we missing 5 here:
EN 582:1993 Thermal spraying - Determination of tensile adhesive strength
EN 657:2005 Thermal spraying - Terminology, classification
EN 1274:2004 Thermal spraying - Powders - Composition, technical supply conditions
EN 1395-1:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 1: General requirements
EN 1395-2:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 2: Flame spraying including HVOF
EN 1395-3:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 3: Arc spraying
EN 1395-4:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 4: Plasma spraying
EN 1395-5:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 5: Plasma spraying in chambers
EN 1395-6:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 6: Manipulator systems
EN 1395-7:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 7: Powder feed systems
EN ISO 2063:2005 Thermal spraying - Metallic and other inorganic coatings - Zinc, aluminium and their alloys (ISO 2063:2005)
EN ISO 12670:2015 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions (ISO 12670:2011)
EN ISO 12671:2014 Thermal spraying - Thermally sprayed coatings - Symbolic representation on drawings (ISO 12671:2012)
EN ISO 12679:2015 Thermal spraying - Recommendations for thermal spraying (ISO 12679:2011)
EN ISO 12690:2010 Metallic and other inorganic coatings - Thermal spray coordination - Tasks and responsibilities (ISO 12690:2010)
EN ISO 13123:2011 Metallic and other inorganic coatings - Test method of cyclic heating for thermal-barrier coatings under temperature gradient (ISO 13123:2011)
EN 13507:2010 Thermal spraying - Pre-treatment of surfaces of metallic parts and components for thermal spraying
EN 14616:2004 Thermal spraying - Recommendations for thermal spraying
EN ISO 14918:1998 Thermal spraying - Approval testing of thermal sprayers (ISO 14918:1998)
EN ISO 14919:2015 Thermal spraying - Wires, rods and cords for flame and arc spraying - Classification - Technical supply conditions (ISO 14919:2015)
EN ISO 14920:2015 Thermal spraying - Spraying and fusing of self-fluxing alloys (ISO 14920:2015)
EN ISO 14921:2010 Thermal spraying - Procedures for the application of thermally sprayed coatings for engineering components (ISO 14921:2010)
EN ISO 14922-1:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 1: Guidance for selection and use (ISO 14922-1:1999)
EN ISO 14922-2:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 2: Comprehensive quality requirements (ISO 14922-2:1999)
EN ISO 14922-3:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 3: Standard quality requirements (ISO 14922-3:1999)
EN ISO 14922-4:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 4: Elementary quality requirements (ISO 14922-4:1999)
EN ISO 14923:2003 Thermal spraying - Characterization and testing of thermally sprayed coatings (ISO 14923:2003)
EN ISO 14924:2005 Thermal spraying - Post-treatment and finishing of thermally sprayed coatings (ISO 14924:2005)
EN 15311:2007 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions
EN 15339-2:2007 Thermal spraying - Safety requirements for thermal spraying equipment - Part 2: Gas control units
EN 15340:2007 Thermal spraying - Determination of shear load resistance of thermally sprayed coatings
EN 15520:2007 Thermal spraying - Recommendations for constructional design of components with thermally sprayed coatings
CEN/TR 15339-1:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 1: General requirements - missing
CEN/TR 15339-3:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 3: Torches for thermal spraying and their connection and supply units - missing
CEN/TR 15339-4:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 4: Gas and liquid fuel supply - missing
CEN/TR 15339-5:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 5: Powder and wire feed units - missing
CEN/TR 15339-6:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 6: Spray booth, Handling system, Dust collection, Exhaust system, Filter - missing
EN 15648:2009 Thermal spraying - Component related procedure qualification
EN ISO 17834:2003 Thermal spraying - Coatings for protection against corrosion and oxidation at elevated temperatures (ISO 17834:2003)
EN ISO 17836:2004 Thermal spraying - Determination of the deposition efficiency for thermal spraying (ISO 17836:2004)
or
