4 valid editions are missing...
EN 39:2001 Loose steel tubes for tube and coupler scaffolds - Technical delivery conditions
EN ISO 228-1:2003 Pipe threads where pressure-tight joints are not made on the threads - Part 1: Dimensions, tolerances and designation (ISO 228-1:2000)
EN ISO 228-2:2003 Pipe threads where pressure-tight joints are not made on the threads - Part 2: Verification by means of limit gauges (ISO 228-2:1987)
EN ISO 1127:1996 Stainless steel tubes - Dimensions, tolerances and conventional masses per unit length (ISO 1127:1992)
EN ISO 1179-1:2013 Connections for general use and fluid power - Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing - Part 1: Threaded ports (ISO 1179-1:2013)
EN ISO 1179-2:2013 Connections for general use and fluid power - Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing - Part 2: Heavy-duty (S series) and light-duty (L series) stud ends with elastomeric sealing (type E) (ISO 1179-2:2013)
EN ISO 1179-3:2008 Connections for general use and fluid power - Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing - Part 3: Light-duty (L series) stud ends with sealing by O-ring with retaining ring (types G and H) (ISO 1179-3:2007) - missing
EN ISO 1179-4:2008 Connections for general use and fluid power - Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing - Part 4: Stud ends for general use only with metal-to-metal sealing (type B) (ISO 1179-4:2007) - missing
EN ISO 3183:2012 Petroleum and natural gas industries - Steel pipe for pipeline transportation systems (ISO 3183:2012)
EN ISO 6149-1:2007 Connections for hydraulic fluid power and general use - Ports and stud ends with ISO 261 metric threads and O-ring sealing - Part 1: Ports with truncated housing for O-ring seal (ISO 6149-1:2007)
EN ISO 6149-2:2007 Connections for hydraulic fluid power and general use - Ports and stud ends with ISO 261 metric threads and O-ring sealing - Part 2: Dimensions, design, test methods and requirements for heavy-duty (S series) stud ends (ISO 6149-2:2007)
EN ISO 6149-3:2007 Connections for hydraulic fluid power and general use - Ports and stud ends with ISO 261 metric threads and O-ring sealing - Part 3: Dimensions, design, test methods and requirements for light-duty (L series) stud ends (ISO 6149-3:2006)
EN ISO 6149-4: 2014 Connections for fluid power and general use - Ports and stud ends with ISO 261 metric threads and O-ring sealing - Part 4: Dimensions, design, test methods and requirements for external hex and internal hex port plugs (ISO 6149-4:2006) - missing
EN ISO 8434-1:2007 Metallic tube connections for fluid power and general use - Part 1: 24 degree cone connectors (ISO 8434-1:2007)
EN ISO 8434-1:2007/AC:2009 Metallic tube connections for fluid power and general use - Part 1: 24 degree cone connectors (ISO 8434-1:2007)
EN ISO 8491:2004 Metallic materials - Tube (in full section) - Bend test (ISO 8491:1998)
EN ISO 8492:2013 Metallic materials - Tube - Flattening test (ISO 8492:2013)
EN ISO 8493:2004 Metallic materials - Tube - Drift-expanding test (ISO 8493:1998)
EN ISO 8494:2013 Metallic materials - Tube - Flanging test (ISO 8494:2013)
EN ISO 8495:2013 Metallic materials - Tube - Ring-expanding test (ISO 8495:2013)
EN ISO 8496:2013 Metallic materials - Tube - Ring tensile test (ISO 8496:2013)
EN ISO 9974-1:2000 Connections for general use and fluid power - Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing - Part 1: Threaded ports (ISO 9974-1:1996)
EN ISO 9974-2:2000 Connections for general use and fluid power - Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing - Part 2: Stud ends with elastomeric sealing (type E) (ISO 9974-2:1996)
EN ISO 9974-3:2000 Connections for general use and fluid power - Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing - Part 3: Stud ends with metal-to-metal sealing (type B) (ISO 9974-3:1996)
EN 10216-1:2013 Seamless steel tubes for pressure purposes - Technical delivery conditions - Part 1: Non-alloy steel tubes with specified room temperature properties
EN 10216-2:2013 Seamless steel tubes for pressure purposes - Technical delivery conditions - Part 2: Non-alloy and alloy steel tubes with specified elevated temperature properties
EN 10216-3:2013 Seamless steel tubes for pressure purposes - Technical delivery conditions - Part 3: Alloy fine grain steel tubes
EN 10216-4:2013 Seamless steel tubes for pressure purposes - Technical delivery conditions - Part 4: Non-alloy and alloy steel tubes with specified low temperature properties
EN 10216-5:2013 Seamless steel tubes for pressure purposes - Technical delivery conditions - Part 5: Stainless steel tubes
EN 10217-1:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 1: Non-alloy steel tubes with specified room temperature properties
EN 10217-1:2002/A1:2005 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 1: Non-alloy steel tubes with specified room temperature properties
EN 10217-2:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 2: Electric welded non-alloy and alloy steel tubes with specified elevated temperature properties
EN 10217-2:2002/A1:2005 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 2: Electric welded non-alloy and alloy steel tubes with specified elevated temperature properties
