Results 1 to 8 of 8
Thread: Lap welded bottom Plates API 650. Lap width
  1. Re: Lap welded bottom Plates API 650. Lap width
    The english is funny and does not serve the purpose. the word "need not exceed" is actually meant to be " the minimum".
    See also technical queries answered by API. There is reference to bottom lap welds.
    10th - Nov. 1998
    3.1.3.5
    650-I-37/03
    Question : Is it the intent of 3.1.3.5 to limit the maximum lap of a double welded lap joint to 2 in. and a single welded lap joint to 1 in. If not, is there a maximum lap requirement for single welded lap joint bottoms and roofs? Would this constraint, if any, also apply to bottom or roof repair or replacements governed by API 653.
    Answer: No.
    10th - Nov. 1998
    3.1.3.5
    650-I-49/03
    Question: Section 3.1.3.5 of API 650 specifies minimum lap joint dimensions. Is there any limit on the maximum width of a lap joint?2: Can a lap joint consisting of two (2) ¼ in. plates be lapped 3 in.?
    Answer: API Standard 650 does not address maximum lap.2: Yes. Any lap that exceeds the minimum is acceptable. Refer to 3.1.3.5.
    I hope this answers you question.
    Attached Files Attached Files
    Quote Originally Posted by adamjin View Post
    10th - Nov. 1998
    3.1.3.5
    650-I-37/03
    Answer: No.
    10th - Nov. 1998
    3.1.3.5
    650-I-49/03
    Thanks a lot adamjin!!!
    Just I have looking for. I will download just now the PDF and read it.
    I always have understood the same as "Tessios". In my mother language, we call this expressions "juego de palabras / play on words or PUN" because I understand that we never lap more than 25 mm in single lap welded joints, but it "crash" against the first part of the paragraph (five times...).
    So that, we thought: right; we have two 6 mm thickness plates, single lap welded...25 mm minimum and...25 mm maximum!! (due to my mistake translating "need not to exceed" as maximum overlap) That's a nonsense and the reason for my question.
    Thanks again
  1. How to calculate Slots width in a slotted liner!
    By joseluismondragon in forum Drilling And Workover
    Last Post: 07-09-2015, 12:02 PM
  2. Multistage orifice plates
    By amsats in forum Pipeline And Fluid Flow
    Last Post: 02-09-2014, 11:37 AM
  3. Replies: 0
    Last Post: 04-14-2013, 01:17 PM
  4. Replies: 0
    Last Post: 09-23-2010, 05:35 PM
