Asalaam o Aalikum, Hi
That,s very effective. kindly carry on.
HI , Can any one suggest development strategy for maximum recovery and wells model in petrel and simulator is eclispe100 - I dont know how and which parameters to fill in the prediction/depletion and water injection prediction rules. Here is the link to the model i am working, I have basic idea of how petrel works since I am very new to petrel and eclipse (gives me convergence problem), any help will be appreciated.
Here is the link to the model:[link Point to another website Only the registered members can access]
Read more:[link Point to another website Only the registered members can access]
Noone here will make a work for you)
Read the forum there are a lot of threads with 'how to' instruction.
The guideline for any model optimization is to limit difference between oil RF and SweepFactor
Some useful utilities
How to import well top. Thanks
How to tie wells
How to tie wells
Hi guys,
I have a problem running simple simulation, when I pressed run in the "Define Simulation Case", I get "eclrun.exe is not on the path".
There's also this message that appears:
message: Simulation Case is valid
Warning: Threshold pressure (THRESHPT) is not supported by the simulator and has not been exported to deck
What is that mean?
Is there something wrong with the values in my fluid model? Rock physics function?
Or there's a problem with the software I'm using?
Anyway, I'm using Petrel 2013. And have not yet installed Eclipse.
Hi guys,
What is that mean?
in file tab right click on well folder and select import file
