminium oxide
    ISO 11126-8:1993 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 8: Olivine sand
    ISO 11126-9:1999 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 9: Staurolite
    ISO 11126-10:2000 Preparation of steel substrates before application of paints and related products -- Specifications for non-metallic blast-cleaning abrasives -- Part 10: Almandite garnet
    ISO 11127-1:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 1: Sampling
    ISO 11127-2:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 2: Determination of particle size distribution
    ISO 11127-3:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 3: Determination of apparent density
    ISO 11127-4:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 4: Assessment of hardness by a glass slide test
    ISO 11127-5:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 5: Determination of moisture
    ISO 11127-6:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 6: Determination of water-soluble contaminants by conductivity measurement
    ISO 11127-7:2011 Preparation of steel substrates before application of paints and related products -- Test methods for non-metallic blast-cleaning abrasives -- Part 7: Determination of water-soluble chlorides
    Protective paint systems for steel structures
    ISO 12944-1:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 1: General introduction
    ISO 12944-2:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 2: Classification of environments
    ISO 12944-3:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 3: Design considerations
    ISO 12944-4:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 4: Types of surface and surface preparation
    ISO 12944-5:2007 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 5: Protective paint systems
    ISO 12944-6:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 6: Laboratory performance test methods
    ISO 12944-7:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 7: Execution and supervision of paint work
    ISO 12944-8:1998 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Part 8: Development of specifications for new work and maintenance
    ISO 15741:2016 Paints and varnishes -- Friction-reduction coatings for the interior of on- and offshore steel pipelines for non-corrosive gases
    ISO 16276-1:2007 Corrosion protection of steel structures by protective paint systems -- Assessment of* and acceptance criteria for* the adhesion/cohesion (fracture strength) of a coating -- Part 1: Pull-off testing
    ISO 16276-2:2007 Corrosion protection of steel structures by protective paint systems -- Assessment of* and acceptance criteria for* the adhesion/cohesion (fracture strength) of a coating -- Part 2: Cross-cut testing and X-cut testing
    ISO 19840:2012 Paints and varnishes -- Corrosion protection of steel structures by protective paint systems -- Measurement of* and acceptance criteria for* the thickness of dry films on rough surfaces
    ISO 20340:2009 Paints and varnishes -- Performance requirements for protective paint systems for offshore and related structures
    ISO 29601:2011 Paints and varnishes -- Corrosion protection by protective paint systems -- Assessment of porosity in a dry film
    the only one missing is:
    links:
    or
    Re: ISO/TC 35 - Paints and varnishes
    Re: ISO Collection 129/300:ISO/TC 35 - Paints and varnishes
    ISO changed the structure of this sector* but standards stayed the same in totally...
    update:
    added missing/new standards:
    ISO 8502-4:2017 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 4: Guidance on the estimation of the probability of condensation prior to paint application
    ISO 8502-3:2017 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 3: Assessment of dust on steel surfaces prepared for painting (pressure-sensitive tape method)
    ISO 8502-2:2017 Preparation of steel substrates before application of paints and related products -- Tests for the assessment of surface cleanliness -- Part 2: Laboratory determination of chloride on cleaned surfaces
    the new missing one is:
    ISO 8503-5:2017 Preparation of steel substrates before application of paints and related products -- Surface roughness characteristics of blast-cleaned steel substrates -- Part 5: Replica tape method for the determination of the surface profile
    new link:
  6. Re: ISO Collection 129/300:ISO/TC 35 - Paints and varnishes
    Goodnight
    Please upload these rules* thank you in advance.
    1.- ISO 11126-1:1993/Cor 2:1997
    2.- ISO 11126-7:1995/Cor 1:1999
    3.- ISO 8130-6:1992/Amd 1:1998
    4.- ISO 8130-4:1992/Cor 1:1993
    Best regards and thanks
    update:
    BQ or missing or new:
    ISO 16773-4:2017 Electrochemical impedance spectroscopy (EIS) on coated and uncoated metallic specimens -- Part 4: Examples of spectra of polymer-coated and uncoated specimens
    ISO 20567-1:2017 Paints and varnishes -- Determination of stone-chip resistance of coatings -- Part 1: Multi-impact testing
    ISO 20567-2:2017 Paints and varnishes -- Determination of stone-chip resistance of coatings -- Part 2: Single-impact test with a guided impact body
    ISO 3668:2017 Paints and varnishes -- Visual comparison of colour of paints
  9. Re: ISO Collection 129/300:ISO/TC 35 - Paints and varnishes
    Hi* Is it possible to post the link again iam not able to access it. Thanks.
    if you take a better look can see it's a board error so use logic and reply with quote at post and you will get the clear mediafire link
  11. Re: ISO Collection 129/300:ISO/TC 35 - Paints and varnishes
    i did not understand* what did you mean??
    Kindly upload ISO 19277-2018 Qualification testing and acceptance criteria for protective coating systems under insulation. best regards.
  1. CEN Standars Collection 56/370: CEN TC 139: Paints & Varnishes
    Last Post: 11-24-2017, 12:25 AM
  2. Failure Analysis of Paints and Coatings
    By Han Ah kwang in forum Materials Science &Corrosion
    Last Post: 02-23-2015, 07:33 AM
  3. Automotive Paints and Coatings
    By dongono in forum General Engineering
    Last Post: 01-14-2015, 03:32 AM
  4. Failure Analysis of Paints and Coatings
    Last Post: 12-27-2014, 01:18 PM
  5. Automotive Paints and Coatings
    By Derek1 in forum Petrochemical
    Last Post: 01-07-2009, 02:32 PM
