Page 2 of 2 FirstFirst 1 2
Results 13 to 15 of 15
Thread: PVELITE 2013 working in WIndows 7 64-bit
  1. #13
    Re: PVELITE 2013 working in WIndows 7 64-bit
    Dear gerge22,
    Following is the link for compress softwares
    version 7400 lastest( without -----)
    version 7320 one year ago (without -----)
    version 6258 -----ed version.( for xp only)
    I would appreciate if you could provide -----s for them.
    secondly, I am using pvelite2014 in virtual box with xp. And it is working fine. I installed it in windows 7 32bit but it is not installing. Please remember that I don`t have network card but I installed Microsoft loopback adapter and gave it a static ip address before installing it in xp and it get installed but I repeated same process in windows 7 but it is not installing.
    What I observe is that in xp by giving a static ip to loop back adapter, it icon blinks at the right bottom of desktop showing msg of connected but in windows 7 its icon show some yellow sign appears giving msg of unidentified network.
    Can you help for installing pvelite 2014 in windows 7 32 bit.
    Looking for your prompt response.
    regards,
  3. Re: PVELITE 2013 working in WIndows 7 64-bit
    P_V_E_l_i_t_e 2013 & 2014 with simple installation procedure
    Dear friend*
    I am looking for emulator for codeware compress 7400 or 7500 or 7600 . If you have or can manage * it will be great job. Secondly as you know that codeware compress can export its models into xml format which can directly impirted into Ampreva by technosoft to get the fabrication drawings.Similarly i want to convert pvelite files into xml format on the same pattern as the compress exports its models into xml format to import into ampreva. Ampreva has facility to import mdb files from pvelite but i have tried many times and i get msg from ampreva that pvelite model imported successfully but no model is formed. Looking for your expert opinions.Regards
  1. Pet 2013.2 exchange with working Intersect 2012.1 or CMG 2013
    By rinrin in forum Engineering Programming
    Last Post: 03-11-2019, 08:02 PM
  2. PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    By notachance in forum Mechanical Engineering
    Last Post: 04-14-2018, 07:58 AM
  3. PVElite 2013
    By CCCP in forum Mechanical Engineering
    Last Post: 07-02-2013, 02:10 PM
