31 valid edition, 3 standards are missing:
EN 1559-2:2014 Founding - Technical conditions of delivery - Part 2: Additional requirements for steel castings - missing VE
EN 10031:2003 Semi-finished products for forging - Tolerances on dimensions shape and mass
EN 10213:2007 Steel castings for pressure purposes
EN 10213:2007/AC:2008 Steel castings for pressure purposes
EN 10222-1:1998 Steel forgings for pressure purposes - Part 1 : General requirements for open die forgings
EN 10222-1:1998/A1:2002 Steel forgings for pressure purposes - Part 1 : General requirements for open die forgings
EN 10222-2:1999 Steel forgings for pressure purposes - Part 2: Ferritic and martensitic steels with specified elevated temperature properties
EN 10222-2:1999/AC:2000 Steel forgings for pressure purposes - Part 2: Ferritic and martensitic steels with specified elevated temperature properties
EN 10222-3:1998 Steel forgings for pressure purposes - Part 3: Nickel steels with specified low temperature properties
EN 10222-4:1998 Steel forgings for pressure purposes - Part 4: Weldable fine grain steels with high proof strength
EN 10222-4:1998/A1:2001 Steel forgings for pressure purposes - Part 4: Weldable fine grain steels with high proof strength
EN 10222-5:1999 Steel forgings for pressure purposes - Part 5: Martensitic, austenitic and austenitic-ferritic stainless steels
EN 10222-5:1999/AC:2000 Steel forgings for pressure purposes - Part 5: Martensitic, austenitic and austenitic-ferritic stainless steels
EN 10228-1:1999 Non-destructive testing of steel forgings - Part 1: Magnetic particle inspection
EN 10228-2:1998 Non-destructive testing of steel forgings - Part 2: Penetrant testing
EN 10228-3:1998 Non-destructive testing of steel forgings - Part 3: Ultrasonic testing of ferritic or martensitic steel forgings
EN 10228-4:1999 Non-destructive testing of steel forgings - Part 4: Ultrasonic testing of austenitic and austenitic-ferritic stainless steel forgings
EN 10243-1:1999 Steel die forgings - Tolerances on dimensions - Part 1: Drop and vertical press forgings
EN 10243-1:1999/AC:2005 Steel die forgings - Tolerances on dimensions - Part 1: Drop and vertical press forgings
EN 10243-2:1999 Steel die forgings - Tolerances on dimensions - Part 2: Upset forging made on horizontal forging machines
EN 10243-2:1999/AC:2005 Steel die forgings - Tolerances on dimensions - Part 2: Upset forging made on horizontal forging machines
EN 10250-1:1999 Open die steel forgings for general engineering purposes - Part 1: General requirements
EN 10250-2:1999 Open die steel forgings for general engineering purposes - Part 2: Non-alloy quality and special steels
EN 10250-3:1999 Open die steel forgings for general engineering purposes - Part 3: Alloy special steels
EN 10250-4:1999 Open die steel forgings for general engineering purposes - Part 4: Stainless steels
EN 10254:1999 Steel closed die forgings - General technical delivery conditions
EN 10283:2010 Corrosion resistant steel castings
EN 10293: 2015 Steel castings for general engineering uses - missing VE
EN 10295:2002 Heat resistant steel castings
EN 10340:2007 Steel castings for structural uses
EN 10340:2007/AC:2008 Steel castings for structural uses
EN 10349:2009 Steel castings - Austenitic manganese steel castings
EN 10360:2015 Hot, warm or cold forging - Repair conditions prior to delivery - missing VE
EN ISO 11970:2007 Specification and approval of welding procedures for production welding of steel castings (ISO 11970:2001)
or