EN 10217-3:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 3: Alloy fine grain steel tubes
EN 10217-3:2002/A1:2005 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 3: Alloy fine grain steel tubes
EN 10217-4:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 4: Electric welded non-alloy steel tubes with specified low temperature properties
EN 10217-5:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 5: Submerged arc welded non-alloy and alloy steel tubes with specified elevated temperature properties
EN 10217-6:2002 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 6: Submerged arc welded non-alloy steel tubes with specified low temperature properties
EN 10217-6:2002/A1:2005 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 6: Submerged arc welded non-alloy steel tubes with specified low temperature properties
EN 10217-7:2014 Welded steel tubes for pressure purposes - Technical delivery conditions - Part 7: Stainless steel tubes - missing VE
EN 10220:2002 Seamless and welded steel tubes - Dimensions and masses per unit length
EN 10224:2002 Non-alloy steel tubes and fittings for the conveyance of aqueous liquids including water for human consumption - Technical delivery conditions
EN 10224:2002/A1:2005 Non-alloy steel tubes and fittings for the conveyance of aqueous liquids including water for human consumption - Technical delivery conditions
EN 10226-1:2004 Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads - Dimensions, tolerances and designation
EN 10226-2:2005 Pipe threads where pressure tight joints are made on the threads - Part 2: Taper external threads and taper internal threads - Dimensions, tolerances and designation
EN 10226-3:2005 Pipes threads where pressure tight joint are made on the threads - Part 3: Verification by means of limit gauges
EN 10240:1997 Internal and/or external protective coatings for steel tubes - Specification for hot dip galvanized coatings applied in automatic plants
EN 10241:2000 Steel threaded pipe fittings
EN 10242:1994 Threaded pipe fitting in malleable cast iron
EN 10242:1994/A1:1999 Threaded pipe fitting in malleable cast iron
EN 10242:1994/A1:1999/AC:1999 Threaded pipe fitting in malleable cast iron
EN 10242:1994/A2:2003 Threaded pipe fitting in malleable cast iron
EN 10253-1:1999 Butt-welding pipe fittings - Part 1: Wrought carbon steel for general use and without specific inspection requirements
EN 10253-2:2007 Butt-welding pipe fittings - Part 2: Non alloy and ferritic alloy steels with specific inspection requirements
EN 10253-3:2008 Butt-welding pipe fittings - Part 3: Wrought austenitic and austenitic-ferritic (duplex) stainless steels without specific inspection requirements
EN 10253-4:2008 Butt-welding pipe fittings - Part 4: Wrought austenitic and austenitic-ferritic (duplex) stainless steels with specific inspection requirements
EN 10253-4:2008/AC:2009 Butt-welding pipe fittings - Part 4: Wrought austenitic and austenitic-ferritic (duplex) stainless steels with specific inspection requirements
EN 10255:2004+A1:2007 Non-Alloy steel tubes suitable for welding and threading - Technical delivery conditions
EN 10266:2003 Steel tubes, fittings and structural hollow sections - Symbols and definitions of terms for use in product standards
EN 10274:1999 Metallic materials - Drop weight tear test
EN 10275:1999 Metallic materials - Tube ring hydraulic pressure test
EN 10284:2000 Malleable cast iron fittings with compression ends for polyethylene (PE) piping systems
EN 10288:2002 Steel tubes and fittings for onshore and offshore pipelines - External two layer extruded polyethylene based coatings
EN 10289:2002 Steel tubes and fittings for onshore and offshore pipelines - External liquid applied epoxy and epoxy-modified coatings
EN 10290:2002 Steel tubes and fittings for onshore and offshore pipelines - External liquid applied polyurethane and polyurethane-modified coatings
EN 10294-1:2005 Hollow bars for machining - Technical delivery conditions - Part 1: Non alloy and alloy steels
EN 10294-2:2012 Hollow bars for machining - Technical delivery conditions - Part 2: Stainless steels with specified machinability properties
EN 10296-1:2003 Welded circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 1: Non-alloy and alloy steel tubes
EN 10296-2:2005 Welded circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 2: Stainless steel
EN 10296-2:2005/AC:2007 Welded circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 2: Stainless steel
EN 10297-1:2003 Seamless circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 1: Non-alloy and alloy steel tubes
EN 10297-2:2005 Seamless circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 2: Stainless steel
EN 10297-2:2005/AC:2007 Seamless circular steel tubes for mechanical and general engineering purposes - Technical delivery conditions - Part 2: Stainless steel
EN 10298:2005 Steel tubes and fittings for on shore and offshore pipelines - Internal lining with cement mortar
EN 10300:2005 Steel tubes and fittings for onshore and offshore pipelines - Bituminous hot applied materials for external coating
