Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 29
Thread: HEI Standards for Steam Surface Condensers
    Dear All
    I am looking for HEI Standards for Steam Surface Condensers 10th or 11th edition.
    can you Please share.
    Re: HEI Standards for Steam Surface Condensers
    Is anyone able to provide the 11th Edition (2012) for HEI Standard 2629 for Steam Surface Condensers?
    Your help would be greatly appreciated.
  5. Re: HEI Standards for Steam Surface Condensers
    see link:
    Thank you engineer79. Your kindness is appreciated.
    I am also having to work with some other outdated HEI standards. I am wondering if you have links for the latest available versions of these HEI standards:
    HEI 2633 Standards for Steam Jet Vacuum Systems, 7th Edition, 2012
    HEI 2854 Performance Standards for Liquid Ring Vacuum Pumps, 4th Edition, 2010
  7. #5
  9. #6
    The addendum 1 for the steam surface condensers appears to be here...
    someone with access please repost
  10. Re: HEI Standards for Steam Surface Condensers
    the addendum is for the old ninth edition; the eleventh edition does not require this addendum.
    Quote Originally Posted by Marty Thompson View Post
  11. Re: HEI Standards for Steam Surface Condensers
    *** deleted ***
  12. Re: HEI Standards for Steam Surface Condensers
    only have 2854, see link below:
    2633 does not exist; based on latest catalogue, steam jet vacuum systems is 2866; however, i do not have it or any older editions.
    Quote Originally Posted by marwanab View Post
  13. #10
    OK, that is the 9th. When you download the 11th contents from the HEI site, it appears to have an addendum 1 dated 2014
    look at this downloaded from there... the last page
  14. Re: HEI Standards for Steam Surface Condensers
    oh... i'm not aware of the 2014 addendum for the eleventh edition.
    thank you for pointing out, marty.
    unfortunately, the set of data i have only is only dated up til 2012.
    so, i do not have the addendum 1 for the eleventh edition.
    maybe others can help?
  16. #12
    It appears that the
    Standards and Typical Specifications for Tray-Type Deaerators - 9th Ed. 2011 Contents also has a 2014 addendum 1
  1. ASME PTC 12.2 Performance Test Code for Steam Surface Condensers
    By AliDouceur in forum Mechanical Engineering
    Last Post: 06-04-2017, 07:53 AM
  2. HEI Standards for Steam Surface Condensers
    By AMinati in forum Mechanical Engineering
    Last Post: 09-29-2014, 06:08 AM
  3. Replies: 0
    Last Post: 02-21-2014, 12:02 AM
  4. Standards for Steam Surface Condensers
    By foxawan in forum Mechanical Engineering
    Last Post: 04-15-2010, 03:22 PM
  5. Request for HEI Code: "Standards for Steam Surface Condensers"
    By guilhermesempionato in forum Mechanical Engineering
    Last Post: 02-17-2009, 03:50 PM
