Page 17 of 19 FirstFirst ... 7 15 16 17 18 19 LastLast
Results 193 to 204 of 220
Thread: Petrel Step by Step
  1. Re: Petrel Step by Step
    Asalaam o Aalikum, Hi
    That,s very effective. kindly carry on.
  3. Re: Petrel Step by Step
    HI , Can any one suggest development strategy for maximum recovery and wells model in petrel and simulator is eclispe100 - I dont know how and which parameters to fill in the prediction/depletion and water injection prediction rules. Here is the link to the model i am working, I have basic idea of how petrel works since I am very new to petrel and eclipse (gives me convergence problem), any help will be appreciated.
    Here is the link to the model:
    Read more:
    Jan 2009
    ALA, KZ
    Noone here will make a work for you)
    Read the forum there are a lot of threads with 'how to' instruction.
    The guideline for any model optimization is to limit difference between oil RF and SweepFactor
  6. #196
    Jan 2009
    ALA, KZ
    Some useful utilities
  7. Re: Petrel Step by Step
    How to import well top. Thanks
  9. Re: Petrel Step by Step
    How to tie wells
  10. Re: Petrel Step by Step
    How to tie wells
  11. #200
    Jan 2009
    ALA, KZ
    Quote Originally Posted by Olalekange View Post
    How to tie wells
    To read manual and tie
  12. Re: Petrel Step by Step
    Hi guys,
    I have a problem running simple simulation, when I pressed run in the "Define Simulation Case", I get "eclrun.exe is not on the path".
    There's also this message that appears:
    message: Simulation Case is valid
    Warning: Threshold pressure (THRESHPT) is not supported by the simulator and has not been exported to deck
    What is that mean?
    Is there something wrong with the values in my fluid model? Rock physics function?
    Or there's a problem with the software I'm using?
    Anyway, I'm using Petrel 2013. And have not yet installed Eclipse.
  13. Re: Petrel Step by Step
    Hi guys,
    What is that mean?
  14. Re: Petrel Step by Step
    Quote Originally Posted by mrpeteng View Post
    Hi guys,
    What is that mean?
    You need to install Eclipse to run ECLRUN.
  16. Re: Petrel Step by Step
    in file tab right click on well folder and select import file
  1. Replies: 11
  2. Step by step to calculate control valve Cv thorugh Intools