EN 10301:2003 Steel tubes and fittings for on and offshore pipelines - Internal coating for the reduction of friction for conveyance of non corrosive gas
EN 10305-1:2010 Steel tubes for precision applications - Technical delivery conditions - Part 1: Seamless cold drawn tubes
EN 10305-2:2010 Steel tubes for precision applications - Technical delivery conditions - Part 2: Welded cold drawn tubes
EN 10305-3:2010 Steel tubes for precision applications - Technical delivery conditions - Part 3: Welded cold sized tubes
EN 10305-4:2011 Steel tubes for precision applications - Technical delivery conditions - Part 4: Seamless cold drawn tubes for hydraulic and pneumatic power systems
EN 10305-5:2010 Steel tubes for precision applications - Technical delivery conditions - Part 5: Welded cold sized square and rectangular tubes
EN 10305-6:2005 Steel tubes for precision applications - Technical delivery conditions - Part 6: Welded cold drawn tubes for hydraulic and pneumatic power systems
EN 10310:2003 Steel tubes and fittings for onshore and offshore pipelines - Internal and external polyamide powder based coatings
EN 10311:2005 Joints for the connection of steel tubes and fittings for the conveyance of water and other aqueous liquids
EN 10312:2002 Welded stainless steel tubes for the conveyance of aqueous liquids including water for human consumption - Technical delivery conditions
EN 10312:2002/A1:2005 Welded stainless steel tubes for the conveyance of aqueous liquids including water for human consumption - Technical delivery conditions
EN 10329:2006 Steel tubes and fittings for onshore and offshore pipelines - External field joint coatings
EN 10339:2007 Steel tubes for onshore and offshore water pipelines - Internal liquid applied epoxy linings for corrosion protection
EN 10357:2013 Austenitic, austenitic-ferritic and ferritic longitudinally welded stainless steel tubes for the food and chemical industry
EN ISO 10893-1:2011 Non-destructive testing of steel tubes - Part 1: Automated electromagnetic testing of seamless and welded (except submerged arc-welded) steel tubes for the verification of hydraulic leaktightness (ISO 10893-1:2011)
EN ISO 10893-2:2011 Non-destructive testing of steel tubes - Part 2: Automated eddy current testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of imperfections (ISO 10893-2:2011)
EN ISO 10893-3:2011 Non-destructive testing of steel tubes - Part 3: Automated full peripheral flux leakage testing of seamless and welded (except submerged arc-welded) ferromagnetic steel tubes for the detection of longitudinal and/or transverse imperfections (ISO 10893-3:2
EN ISO 10893-4:2011 Non-destructive testing of steel tubes - Part 4: Liquid penetrant inspection of seamless and welded steel tubes for the detection of surface imperfections (ISO 10893-4:2011)
EN ISO 10893-5:2011 Non-destructive testing of steel tubes - Part 5: Magnetic particle inspection of seamless and welded ferromagnetic steel tubes for the detection of surface imperfections (ISO 10893-5:2011)
EN ISO 10893-6:2011 Non-destructive testing of steel tubes - Part 6: Radiographic testing of the weld seam of welded steel tubes for the detection of imperfections (ISO 10893-6:2011)
EN ISO 10893-7:2011 Non-destructive testing of steel tubes - Part 7: Digital radiographic testing of the weld seam of welded steel tubes for the detection of imperfections (ISO 10893-7:2011)
EN ISO 10893-8:2011 Non-destructive testing of steel tubes - Part 8: Automated ultrasonic testing of seamless and welded steel tubes for the detection of laminar imperfections (ISO 10893-8:2011)
EN ISO 10893-9:2011 Non-destructive testing of steel tubes - Part 9: Automated ultrasonic testing for the detection of laminar imperfections in strip/plate used for the manufacture of welded steel tubes (ISO 10893-9:2011)
EN ISO 10893-10:2011 Non-destructive testing of steel tubes - Part 10: Automated full peripheral ultrasonic testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of longitudinal and/or transverse imperfections (ISO 10893-10:2011)
EN ISO 10893-11:2011 Non-destructive testing of steel tubes - Part 11: Automated ultrasonic testing of the weld seam of welded steel tubes for the detection of longitudinal and/or transverse imperfections (ISO 10893-11:2011)
EN ISO 10893-12:2011 Non-destructive testing of steel tubes - Part 12: Automated full peripheral ultrasonic thickness testing of seamless and welded (except submerged arc-welded) steel tubes (ISO 10893-12:2011)
EN ISO 19879:2010 Metallic tube connections for fluid power and general use - Test methods for hydraulic fluid power connections (ISO 19879:2010)
EN ISO 21809-1:2011 Petroleum and natural gas industries - External coatings for buried or submerged pipelines used in pipeline transportation systems - Part 1: Polyolefin coatings (3-layer PE and 3-layer PP) (ISO 21809-1:2011)
EN ISO 21809-2:2014 Petroleum and natural gas industries - External coatings for buried or submerged pipelines used in pipeline transportation systems - Part 2: Fusion-bonded epoxy coatings (ISO 21809-2:2007)
EN ISO 21809-5:2010 Petroleum and natural gas industries - External coatings for buried or submerged pipelines used in pipeline transportation systems - Part 5: External concrete coatings (ISO 21809-5:2010)
or
